Question about Coffee Makers & Espresso Machines
The machine does not give any water when I make coffee
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Hi Irene, The heating coil may be bad. Try to make some coffee and after a minuet take out the carafe and see if its hot.(using caution). If the hotplate is cold after a minuet of use the heating coils are not working. This can happen from no electric, loose connection at the outlet or the coffee maker or a bad heating coil. Hope this helps, Tom
Posted on Mar 28, 2015
Fault on Siemens TK76K573, after pump replacement
The water passages in the espresso makes may be clogged. Please descale the machine. Depending on the period for which the descaling was not done, it may need nore than one descaling cycle to remove accumulated Calcium deposits.
Calcium deposits narrow water passages and reduce the pump pressure to push water through the coffee grounds.
Oct 18, 2014 | Coffee Makers & Espresso Machines
My Kerig machine started shorting the amount of water delivered. Choosing the 8oz gives about 6 oz of liquid; same for 10oz giving 8oz,
Sounds like you need to de-scale the coffee maker. Use white vinegar instead of water, and run it through until the vinegar is gone (no coffee or filter basket). Then use clean cold water to purge all the vinegar by running the water through the system the same way.
If this doesn't work, and you've purchased your coffee maker within the last year, try giving Keurig a call at 866-901-BREW. Explain your problem, and they may be able to help you or offer you some sort of replacement.
Feb 28, 2011 | Keurig B60 Coffee Maker
Waring Pro Coffee Maker has a water flow problem
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
May 21, 2009 | Waring Pro® WC1000
Coffee is cold and not brewed properly. Unit has been cleaned,de-calcified, rinsed, but still the coffe is cold. temperature is set to high, and the machine can produce steam. Anyone help?
Apr 02, 2009 | Gaggia Titanium Espresso Machine
Coffee out of the machine seems too watery
Feb 22, 2009 | Gaggia Syncrony Compact Coffee...
Doesn't heat the water
Jan 27, 2009 | Nespresso C100B Essenza Single-Serve...
Saeco Professional- Coffee taste watery and not creamy
Nov 23, 2008 | Saeco Royal Professional Espresso Machine
The water that comes out thru the coffee gounds and into the carafe is only warm not hot.The coffee that is brewed is weak and only warm.
Sep 12, 2008 | Krups Small Appliances Espresso Machine
Weak coffee
Jun 24, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
