Question about Mitsubishi Lancer 08 2008
08 lancer battery keeps going dead tried 3 new batteries installed,had new belts installed as per recall,alternator checks out
Battery keeps going dead. tried 3 new batteries.had new belts installed.alternator ok. have to have it jumped started when I want to use it.
  • Mitsubishi Master
  • 4,134 Answers
Based upon what you have said, it would seem that you have something that is causing a continuous battery drain. Have you added any new electronics to the vehicle that may have accidentally been wired up to a constant hot source instead of one that is controlled by the ignition switch? Many enthusiasts accidentally install stereo amps directly to hot and find they never shut off, killing the battery. If you are skilled at electronic troubleshooting, you may be able to track down a wiring problem yourself. I will warn you that many repair shops will attempt to diagnose your problem, but few are trained to do it efficiently. If you decide to pay a pro to fix it, go to an Auto Electric specialist. They charge more per hour, but will take far fewer hours to locate and repair the problem than the corner mechanic.
Posted on Mar 28, 2015
I replace altornator and battery my 2007 f 250 the battery keep going dead
Before replacing alternator check that the drive belt is at correct tension, it should only move up and sown by a finger width or two.
If you do replace, them again make sure belt is correctly set. It may not be necessary to replace battery, try charging battery first, and seeing if the new alternator keeps iit powered
Oct 05, 2015 | Cars & Trucks
Tried 3 new batterys,had alternator checked,had a new serpentine belt installed as per recall notice from Mitsubishi for 08 lancer,had certified techs from Mitsubishi dealer installed new belt car started...
If you know for sure the battery, alternator, and serpentine are OK. then (A) you might need more power to start than your battery can produce. This is not likely because the jump battery does the job. (B) are not really charging because of a bad connection at ground, battery cable, or fuse. You can test this with a volt meter. You might try checking the battery condition just after running by turning on the headlights and see what they do when you try to start. You can check it again a few hours later. (C) Something in the car is draining power. You can check this by (1) disconnecting the ground cable at the battery, (2) charging the battery, (3) connect a test lamp between the the battery cable and the battery. If the test lamp glows, some device is pulling power with the ignition off. Pull fuses one at a time until the test light goes out. (replace the fuses if the light stays on.) Then find the component on the fuse that is grounded and fix it. Look for simple stuff like a wire with bad insultion at one spot or maybe a bad cigar lighter.
Mar 30, 2015 | Mitsubishi Cars & Trucks
Battery keeps going dead,bought 3 new,had new belts installed as per recall,alternator is good. still have to jump start when I have to use it.
Sounds like something is causing a power drain. If you know how to use an amp meter it's not too hard to find it. Disconnect the positive terminal from the battery with the meter set on amp put one lead from the meter on the battery terminal the other to the cable you took off the battery so that the current goes through the meter if it shows a drain pull out one fuse at a time until no drain seen then just check what that fuse goes to.
Mar 28, 2015 | Mitsubishi Lancer 08 2008
2002 mitsubishi lancer won't start Ok so my car started making a loud screeching noise when it would start up, and then a few days later I drained my battery on accident listening to music in the...
When a car battery gets low, the windows won't necessarily move extremely slow - you may still have functionality, but not enough power to start the vehicle. Charge up the battery or replace it if it is more than 4-5 yrs old. As for the screeching sound, its possible a loose alternator belt could cause that - if the belt is too loose the alternator might not be charging the battery properly. Another possibility is the alternator is binding and that can cause the screeching too. Remove the drive belt and try to rotate the alternator by hand - if there is excessive resistance you might be looking at a new alternator too. Most automotive parts stores will test your battery and charging system for free if you ask them.
Mar 15, 2011 | 2002 Mitsubishi Lancer
Alternator 1993 mark 8 lincoln
take the negative side of the battery off and then remove the drive belt and there should be a belt tensioner near the belt take the pressure of the belt by using the 3/8 or a 1/2 in sockets and make sure you use the right side socket if needed
Feb 04, 2009 | 1993 Lincoln Mark VIII
Even with new batteries and they go dead before I take 3 pictures
Yes, there is definitely a fault with your camera.  You should be able to return it for a replacement.  I wouldn't experiment too much with batteries in this camera. batteries discharging this quickly are likely to overheat, causing unmentionable catastrophe.
Dec 11, 2008 | HP Photosmart M547 Digital Camera
My baterry keeps on going dead and i had the altenator checked and it passed
Here's the key parts of the electrical system.
Battery: the source of your electrical energy
Alternator: The charging source for the battery. Driven by the engines rotation via a fan belt
Regulator: tells the alternator when your battery needs to be charged and how much.
The Load: all of the devices that use the batteries energy
If you have replaced the battery 3 times we can rule out the battery as the problem
You had the alternator check and it passed. We can rule out the alternator
The load: It's fixed and for the most part you can control most of this with knobs on the dash
That leaves only the regulator. If the regulator is giving bad info to the alternator that could account for the problem.
Try this ( if you don't have a voltmeter, places like AutoZone can make these measurements)
Start the engine and measure the voltage at the output of the alternator. It should be about 13.5 to 14.0 volts. Then measure the voltage at the battery terminals. It should read the same as what you got at the alternator. If it's not,check the battery cables for clean bright connectors. Use a battery terminal brush to clean the. If this still doesn't help check the regulator.
Hope this helps
Good luck Loringh
Oct 22, 2008 | 2001 Mitsubishi Montero
Electrical. Now. Mon. 7/28/08 9:43 PM
take to a alternator starter rebuild shop. most likely a bad ground or discharged battery
Jul 29, 2008 | 1993 Ford Aerostar Extended
Mitsubishi Lancer 08 2008 Logo
134 people viewed this question
Top Mitsubishi Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Mister Danger
Are you a Mitsubishi Car Audio and Video Expert? Answer questions, earn points and help others
