Question about Mitsubishi Lancer 08 2008
Battery keeps going dead,bought 3 new,had new belts installed as per recall,alternator is good. still have to jump start when I have to use it.
    New Friend:
    Problem Solver:
  • 5 Answers
Sounds like something is causing a power drain. If you know how to use an amp meter it's not too hard to find it. Disconnect the positive terminal from the battery with the meter set on amp put one lead from the meter on the battery terminal the other to the cable you took off the battery so that the current goes through the meter if it shows a drain pull out one fuse at a time until no drain seen then just check what that fuse goes to.
Posted on Mar 28, 2015
Tried 3 new batterys,had alternator checked,had a new serpentine belt installed as per recall notice from Mitsubishi for 08 lancer,had certified techs from Mitsubishi dealer installed new belt car started...
If you know for sure the battery, alternator, and serpentine are OK. then (A) you might need more power to start than your battery can produce. This is not likely because the jump battery does the job. (B) are not really charging because of a bad connection at ground, battery cable, or fuse. You can test this with a volt meter. You might try checking the battery condition just after running by turning on the headlights and see what they do when you try to start. You can check it again a few hours later. (C) Something in the car is draining power. You can check this by (1) disconnecting the ground cable at the battery, (2) charging the battery, (3) connect a test lamp between the the battery cable and the battery. If the test lamp glows, some device is pulling power with the ignition off. Pull fuses one at a time until the test light goes out. (replace the fuses if the light stays on.) Then find the component on the fuse that is grounded and fix it. Look for simple stuff like a wire with bad insultion at one spot or maybe a bad cigar lighter.
Mar 30, 2015 | Mitsubishi Cars & Trucks
08 lancer battery keeps going dead tried 3 new batteries installed,had new belts installed as per recall,alternator checks out
Based upon what you have said, it would seem that you have something that is causing a continuous battery drain. Have you added any new electronics to the vehicle that may have accidentally been wired up to a constant hot source instead of one that is controlled by the ignition switch? Many enthusiasts accidentally install stereo amps directly to hot and find they never shut off, killing the battery. If you are skilled at electronic troubleshooting, you may be able to track down a wiring problem yourself. I will warn you that many repair shops will attempt to diagnose your problem, but few are trained to do it efficiently. If you decide to pay a pro to fix it, go to an Auto Electric specialist. They charge more per hour, but will take far fewer hours to locate and repair the problem than the corner mechanic.
Mar 28, 2015 | Mitsubishi Lancer 08 2008
My battery is going down over night and i bought a new battery and it still goes down over night.
Have your alternator checked, it may charge some but not enough to keep your battery charged. If it has an internal short (blown diode)it can discharge your battery.
Nov 30, 2013 | 2006 Pontiac Torrent
Battery keeps going dead. We jump it and goes dead in 5 min. the gauges quit working also.
You have a bad alternator. Get the alternator checked, the alternators in 98 cavalier require at least 13 to even start the car off of battery power. The alternator is what charges your car's battery while you are driving. if you have bad alt then your jumping the car is pointless cause it won't harge your battery at all it just kick starts the engine with power from the other vechile. If the alternator is showing at the very least more than 15 when its tested time for a new one. They should run about $90-110, it's an easy do it yourself installation to. Good Luck!!!
Mar 17, 2013 | 1998 Chevrolet Cavalier
I see on here where u have answered questions about ppl trying to start their durango and just get a clocking noise. Ok so here goes....my car for a while because my battery was almost dead and then dies...
If you have a new battery and it keeps going dead, then either you have a bad battery or the alternator is not charging properly. Altenator not charging could be either a bad alternator, loose belt, or bad wiring coming from alternator.
Dec 23, 2010 | Dodge Durango Cars & Trucks
My 2000 GMC Jimmy had brand new battery installed roughly a week ago. Attempted to run errands last evening and whole vehicle was dead: unable to use key fob to unlock doors, engine didn't even attempt to...
Does or did the check engine light ever come on durring all of this ? Or did the alternator light ever come on durring all of this? Jump starting another vehicle, damage to your battery I duoght it, damage to your Alternator and or other electrical componants highly possible if not connected properly.The new battery going dead again could cause all of the problems you have discribed for me. If I were you the first thing I would do is check the new battery and see if it has gon dead now. If so check to see if it is Frozen. If it is frozen you will half to replace it, because once a battery has frozen it will never hold a charge again.Once you have replaced the battery with a good known one (fully charged). Start engine and warm up to normal operating temperature and then disconnect the battery if the engine keeps running then the Alternator is fine . If the engine stalls then you need a new Alternator.A bad Alternator could have ben the problem from the start.I also live in a cold climate zone ( RedDeer, Alberta, Canada).Good Luck and have a good XMSS.
Dec 13, 2010 | 2000 GMC Jimmy
Dies after jump starting
If you have to jump because it has a dead battery, the car won't run with a dead battery. The jumper car gives it enough juice to start but that is it. Check your battery, check your alternator. Hope this helps.
Mar 14, 2010 | 1992 Geo Storm
98 dodge avenger es 6 cyl., won't start
Is you battery going dead? How old is the battery? After 4-5 years a battery is bad and needs to be replaced.
It sounds like you didn't replace the alternator?
Do you get a click when you try to start and it wont start?
Also check the grounds on the starter they could have corroded and this would cause an non-normal starting pattern. To chech these locate them, usually close to that starter and screwed into the frame of the vehicle. Unscrew them and take a wire brush and clean them very good making sure to expose bare metal. Do the same to the frame where it is screwed into.
Make sure to unhook you battery before doing anything!
Reply with the answer to the questions and we can go from there.
Good Luck,
Subikid90
Mar 04, 2010 | 1996 Dodge Avenger
Daughter's 1999 Jetta; smelled burnt rubber when leaving work last week. Car ran fine. Yesterday, started squealing (sounded like belt slipping) when started. Later in day, she turned car off and sat with...
It sounds like the alternator belt or the alternator is going bad. The squealing sound was probably the alternator belt. the alternator belt might need to get tightened or replaced or you may need a new alternator. The alternator keeps the battery charged. When the alternator goes bad the battery can not be recharged. You also should keep the power steering fluid up to par or the power steering will go bad on you.
May 18, 2009 | 1999 Volkswagen Jetta
'98 Lexus ES300 Won't Start--But Has New Battery!
If your is exhibiting the same signs as a dead battery it really sounds like your alternator is bad. If you are handy, you can remove the alternator and take it to an autoparts store like autozone and they will test it for you. This is not a hard job to do, usually 2 electrical connections, 3-5 mounting bolts and you have to pop the belt off. Just reverse it to install a new one. Good luck! - Nick
Nov 03, 2008 | 1998 Lexus ES 300
Mitsubishi Lancer 08 2008 Logo
125 people viewed this question
Top Mitsubishi Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Mitsubishi Car Audio and Video Expert? Answer questions, earn points and help others
