Question about Craftsman Drills
Craftsman 19.2v drill. What is process remove the chuck. The back side of it has 17mm dual flat spot. I tried 17mm open end thin bike wrench but I cannot get the chuck to unscrew. I need it off in order to put a new one on.
  • 5 Answers
Hi Charles! The chuck is fixed to the spindle by a bolt (with Ph2 or hex head), you can find the bolt head if you look directly into the chuck (with its jaws completely opened). You'll just need to fix the chuck (with your hand most probably), and unscrew that fixing bolt (might be with left-hand thread! - don't use excessive moment, first try it gently both ways). After removing the bolt you'll just need to gently tap the bottom of the chuck - through a piece of wood - with a hammer, to remove the chuck from the spindle. Gently is the key word - in order not to damage the chuck and ball bearings/gear set of the drill.
Below are 2 reference links from Craftsman and Sears Parts catalogue - may help you as well.
Good luck! Craftsman C3 19 2 Volt Lithium Ion 3 8 in Drill Driver Kit Craftsman Drill Parts Repair Parts
Posted on Apr 16, 2015
stug_57u
  • 99 Answers
SOURCE: drill chuck removal
The screw should be left hand thread and the chuck is normal thread. The 'workshop' way to remove the chuck is to remove the screw (done). If the jaws are still working then clamp a sturdy allen key in it and whack it against a workbench to unscrew the chuck. If holding the drill in the normal position you would stand with the workbench to your left and whack it down on that. If the jaws aren't working then you can grip the body in a vice and use large pipe grips or stiltsons on the chuck. Also check to see if the chuck spindle will accept a thin spanner to hold it, as this is a slightly more caring way to brace the spindle. Then you can can hold the spanner in the vice and use the allen key in the chuck and unscrew it that way.
Posted on Oct 25, 2008
stug_57u
  • 99 Answers
SOURCE: How do I remove a keyless chuck from my Sears drill.
The chuck is screwed on with a normal thread, the screw in the centre (already removed) is left hand thread. Holding the drill with the open end of the chuck facing you, it should unscrew anti clockwise. It might take an impact to start it off. I normally put the gearbox to slow, set the cluth to drill and then holding the drill firmly, hit the allen key against the edge of my workbench. Bring the drill down like a hammer blow so the allen key hits the bench (which should be on your left). I find this more effective than holding the drill on the bench and hititng the allen key with a hammer as it allows for less drill movement at the point of impact.
Posted on Nov 16, 2008
  • 142 Answers
SOURCE: locked drill chuck
i have the same tool and have had the same problem
i use 2 large prs of channel locks(water pump pliers) to break the bond
Posted on Jul 06, 2009
  • 165 Answers
SOURCE: Craftsman 14.4 drill chuck stuck in open position
Look inside for centered screw and remove.
Posted on Feb 27, 2010
SOURCE: Broken Makita Drill 6408k chuck
If the chuck itself slips, you can tear down the outer layers (yes it is a bit brutal)
of the chuck until you reach the inner metal core. You can then try several things;
1 loosen it with a pipe wrench, provided you can get a grip on the axle of the chuck to counter the torque
2 Weld an allen key to the metal core of the chuck and use a firm rapid blow by a hammer to rotate it counterclockwise
3 Dismantle the final shaft with the chuck core, and set it in a vise with aluminium plates to protect it, while you turn the chuck with a wrench or pliers.
4.If there is no senter lock screw inside the bottom of the chuck it may be fitted with a thread locking compound. It will loosen easilier if heated with a heat gun or moderate gas heat.Only supply just enough heat to loosen it, or the hardening of the steel may be compromised.
Posted on Dec 02, 2010
I need to remove the jakobs chuck from my makita 2030 hammer drill
Open the chuck fully and remove the set screw inside it. The screw has left handed threads and is most likely lock-tited in so get a firm grip on it and turn it clockwise to remove it. The chuck is right threaded but put on very tight. The best way to losen it is to lock the short leg of a 1/2-inch allen wrench firmly in the chuck so you can hit the long leg with a hammer. If the spindle below the chuck has flat spots for a wrench, lock the wrench in a vice and put the spindle in it so you can hit the allen wrench hard enough to break the chuck free. When you put a chuck back on use a drop of lock-tite on the spindle and screw threads and turn them on as tight as you can.
