Question about JVC Televison & Video
How do I turn off blind audio on my jvc TV? - JVC Televison & Video
Our JVC TV 40 HAS NO PICTURE BUT IT HAS SOUND. CAN YOU HELP
Please post your problem once. We are all not blinds.
May 22, 2017 | JVC Televison & Video
I have a JVC RX-7010V AUDIO/VIDEO CONTROL RECEIVER. And I can not get it to hook up to my TV for surround sound I have to hook it up through my headphone jack on my TV.
On the back of the JVC receiver, there should be a TV input, Coax IN and OUT or AUX input (I don't remember if this model had HDMI). On the back of your TV, there should be an AUDIO OUT, connect this to either the TV or AUX inputs and make sure on your TV, to set the Audio Out is On in the TV menu. Turn on JVC and set input to TV and adjust volume. Another way is using the COAX input and outputs. Connect Output of cable box to Input of JVC, then connect Output of TV to Input on TV.
May 15, 2016 | JVC Audio Players & Recorders
Turn off audio voice over for the blind
This is called Closed Captioning.
Go to the menu via the TV remote control and find the CC options and disable that feature.
Apr 12, 2015 | LG Televison & Video
My vizio 60' flat screen tv audio captioning for the blind will not turn off? A voice comes on during all prime time shows describing visual actions for the blind...help?
Go to your Menu options, and look around for a RESET option. You want to basically do a factory reset on your TV. (I'm assuming you turned off the setting, the system confirmed it, but it never turned off?)
Jan 31, 2013 | Televison & Video
I am using an optical audio out from my tv to my JVCrx-7010v. I am using the TV in jack, cannot get any audio out let alone 5.1
Where does the digital audio REALLY originate - the TV or something higher up the food chain like a Cable Box?
Try getting it from the source to make sure it works. Then, if you REALLY think the TV needs digital 5.1 and an intervening run of cable before it passes audio to the JVC, connect it as the book says.
The TV can probably survive just fine with a simple RCA stereo audio patch from the cable box just in case you want to watch CNN without the JVC turned on.
Feb 05, 2011 | JVC RX-7010V Receiver
How to find JVC AV27320 headphone jack? I've plugged into the avs(red & white) in the front panel as well as the extra ones in the back. Altho - I CAN hear the sound thru the headphones, The external...
This model doesn't have a headphone jack. The only JVC TV in the series that does is the model AV-20D202. For the JVC AV-2732, use the RCA audio out jacks with an RCA to 3.5 mm adapter to connect to the headphones. The front audio jacks are audio in (for the audio from a video camera for example).
When you use any external speakers or headphones through the audio out jacks, make sure to turn off the TV speakers. Press Menu and navigate down to TV Speakers (up/down arrows). Then use the right/left arrows to select Off and then Exit the menu. Make sure you scroll the TV volume before doing this. Note: if your headphones do not have a volume control they are a bad choice for this type of audio output.
You can find the manual for the TV here: http://books.jvc.com/booklist.asp?Model=AV-27230 .
I wish that I had better news for you.
Jan 06, 2011 | JVC AV-27320 27" TV
Cannot get home theatre to work with panasonic flat screen. Surround sound was working with old tv got a new one but now its not working. Do i need a different cable
your new tv probalby has an hdmi output. depeding on how old your jvc system is, iit may or may not have an hdmi input. not to worry, there should be some type of compatible output on the tv to send audio signal to the jvc. first look at the back of the jvc and see whats there. then look at the tv and you should see compatible output on tv and run proper cable to input on jvc. some auxillary audio outputs on the tv are driven by the volume of the tv itself, so make sure to turn the volume on the tv up a llittle to make sure its sending signal. you may have to go into the tv menu and turn the internal tv speakers off so you dont hear them and the jvc. its not a big deal if your hearing both, it just wont be true surrond sound. if it were mine, id turn the tv speakers off.
Dec 24, 2010 | JVC TH-C40 System
How do I get a service for the blind voice off my Sony Bravia TV
in the menu of your tv .. look for SAP .. thats secondary audio program .. turn that off ... if you have a cable box then check that also in its setup .. . if you cant find SAP then provide your model number and we can give more specific instructions ..
Nov 21, 2009 | Televison & Video
No Picture, only audio
If it is a CRT TV Then The CRT Unit Could Be Dead
Aug 27, 2009 | JVC AV-20020 20" TV
Will not turn on
So, you did not find the bad Cap in the powersupply?? Might get yourself some glasses cause you seem to be blind.
Jan 07, 2008 | JVC AV-27F702 27" TV
Televison & Video Logo
173 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
