Question about Pool & Spa
The pump runs continuously at low speed.
Balboa liteleader control #54115. Checked that the low speed pump relay isn't stuck or fused. 12v to low speed relay coil.
  • 1,631 Answers
Are you sure... Continuously?
non stop?
maybe just a long time, and is off when you are not around?
continuously = 24-7
its possible your programmed filter cycle is set for 2 long cycles. ?
Posted on Mar 30, 2015
4 Suggested Answers
  • 77 Answers
SOURCE: I have a 2HP 230V AquaFlow pump model 06620390-2.
Check or substitute motor capacitor
Posted on Aug 18, 2009
  • 16 Answers
SOURCE: my 2 speed pool pums is only working on low speed.
could be the start capacitor or run capacitor on pump motor.
Posted on Aug 23, 2009
  • 366 Answers
SOURCE: I have a 2004 great lakes hot tub with a balboa
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Posted on Feb 09, 2010
Engine cranks but no start
Check the fuel pump. Fuel pump relay. Car security system.
Oct 27, 2015 | 2011 Kia Forte
Balboa VL700S control panel jets 1 not working
Your problem is going to be in the circuit board in the spa control box under the skirt.
You have a bad relay.
Rod
US Parts Center
Jun 25, 2013 | Pool & Spa
After jump starting 2006 Z4 BMW headlight low beams don't work checked fuses in glove compartment and under hood all seemed to be ok is there a relay, what do i do now
If the lights are switched then the switch controls a rely all lights are switched on bmw. Can use fog lights temporarily. Find rely test with continuity meter when on, disconnect lights first, then turn on lights switch, check for 12v at light bulb terms, if 12v then bulbs bad, if not relay is bad, test with continuity meter, rely should read 0 ohms when lights switched on, infinite open circuit when switched off. If lights work in manual switch pos then solar sensor bad.
Dec 05, 2012 | 2006 BMW Z4 Roadster
Hot tub keeps running all night keeping me awake. How do you shut it off? It's a Great Lakes.
If the system is the Jacuzzi 52221-05 system mentioned in the subject header, there could be a stuck relay causing the problem and you might need to get a spa technician out to assist you in repairing the problem. However...
If it is a Great Lakes system as mentioned in your message body, then there could be a programming issue allowing the filter cycle to run continuously. Provide a model number off of the Balboa control. Then we can provide you an instruction manual or reference card to assist you in resolving this problem. you can also search our online manuals at our website. You can find them online at:
BALBOA WATER GROUP INSTRUCTION MANUALS
Sep 18, 2011 | Jacuzzi Balboa R574 System for 1 2 Speed...
What is the difference between a Balboa VS500Z and a VS501Z
The Balboa VS500Z supports one two speed pump, an ozone, and 12v spa light and an optional circulation pump.
Whereas the VS501Z will support a two speed pump, a single speed pump or blower, an ozone, a 12v spa light and an optional circulation pump.
Basically the two are very similar except that the 501Z will support an additional one speed pump or blower.
The best suggestion if you are doing a replacement is to purchase one of the Value Pack Retrofit Kits available through Balboa. You basically get everything you need for the replacement, including the topside, cables, and overlay.
You can find everything you need to know about making the replacement on the following page:
BALBOA VALUE PACK VS RETROFIT KIT
Hope that helps!
Jul 12, 2011 | Balboa Instruments Duplex Digital Panel 2...
Heater bower won't blow
There is a blower motor relay,near the motor i think,check it.
Apr 12, 2010 | 1998 Ford Contour
Pool & Spa Logo
83 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
