Question about GE Refrigerators
Why does my GE model number TBX1811 refrigerator leak from the back inside the fridge
    Master:
  • 416 Answers
Water leaking inside it
  1. Check the lines to your dispenser
If the lines to your dispenser are broken or damaged you will need to replace them.
  1. Damaged drain pan
If your drain pan has holes or cracks it will also need to be replaced.
  1. Clogged drain
If you experience any clogged drains, they must also be unclogged or replace. If you experience this at the ceiling of your unit it can be attributed to a clog in the freezer section. Remove the divider and let the insulation thaw out and dry.
Posted on Mar 29, 2015
jumptrout51
  • 3361 Answers
SOURCE: My GE Profile fridge periodically (eve other n) leaks water
Thaw out the defrost drain in the freezer. It has frozen over and the defrost water has nowhere else to go except on your floor.
Posted on Apr 08, 2009
SOURCE: ge model gsh25jfrfww not cooling just clicking
Replace the main board on the back i got the part for $130 at a wholesale parts store
Posted on Mar 06, 2009
woodchuck789
  • 4066 Answers
SOURCE: Kenmore refrigerator (model 106.78187891) leaking inside
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 14, 2009
iwillfixforu
  • 619 Answers
SOURCE: GE fridge/freezer on but no cold air
The main board on the back of the unit has gone bad or in lockout. Try unplugging unit for about 30 seconds. Then plug it back in. If it doesn't start the board is bad. wr55x10942 at about 169.00. Hope this helps. Very common GE problem
Posted on Mar 07, 2010
  • 4 Answers
SOURCE: LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Posted on Jan 16, 2011
A refrigerator that I bought second hand but has worked remarkedly well and still does with one exception. Is it worth fixing.
Of course it is worth fixing! This leak is cause by a defrost drain that is blocked with ice and sludge. I really can't tell you how to remove that rear panel unless you provide a model number. This problem is worse with the Samsung dual evaporators as the evaporator inside the fresh food compartment is usually the one that causes problems on those models. There are a few GE dual evaporator refrigerators also that are really a Sumsung with the GE brand name. Here is a link that may help but you need to pay close attention to the videos and focus especially on your Brand
Leaking Refrigerators
APPLIANCE 911
Aug 29, 2016 | Refrigerators
12-14 yr old ge bottom freezer. freezer is working, fridge is warm.
not all refrigerators are the same can you look inside the fresh food section around the door or on the back of the refrigerator and provide a model number?
Appliance 911 Sea Breeze
Sep 30, 2015 | GE Refrigerators
Need an ice maker for a TBX1811 refrigerator
Hello;
The ice maker that your need is part number WR30X10093. It cost about $140.00.
Oct 14, 2014 | GE Refrigerators
LEAKING FRIDGE
A magnitude of problems could be caused by this, you should really call someone to come out and look at the refrigerator. With that model having a ice maker and water dispenser, it could be a crack in the water filtration which is typically located in the lower read of the refrigerator. If nothing else seems to be wet on the inside of the refrigerator you can almost guarantee that its the filter and pump in the back leaking which will require a skilled professional to look at it.
Dec 08, 2011 | GE Refrigerators
Ge top freezer model tbx211a leaking water on occasion inside fridge
Drain is clogged inside freezer.
Your model number is missing a few characters, but this model should have a black tube coming out of the back side of your refrigerator about 1/2 way from the floor that drains into a pan underneath near compressor. Check this first to see if it is clogged. Carefully pull it off where it enters the back wall (will need to pull out refrigerator to access this) try running a wire into tube to clear and pour water down tubing to make sure it is clear.
Next you may need to pull the back panel inside freezer to excess evaporator coils. Turn off or unplug refrigerator while doing this and pour hot water onto ice build up under coils. Once that is clear and water is draining fine into pan under refrigerator, reassemble and your problem should be solved for a few more years again.
Jan 30, 2011 | Refrigerators
Freezer not cooling, fan blowing, fridge also not
If there is no frost , on the inside rear freezer wall ,
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
If there is frost , reply back with complete model number .
Nov 08, 2009 | GE PSS25MGN Side by Side Refrigerator
Leaky Water Valve Inlet
The part number for the valve for a pss26msrss is:
WR57X10032 it is around $45.00-$50.00. There are several look ups available but you need a complete model number that you will find on the refrigerator usually inside upper fresh food section. you can order at repairclinic.com, sears .com ... or you can google appliance parts and see what you come up with. You might also try a local appliance store. Good Luck.
Jan 08, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaks when filter is connected
Does it leak from the back or the front of the appliance ??
Aug 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator Leaks
I can't find this model number anywhere and am unfamiliar with the "Evolution" series. However, if it is a top/bottom unit (freezer on top, fridge on bottom) it sounds like you have a clogged drain.
If you pull the back panel off inside of the freezer (where the evaporator is housed) you will see a drain hole, usually in the rear center) that is probably full of ice. If this drain is plugged, it will cause the water to back up into the refrigerator, usually onto the top shelf or under the veggie bins, and possibly onto the floor.
You need to clear it out, and make sure that water flows through it freely, to the pan underneath the unit. The best way to do this is with a hair dryer and a copper wire, but be careful not to melt the inside of the freezer with it. When it's clear, you might want to take a hose and blow through it to make sure there's nothing trapped inside.
Please let me know if you need any further help with this issue.
Mar 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