Nov 06, 2012 | Drills
I want to know the steps needed to replace a 1/2" keyed chuck.on a Milwaukee 0234-6 Magnum Drill
they make a service fixture for that BUT if you can find a thin wall open end wrench that will fit behind the chuck on the hex of the spindle you can still do it. What you will need to do is remove the left hand chuck retaining screw, put the wrench or similar item over the hex and then put the chuck key in a hole that is about a 30 degree so that you can strike it counter clockwise to remove. That chuck is on tight and there no easy way to remove it like you can do on cordless items.
Jul 31, 2011 | Milwaukee 0234-6 1/2" Magnum Drill 0-850...
I HAVE A DEWALT 511 HAMMER DRILL AND I CAN'T REMOVE THE CHUCK. COULD PLEASE ADVISE ME ON WHAT TO DO.
Open the chuck fully and look inside, there should be a screw there that has to be removed to remove the chuck in view of the fact that it is a reversable drill and the chuck cannot be screwed off like a conventional inudirectional drill.
Jul 09, 2011 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
Cannot remove drill from chuck
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Oct 24, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How do I remove the chuck from the drill. I have removed the star screw and have tried to turn the chuck counter clockwise to remove the head.
Sep 22, 2010 | Bosch PS312A 12Volt Max 38Inch DrillDriver
Need to change chuck
When you buy a replacement chuck it will have detailed instructions- at least Jacob's brand chucks do. Basically there is a retaining screw inside the chuck that needs to come out first- it may be left-hand threads . Then you put the short end of a 1/4" or larger allen wrench in the chuck and close it tightly. Set the drill on a bench with the chuck off of the bench and strike the allen wrench with a mallet in a counterclockwise direction. Do this several times, then you'll be able to spin the chuck off by hand. Reverse the process to install the new chuck.
Apr 13, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
I have a DC900 dewalt drill and the chuck requires replacing is there an easy way to remove the chuck ?
Open the chuck as wide as it will go and then remove the machine screw from it,it's down inside the chuck.Now,put a 5/16 allen wrench in the chuck and tighten it.Hold the drill with the chuck away from you and hit the allen wrench with a hammer,with the wrench to your right and making the hit drive it downward.Spin it off with your fingers from here,hope this helps.
Jan 29, 2010 | Dewalt DC900KL Heavy - Duty 36 - Volt...
Need to change a keyless chuck
open jaws for large size bit.look in bottom and there will be a screw slot or phillips head screw or possibly an allen head screw.remove this,by possibly turning clockwise. and then chuck up a large allen wrench. try removing the chuck by tapping wrench with hammer. this may be threaded on counterclockwise.have to try both ways.
Aug 28, 2009 | Craftsman 19.2v 3/8"drill/driver W/ Work...
Cordless drill- chuck jammed.Model No. HP146F2B
b&d usualy thow away inthis range.still you can remove the chuck and fix or relace chuck unscrews anticlockwise hold shaft behind chuck with thin spanner or it may be the type with allen screw dwn the centre of chuck
Jul 25, 2009 | Black & Decker Pivot Plus Cordless...
Chuck on Bosch 1194 vsr drill is rusted... how to remove?
you are half right. The screw that you see is a chuck retaining screw (LH thread) to keep the chuck from loosening up when in reverse. What you need to do is if you have one remove it first and then find a bent handle allen wrench about the size of the chuck capacity, lock the shorter end in the jaws and then position the wrench at about a 30 deg angle and put the chuck on a block of wood or bench and take a hammer and hit it counter clockwise. If you have a wrench small enough to lock onto the spindle use it and brace it on the bench. If this tool has a high and low setting use the low and if clutch equipped the drill only. Let me know if you need more help
Jun 26, 2009 | Bosch 1194AVSR 1/2" Vsr Hammerdrill
Drills Logo
299 people viewed this question
Top Craftsman Drills Experts
Tim Venetis
Gary Nitowski
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
