Does anyone know where I can buy a replacement hinge (hinge that holds the dust cover)?
  • 4 Answers
You can get almost any part you require from ebay just put your model no in the search bar
Posted on Mar 29, 2015
    Master:
  • 238 Answers
Hi Michelle,
What kind of laptop do you have? If you can provide the make and model number, I'll be happy to point you in the right direction.
You can even start here, too:
Hope this helps!
Posted on Mar 28, 2015
Looking for dust cover hinges for a SL-1900 turntable
Fixya does not sell replacement dust cover hinges.
Sep 18, 2016 | Audio Players & Recorders
Where can I find dust cover hinges for the above model?
Dust cover hinges can be like hen's teeth!
The message I am looking it from you shows no above model, but you can ask the makers if they are still around for spare part suppliers. Otherwise it's off to E-Bay to see if anyone has one second hand.
Nov 04, 2015 | Audio Players & Recorders
Dust cover falls down
You'll have to flip your turntable upside down on a pillow or beanbag, remove the feet & all the screws including the harder plastic underside to get to the hinges where by which you can estimate whether there was wear & tear & needs replacing or whether it was a simple fix by just tightening up the screws that hold the hinges in place.
Feb 09, 2014 | Technics Audio Players & Recorders
Hinge Replacement, Thule Thule Atlantis 688T 2100 Cargo Cariier
Hi Erroll,
What I believe you're referring to is the 'locking hook' -- the piece attached to the lid that slides into the lock mounted on the bottom segment of the cargo box. While it acts like a hinge in respect of the closed side of the Thule, what the mfg refers to as the hinge (or also referred to as a strut) is the spring mechanism at the front and back used to hold the lid up.
You can acquire this locking hooks online - attached a link for your convenience.
Good luck.
THULE ATLANTIS 200 from Exeter Roofracks Roofboxes
Apr 28, 2012 | Office Equipment & Supplies
Acer 9300 Laptop CRACKED BACK COVER NEAR HINGES
I would start watching e-bay for one. They're usually pretty reasonable, and without knowing exactly what part you're talking it's awfully hard to quote you a price.Good luck.-jmattes
Oct 19, 2009 | Acer Aspire 9300 Notebook
Hinges for top cover for HP officejet 6210- Q5820A
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Sep 06, 2009 | HP Officejet J5780 All-In-One Printer
Sony Ericsson W350i - replacement hinged keypad cover
While this may not be typically, I just talked with Sony Ericsson and they are sending me a new flip cover at no charge. I should receive it within 3-5 business days.
Sep 27, 2008 | Sony Ericsson W350i Cell Phone
Compaq Presario Laptop (M2000 series) hinge
Hello Wendy names Nick and just done hinge work on the Presario V5000z and readin up on your problem my suggestion would be lookin on ebay or various sites for the hinge then go about replacing it.
Steps involved in replacing the hinge start with removing power and battery
Next come the more difficult step, removing all the screws fron the bottom of the unit (this is done to gain access to the wireless cables which run from the wifi card to the lcd display)
once the base is removed then you carefully use a flat head screw driver an near the top row of keys (while pressing a few of them down) you will see a few notches which you can pry off the top cover giving you access to the lcd screen connector and bracket anchoring screws.
hopefully you disconnected your wireless antenna leads by now, and also disconnected the lcd cable from the board.
now you have the lcd display free from the base, now to change the hinge.
under the lil rubber circle pads are screws holding the brazel to the front of the lcd, this should be removed to get access to the lcd itself and thus the hinge brackets.
remove replace carefully i might add. then do everything in reverse to get the system reassembled and there ya have it
hinge has been replaced
P.S. careful steps should always be taken to prevent shock damage to any computer system when working on internals, also mind bending and pincing cables since they can most times be easilly damaged
Aug 18, 2008 | HP Compaq Presario V5000Z Notebook
Cx7330, battery cover BROKEN
Remove batteries and memcard. Remove 8 screws, the screws on the bottom are smaller than the side screws. Rear cover will slide off, watch out for loose LCD screen. Two protruding slots on the bottom hold the battery cover hinges. Hold battery cover wide open and at an angle to snap hinges into place. Reinstall rear cover and screws.
May 29, 2007 | Kodak EasyShare CX7330 Digital Camera
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
