Question about Vestax Audio Players & Recorders
Does anyone know where I can but a hinge replacement hinge that holds dustcover on a Vestax bdt 2600 turntable?
  • Vestax Master
  • 5,126 Answers
Vestax went out of business in 2014. I have found a website called Virtual Sounds Technology. They are the largest suppliers of their parts going. They say "if we don't have it, it either no longer exists or can only be pulled from a used unit".
So your best option is to ask them!
Posted on Jan 09, 2016
4 Suggested Answers
SOURCE: i carnt remove the turntable platter can anyone help
The platter needs a drop of oil as the platter and motor shaft is a machined fit, Via brass upside down v as the platter will be reversed ie: a A WITH NO LINE . You can place two plastic wedge shaped blocks ,one on each side of the platter with even pressure and work up.
Posted on May 19, 2009
  • 124 Answers
SOURCE: kenwood turntable cover hinge replacement
Yes they can be replaced.
Contact the store you purchased it from or ask where they have repairs done. They should be able to order the parts for you.
Posted on Sep 12, 2009
richardvreed
  • 432 Answers
SOURCE: my turntable keeps skiping for no reason, no
Don't forget that the tone arm is too short and the material too heavy, i like vestax, but a bit wrong angle with too much pressure messes up your records fast.
Posted on Jun 14, 2014
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    Repairing tone arm of a pioneer PL 200!
    i have the same problem with two vestax parts, which of one is round so sprayglue and three turns around it with thin koper cable.and after that sandpapered itagain and another layer glue, but i had no choice... the part ain't available en a couple of days ago my backside of a pdx 2000 spantanious broke of, but carbon wil hopefully fix it. You need to know of which plastic it's made and get the right glue, but you nee some glassfibre orso also on the inside , or it will brake
    May 11, 2014 | Vestax BDT-2500 Turntable
    Vestax Handy Trax Turntable skips toward the end of very LP played. Does anyone know how to resolve this issue?
    Generally caused by a worn stylus, or incorrect pressure. Increase the weight - pressure, by adjusting the weight on the end of the arm.
    Apr 22, 2014 | Vestax Handy Trax Turntable
    Parts sales
    I should contact the Vestax website and ask them if the part is still made and where spare parts can be obtained.
    Sep 06, 2013 | Vestax BDT-2500 Turntable
    Dustcover will not stay up. how to adjust? where to find service manual?
    You will probably need a set of Allen Keys. One should fit in the bracket which will tighten up the hinge.
    Aug 22, 2013 | Numark TT100 Turntable
    I carnt remove the turntable platter can anyone help
    May 09, 2009 | Vestax PDX-A1MKII Turntable
    Hinges for dustcover of Technics SL1300 turntable
    See: http://djparts.net/technics-parts-replacement-dustcover-with-hinges.html
    Has a dustcover w/hinges... :o)
    Mar 06, 2008 | Audio Players & Recorders
    Open Questions:
    140 people viewed this question
    Top Vestax Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Steve
    Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
