Question about Garden
Speed control won't increase - Garden
  • Garden Master
  • 2,471 Answers
Check all linkage from the throttle to the carburetor . Sounds like something has come undone or broken. Check springs as well. Some times the throttle cable its self will break. I have seen where a loose screw or bolt will not let the linkage work as well.
Posted on Mar 30, 2015
Blower fan not working at all 2004 Buick rendezvous
Which system ?
HVAC Systems - Manual HVAC Systems - Automatic
If automatic it's probably the blower motor control processor .
Blower Motor Control Processor The blower motor control processor is an interface between the HVAC control module and the blower motor. The blower motor speed control, Blower motor speed signal, battery positive voltage and ground circuits enable the control processor to operate. The HVAC control module sends the commanded blower motor speed to the control processor through a 0 to 12-volt linear ramped blower motor speed control circuit. As the blower motor speed control voltage increases, the blower motor speed increases. The control processor sends the actual blower speed to the control module through a 0 to 12-volt blower motor speed signal circuit. The processor supplies 12volts to the blower motor through the blower motor voltage supply circuit. The control processor uses the blower motor ground as a low side control to adjust the blower motor speed.
Nov 19, 2016 | Buick Cars & Trucks
I replaced the blower, and resister on my 2012 chevy. impala but blower still don't work. What fuse do I need to check
The fuse box should be under the hood, passenger side. Try the upper box, middle right side Mine is huge, 30 amp
Sep 23, 2016 | 2012 Chevrolet Chevrolet Impala LT
How do I increase lowering speed.
Your question isn't clear. Are you talking about cruise control? I would understand, 'How do I increase speed?' or, 'How do I lower speed?', or even, "How do I increase speed and lower speed?' would make sense.
However I don't understand, "How do I increase lowering speed?"
Feb 22, 2015 | Cars & Trucks
Overheated and won't restart. Any ideas?
Check to see if your laptop has an option for fan speed control, if it does, increase the rpm's.
Id doesn't be careful, you may have a bad collong fan, if that's the situation STOP using the laptop until you replace the cooling fan.
Mar 17, 2013 | Toshiba Satellite L505-S5966 Notebook
2001 Lincoln LS, 5 speed manual, cruise control buttons are mixed up. + does resume, - sets or increases speed, cancel sets or reduces speed and won't cancel. Is this computer related? Had an issue...
Sounds like your clock spring may be going bad. The blinking cruise control symbol is a warning that you are traveling at a high speed. That is nothing to really worry about.
Sep 04, 2017 | Lincoln LS Cars & Trucks
2003 Chev Malibu.V6, loaded: HVAC: control head
under the dash on the right side ,look for a plug with 5 wires . That switch is called a RHEOSTAT.(fan speed control).Sounds like it is defective
Apr 05, 2010 | 2003 Chevrolet Malibu
Wire Speed Increases when voltage increases
What is it doing? stabbing the wire into the work? The voltage is too low for the speed of the wire feed.. Turn up your voltage and slow down the wire. then increase your wire according to the speed of travel of weld. That is an awesome machine but it is still up to you to get the settings dialed in. Good Luck, Ned.
Sep 16, 2009 | Welding Tools
Shoprider deluxe te-889af loses power when reversing
I think that this is usual to have a slower reverse speed for safety.But on your shoprider you should have 4mph and 8mph ,usually if you are at 8mph it won`t reverse at that speed, you have to go to 4mph ,look infront of you there is a dial this controls the speed that you go forward and reverse.If reverse speed needs to be increased turn the dial up,but don`t forget this also increases forwards.
Jan 14, 2009 | Shoprider Sprinter 889B-4 Scooter by
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
