Question about Casio Cameras
My casio exilim camera captures images and save it blurred, seems like the lens is affected pls what can I do
    Top Expert:
  • Casio Master
  • 6,702 Answers
No model? please make sure your lens is switched to auto focus (AF)
When the lens is smudged, please only clean it with fluid special for lenses. Never use normal glass cleaners, because lenses do have coatings that come of easy with normal house hold cleanres. If you already tried cleaning the lens that way, I think we have found what is wrong. Without the coating the lens can't give good pictures.
Posted on Mar 29, 2015
SOURCE: Casio Exilim EX1050 10.1 Megapixels
Remove the screws/case and with power on, slightly push the lens back
make sure you disable the play mode so it not turn on by itself if you accident touch the play mode
hope this help
Posted on Dec 14, 2007
SOURCE: Casio lens stuck
I noticed that the lens was sticking out on center. After pushing it a little, it clicked and then everything worked fine again. I hope that's what happens for your camera, too.
Posted on Feb 15, 2008
mcomijohns
  • 477 Answers
SOURCE: Casio Exilim EX-Z60 - severe overexposure - entire image is white
Yes the place sold you a camera with a bad CCD. They should replace it for free.
Posted on Jun 02, 2008
SOURCE: Casio exilim lens problem
this is a weird problem but i found out why it sometimes happens. You have some how broken a cog inside the camera and therefore it doesnot work. I opened my camera and the cog came out and shot me in the face and the cog i half broken...
Posted on Jan 21, 2009
  • 104 Answers
SOURCE: Casio Exilim Z40 - Lens Error Message
You can try to "fix" this problem by holding down the shutter release button as soon as the camera power up.If this does not work you will need to replace the lens assembly. This should only be done by a qualified tech.
This is usually caused by one of two circumstances. (1) The user dropped the camera while the lens was extended causing a mechanical failure. (2) The lens attempts to extend while in a pouch or pocket without the user's knowledge. This usually happens when the user is carrying the camera with the battery in. When/if the REC button or power button is pressed accidentally, the lens will attempt to extend but can't. This causes the servo motors to "smoke".
Posted on Apr 25, 2009
Lens blurred
To come closer to the colprit, if you shoot a picture and you put it on a PC (tablet) does the picture still look blurred?
If it does, the most likely is the image sensor or the lens are broke. If the picture is ok on the PC, only the display is bad.
Are you sure you don't see anything on the lens? Is perhaps a little dent on the outside visable? That could be caused by a fall with the lens outside the body.
Nov 06, 2013 | Casio EXILIM EX-Z400 Digital Camera
Lines are coming on the images and little blurred images..pls how to repair this?
just go and purchase the new lanes for this model and replace the lanes and i am sure ur problem will sort out
Apr 12, 2010 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Blurred Taking Pictures, But not all the time???
lens misallignment due to worn out gears on focus adjustment (zoom in/out), needs repair but could be expensive and not reliable enough.
May 20, 2009 | Casio Exilim EXZ75 Digital Camera
Cannoot see through the lens ??
CCD sensor is faulty ( see enclosed pic) and so no image is generated in capture mode. See if the agents will repair this fault ( as this is manufactiring fault ) free of charge ; something Sony, Canon and Nikon do .7ea4a6c.jpg
Nov 05, 2008 | Casio Exilim EX-Z57 Digital Camera
Casio EXILIM camera lens will not extend fully!!!
Try plugging the PC interface cord into the external connector. No need to hook it up to your computer, just plug it in and out a few times. Then try to power up the camera.
Good luck.
Zductive
Jun 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Blur image
I am having a problem with blury pictures. Every one I take is blury and it also seems the flash wont go off. Now the pictures are blury even in the daytime. Anyone that can help me please do!!!!
Mar 26, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
It's the focus lens gears. The often times get knocked out of alignment by an impact, or debris gets in there. This can be fixed, but Casio won't help. Hint...google my username. ;)
Jan 21, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens assembly
"Lens Error" requires to be sent into repairs.
Sep 12, 2006 | Casio Exilim EX-Z40 Digital Camera
Why are my flash images out of focus?
This could be due to any of the following reasons. 1) A dirty lens can cause whitish blurring of an image. 2) Light from the flash reflected back from the subject can cause blurring and a feeling that the image is out of focus. 3) In total darkness when AF measurements are impossible, the camera focuses for about 2 meters. Subjects that are closer or further will be out of focus. The Auto Focus Frame is red when AF measurements are impossible. In this case, use manual focus (MF).
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
Cameras Logo
60 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
