Question about Pool & Spa
The pump shorts out when heater is put on - Pool & Spa
  • 1,631 Answers
Electric spa control?
what do you mean pump shorts out? Are you saying a breaker trips or a GFCI trips?
if so, it has nothing to do with the pump, if it's already running. But once the heater engages and the breaker trips, then you have about heater element.
Posted on Mar 30, 2015
Tip
Scania Fault Codes
000 00 No Fault
01 001 less than the rated voltage - heater works
02 002 higher than the rated voltage - heater works
004 03 Short circuit fan (D2I)
005 05 Short-circuiting the wires from alarm (D2I)
009 09 Heater off system TRS (D2I / D9W)
010 0A higher than the nominal voltage (heater stopped)
011 0B voltage less than the nominal (heater stopped)
012 0C overheat - fuel pump is turned off
013 0D temperature sensor recorded a high temperature
014 0E big difference values of t. Dutch. overheating and Dutch. regulation. t (D3W / D9W)
015 0F heater overheated many times - the heater is turned off (D2I / D9W)
017 11 Reusable overheating (t exceeds the second threshold) (D3W)
020 14 Candle / rod defective bulbs
021 15 Short candles / kernel bulbs
022 16 switch faulty lights / lamps kernel (D2W)
023 17 Internal defect relay control R2 candle / bar bulbs
024 18 Short-circuit switch controller candle / bar bulbs
025 19 Short-circuit diagnostic socket
029 1D fan air gap 5 does not operate R3
030 1E air fan does not work in all positions (R3-D3W)
031 1F air fan does not work in all positions (R3-D3W)
032 20 Air fan does not work in all positions (R3-D3W)
033 21 Air fan does not work in all positions (R4-D2I / D9W)
034 22 No contact with solenoid valve system COOL. (D2W / D9W)
035 23 No contact with the relay average performance
036 24 Short-circuit relay average performance
037 25 Do not rotate water pump (D2W / D9W)
038 26 No contact with the fan relay cab heating (D2W / D9W)
039 27 Short cab heating fan relay (D2W / D9W)
040 28 Short electromagnetic. COOLING valve system. (D2W / D9W)
042 2A Short circuit water pump (D9W)
043 2B Short cable from the computer to the heater fuel pump (D9W)
047 2F Short circuit of the fuel pump
048 30 No contact with the fuel pump
050 32 Heater run many times but have not worked (relay R3)
051 33 Flames emerged immediately after pressing the start button heater
052 34 No start (restart purge)
053 35 Stop flame during startup
36 054 Stop flame position max. productivity
055 37 Stop the flame in a position average performance
056 38 Stop the flame in the position of poor performance
057 39 Flame sensor short circuit (photoresist)
058 3A heater is turned off, but the flame in the combustion chamber (D2W)
059 3B Water temperature rising too quickly (D9W)
060 3C No contact with the sensor temperature control
061 3D sensor short circuit temperature control
062 3E No contact with the potentiometer (D2H / D2I)
3F 063 Short potentiometer (D2H / D2I)
064 40 No contact with flame sensor
065 41 Flame sensor short circuit
071 47 No contact with the sensor overheating (D3W / D9W)
072 48 Short-circuit overheating sensor (D3W / D9W)
073 49 Overheating sensor recorded the fastest increase in temperature (D9W)
090 5A Spontaneous error
091 5B high surge (high-voltage wires, CB-radio, etc.)
092 5C Faulty heater control unit - fault ROM
093 5D Faulty heater control unit - faulty RAM
094 5E Faulty heater control unit - fault EEPROM
096 60 Temperature sensor faulty heater ECU (D2I)
097 61 Faulty heater ECU (D2I / D2W / D9W)
255 FF cleared but faulty memory EEPROM
source
http://truckmanual.weebly.com/scania-fault-codes.html
on Dec 20, 2016 | Cars & Trucks
Tip
Torpedo Heater Pump Pressure Adjustment
The most critical factor in getting your kerosene torpedo heater to run is the air pressure that the pump puts out. This air pressure is what pulls the fuel out of the bottom of the heater. It is very important that this is set correctly.
You will need a low pressure gauge (0-15 PSI) and a screw driver to make this adjustment.
On the back of your heater there will be a short and a long protrusion. Pull the plug out of the short one and insert the pressure gauge. The longer one is the adjuster screw. This is a very simple device that has a ball a spring and a set screw. Turn in on this screw just places more tension on the ball to allow less air to escape and raise the pressure inside the heater.
