Question about Garden
Speed control will not change speed
Changing speed on speed selector will not increase or decrease
  • 2,029 Answers
Check all linkage from the throttle to the carburetor . Sounds like something has come undone or broken. Check springs as well. Some times the throttle cable its self will break. I have seen where a loose screw or bolt will not let the linkage work as well.
Posted on Mar 30, 2015
2 Suggested Answers
  • 23 Answers
SOURCE: Why does engine speed decrease when blades are engaged?
need to clean grass from under mower change plug and air filter for better perfomance
Posted on Jun 15, 2012
I replaced the blower, and resister on my 2012 chevy. impala but blower still don't work. What fuse do I need to check
The fuse box should be under the hood, passenger side. Try the upper box, middle right side Mine is huge, 30 amp
Sep 23, 2016 | 2012 Chevrolet Chevrolet Impala LT
Why does my D on the amp selector knob not doing anything. A, B, and C, work fine just not the D.
the contact for the selection of Dmust be broken/faulty. A repair shop could fix it or , if you can obtain the part , you can replace it. You are probably unlikely to be able to repair it I think, it will pssibly be a fiddly job
Good Luck
May 31, 2015 | Welding Tools
How do i set the cruise control on my 1994 mercedes c220 elegance automatic
Cruise Control
Any given speed above approximately 22 mph (35 km/h) can be maintained with the cruise control by operating the lever.
-see photo
  1. Accelerate and set: Lift lever briefly to set speed. Hold lever up to accelerate.
  2. Decelerate and set:
    Depress lever briefly to set speed. Hold lever down to decelerate.
    Normally the vehicle is accelerated to the desired speed with the accelerator. Speed is set by briefly pushing
    the lever to position 1 or 2. The accelerator can be released. The speed can be increased (e.g. for passing)
    by using the accelerator. As soon as the accelerator is released, the previously set speed will be resumed automatically. If a set speed is to be increased or decreased slightly, e.g. to adapt to the traffic flow, hold lever in position 1 or 2 until the desired speed is reached, or briefly tip the control lever in the appropriate direction for increases or decreases in 0.6 mph (1 km/h) increments. When the lever is released, the newly set speed remains.
  3. Canceling
To cancel the cruise control, briefly push lever to position 3.
When you step on the brake or the vehicle speed drops below approx. 22 rnph (35 km/h), for example when driving upgrade, the cruise control will be canceled.
4. Resume
If the lever is briefly pushed to position 4 when driving at a speed exceeding approx. 22 mph (35 km/h), the vehicle resumes the speed which was set prior to the cancellation of the cruise control. The last memorized speed is canceled when the key in the steering lock is turned to position 1 or 0.
Note:
If the engine does not brake the vehicle sufficiently while driving on a downgrade, the speed you set on the cruise control may be exceeded and you may have to step on the brake pedal to slow down.
As soon as the grade eases, the cruise controlled speed will again be maintained as long as the brakes were not previously applied, or the lever may be used to resume the previously set speed if the brakes were applied.
http://www.benzworld.org/forums/attachments/w202-c36-c43/153145d1197313761-pdf-owners-manual-w202-1995-2000-1999-c280_owners_manual.pdf
Feb 14, 2015 | Mercedes-Benz C-Class Cars & Trucks
Correct code P0504?
What Colorado do you have ? 2 wheel or 4 wheel drive ? Sport ,sport LS 3.5L , Z71, Z71 LS. etc. what size engine ? an does it have electronic throttle control ? I have factory service info an it is not showing that code .
DTC P0506
Circuit Description
The throttle actuator control (TAC) motor is controlled by the powertrain control module (PCM). The DC motor located in the throttle body drives the throttle plate. In order to decrease idle speed, the PCM commands the throttle closed reducing air flow into the engine and the idle speed decreases. In order to increase idle speed, the PCM commands the throttle plate open allowing more air to pass the throttle plate. If the actual idle RPM does not match the desired idle RPM within a calibrated time, this DTC sets.
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC P0506 Idle Speed Low
DTC P0507
Circuit Description
DTC Descriptor
DTC P0507 Idle Speed High
Cleaning the throttle body mite take care of it !
Cleaning Cleaning An Electronic Throttle Body Safely
Jan 31, 2015 | 2005 Chevrolet Colorado
Speed changes on it own
speed controller is malfunctioning
Dec 11, 2013 | Weslo Epic 10pi Rear Roller For Model...
The tines on a honda f220 always spin and don't change speed when clutch is engaged but speed up when throttle is increased. Adjusted cable with no luck.
I believe that unit utilizes a centrifical clutch. try decreasing the idle speed and see if the tines stop. They should then engage as throttle is increased.
Sep 24, 2012 | Honda 25cc 4-cycle Mini Tiller
2008 chrysler 300 heater/ac control only changes functions when fan is on high
sounds like a electrical issue in the switchs there not flashing a trouble code are they
Nov 20, 2011 | 2008 Chrysler 300
Chainsaw starts normally idles well increase speed and cut a log then decrease speed and the motor stops
Have you tried changing the gas you are using? Sometimes with the addition of ethanol, water condensation is attracted and builds up in the system, creating a fuel mix that affects performance. Also, make sure your settings for High speed throttle are correct. You may need to make a small adjustment on the screw marked H for running high throttle.
Aug 21, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The mpv 5 is in low gear how do you change it to high gear
The second row of lights in the speed indicator. The two bottom buttons will increase and decrease the speed. The lower left button will decrease, the lower right will increase. You will see the second row of lights get bigger or smaller as you press those buttons to increase/decrease your speed. When the second row of lights is fully lit, you will be at the top speed.
Jun 24, 2010 | NRS Hoveround MPV 5 - Used Power...
Turntable 45rpm speed has stopped working
Check that the lever is actually making the contact with the 45 rpm switch position and completing the circuit as it would seem everything else works. The only other thing it could be is a break on the pcb, but that is unlikely.
Oct 17, 2008 | Philips Audio Players & Recorders
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
