Question about Amana Ovens
My propane oven only gets mildly warm what's wrong with it?
    New Friend:
    Problem Solver:
  • 14 Answers
You resolve that issue over the phone in a minute or two.
the best thing about this new service is that you are never placed on hold and get to talk to real repairmen in the US.
the service is completely free and covers almost anything you can think of (from cars to computers, handyman, and even drones). Printable Calendar Templates September 2017 Printable Calendar Template
Posted on Aug 10, 2017
  • Amana Master
  • 610 Answers
Propane? was it a recent install? Gas orifices must be changed and regulator added or removed depending on which fuel is being used, you may need a conversion kit.
Posted on Apr 22, 2016
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
Gas oven gas not shutting off
sounds like you got some debri in the safty valve, teflon tape or pipe dope. they don't come apart so you will probly have to replace it. sorry! disconect lines and blow out good befor replacing it so it don't happen to the new one
Dec 25, 2009 | Ovens
If I DO NOT want to use the self cleaning feature is there any other safe way, including using soap and water, to clean the oven without ruining it? (I don't want to use the self cleaning feature)
  1. Oven door : Wash the door and window with soap and water and rinse with clear water. Use glass cleaner only if sprayed on a cloth first. Do not use abrasive pads, powdered cleaners, or steel wool on glass and enamel, or the surfaces will be scratched.
  2. surface burner : To absorb a spill when it is hot, pour salt on it and wipe it up when the oven has cooled. A mildly abrasive baking soda and water paste can be used in the oven, too.
  3. Racks:Remove oven racks and clean them in warm, soapy water. Stubborn messes can be cleaned by using mild abrasive cleansers or a soap filled scouring pad. Rinse and dry the racks before returning them to the oven.
  4. Metal trim:Metal trim can be cleaned with glass cleaners or mild cleansers, soap and water. Abrasives or cleaners made for oven interiors should not be used.
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Natural gas to propane?
You have to get a converter for propane. You can call any hardware store in your area. Hope this helps you, if not, you can call me. :>)
Aug 13, 2009 | Maytag Ovens
Gas ranges low pressue propane? 2 of them
The problem is with the tanks or the pressure regulator.. Call your propane provider and tell them what is going on. they should come out and replace the regulator and check the gas line for kinks or partial blockage.
Jul 11, 2009 | Kenmore 30169 Electric Single Oven
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Propane kitchen-oven ''whoofs''
Propane burns very dirty,I bet the burner and pilot are clogged with soot.In techinical terms the sound your hearing is blowback.If you check the burner/pilot you will likley see black soot,remove them and clean with soap and water.
Mar 16, 2009 | Ovens
Gas oven that cooks unevenly
clean your orifaces.
Also make sure that it's the correct stove for your gas type. If you're using a NG stove on Propane, you're wrong. It's making a lot of soot, and could potentially blow up your house. Stop using it until you're sure.
Dec 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
My oven isn't warming up
can you verify the ignitor is working (ie: can you hear it sparking)?
1. If no, and you are absolutely sure there is not a buildup of propane inside the oven (or house for that matter), you can try lighting it with a match. If that works, you need to replace/reposition your ignitor.
2. If yes, do you smell propane after trying to light the oven?
A. If yes, STOP and get it fixed..
B. If no,
1. Check to see that your propane tank isn't empty?
2. Verify the regulator supplying the oven with propane is actually sending gas to the over (might need a repairman for this)
Dec 22, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ovens Logo
Top Amana Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
john mabry
Are you an Amana Oven Expert? Answer questions, earn points and help others