If you cannot get a high enough pressure then there is a leak or the pump is worn too much. To check for a leak use soapy water and check all the parts. The black plastic back can crack or the cork of the pump gasket can leak. Sometimes the rotor and vanes will go bad but not likely.
So, insert the pressure gauge in the short port, start the motor and check reading, you will only have a short time to do this if your heater is not firing. Turn the longer screw in or clockwise to raise the pressure and out CCW to decrease the pressure. Adjust to factory specs. And you will be getting warmed up.
http://www.fixya.com/support/r3818299-reddy_heater_troubleshooting_torpedo
http://www.fixya.com/support/r3903547-torpedo_heater_kerosene_heater_portable
on Jan 06, 2010 | Heating & Cooling
What is a f12 fault
F01 - Short circuit motor triac*
F02 - Motor jammed or fan blocked*
F03 - Front thermistor open/short circuit*
F04 - No pump piloting*
F05 - No feedback from the pump*
F08 - Static heater relay with contact welded closed*
F09 - Eeprom is not programmed or not functioning*
F10 - Common of heater open or one shot open*
F11 - No pump connection*
F12 - Communication error between board*
F13 - Rear thermistor open/short circuit*
F15 - Dynamic heater relay with contact welded closed*
F17 - Master relay welded closed* - See more at: http://www.hotpointservice.ie/help-and-advice/error-codes/#sthash.nR8Jb1cP.dpuf
Dec 12, 2014 | Hotpoint Dryers
Water switch open , heater heats up for short period and cuts out
ensure pump is running at full prime. clean the filter out as well. disconnect both connections from pressure switch in raypack heater. check continuity. if switch opens at any point and you have no flow restrictions then replace the pressure switch
Mar 11, 2014 | Solar Rheem Gas Fired Pool & Spa Heater...
Lay z spa heater pump
need more info does whole thing trip off sounds like shorted heater element if you are able to disconnect heater leads and thing stays on bad heater be careful its either 110 volts or 220 volts if your not familiar with this call a professional
Jan 25, 2014 | Pool & Spa
New heater was left dry for 4 weeks while spa pump was replaced. turned back on with error code Fault-shorted H20 Sensor. is it truly in need of replacement or can it be cleaned after sitting and rusting?
You can put an ohm meter on the two wires of the temp sensor and see how much resistance you get. I can't find the chart right now but you should read about 15,000 ohms at a water temp of 88 degrees. Resistance drops as temp rises. A "short" will give you the same result as just holding the two test leads together.
Having the heater idle for a few weeks should not have affected anything. The temp sensor isn't too hard to change yourself if needed.
Sep 15, 2013 | Jandy Lxi Heater Temperature Sensor...
My Jandy Laars LX 400,000 BTU heater flashes "low pressure". I removed the water pressure switch in the heater and turned on the pump and water flows nicely out of the copper tube for the water pressure...
Once you try to ignite three times in succession, and the heater doesn't sense the presence of flame, the heater goes into "lockout" mode and must be reset to fire. This can be done by pressing and releasing the mode button so that the heater is turned off then returned to the desired mode. So if you were going to "jumper" the pressure switch, (connecting two wires together) make sure you do the reset also. Make sure you don't operate like this, if your pump quit, you could have a melt down. Also If you have anything connected to the fireman switch, it is in series with the pressure switch,and woud display the same thing. There is a terminal with two white wires, if there is a jumper there, then nothing conected, but if there is something connected, make sure it is closed. Also be sure your code was for Water pressure and not air pressure switch. You can download manuals at: www.jandy.com
Jul 26, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I have a brand new Raypak heater. Pump is on
Umitherm governor (looks like an automotive thermostat) is bad or bypass valve defective. Both of these are in the header. You should have a manual bypass valve on the pool plumbing to regulate the flow in the heater. Try increasing or decreasing the water flow through the heater first.
Jun 18, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
110,000 heater will run for 15 seconds,will not fire
The rotor in the pump assembly may have broken or cracked and is binding the rotation of the motor. The pump assembly can be removed to inspect, clean and replace any parts that are damaged. The manual will step you through this procedure and can be done in a short period of time. Your local hardware store may be the replacement parts on the shelve.
Mar 28, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Pool & Spa Logo
85 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
