Question about Sceptre Televison & Video
I bought a repacement remote for tv. i put batteries in and does not work. just dead.
  • Sceptre Master
  • 2,963 Answers
Or possible it really a dud, if so take back to the store.
Posted on Mar 28, 2015
    Top Expert:
  • Sceptre Master
  • 44,232 Answers
Check the placement of batteries they could be backward .then the remote has to be programmed to your set
Testimonial: "thanks, must have been batt - ok now"
  • j flem
    j flem Mar 28, 2015
    also, this was actual scepture remote I ordered online -- mso guess didn"t need to be reprogrammed.
The remote does not work at all. New batteries inserted but will not work.
Check the battery + - compartment for moisture or rust connections and used some WD40 chemical spray in a rag and clean it + - battery connections.Wait like 10 mins put battery back in the remote should work again.If not,still have the same problems.The tv remote comtrol CPU chip it is shorted and dead.Or try website Remotes.com to buy a replacement new original remote.
Aug 07, 2011 | Philips DVP5990 DVD Player
T.v. does not respond to remote control, but does work maually from side buttons
Turn tv on manually.Test the remote control all functions are dead or some functions work other don't?Tries take the remote control parts and clean the inner rubbers buttons between the rubbers insulater and the remote circuitries board and the battery connections + - connections with some rubbing alchahol.Then wait awhile like 20 mins and putting it back together again and putting in new battery in the remote,it might work again.If getting the same result than the remote CPU chip is probally dead,remote control devices are very depended on it CPU chip.Try website like Remotes.com to buy an original remote for the replacement.
Mar 24, 2011 | Vizio 42 in. LCD TV
My remote does not work, I have a 50' maxent plasma. Any ideas?
Take the batteries out of the remote like wait 20 mins and take a rag with some WD40 in it clean the - + batteries compartment connections.Wait about 10 mins put in brand new batteries.The remote should work now,if still have the same result.The remote CPU chip is dead.Remotes devices heavyly depended on it CPU chip,it probally shorted and dead.Try website like Remotes.com to buy an original or close to the original remote.
Dec 21, 2010 | Maxent MX-50HPT51 50 in. Plasma TV
Cannot turn tv on or off remotely. Tv works fine after turning on manually.
Take the remote control aparts,take some Q tips dips it in with some rubbing alchahol.Clean the remote control PCB board,putting it back together again,wait like 20 mins.Put in new batteries.The remote now should work again.If not it garbage,because it CPU chip is dead.Try website like Remotes.com to buy an exact remote to ur original remote.
Nov 18, 2010 | Quasar VV2007 20 in. Combo
My Scott Remote Control #KC01-B1 one night just would not connect to the sensor in my tv. I thought my batteries were low and changed them. The remote would still not work. I went to a Radio Shack...
Before you throw any more money at this problem, have you considered that the problem might be with the Infra-red (IR) receiver in the TV?
Also, did you programme the correct codes for your Scott TV into the universal remote/s? If you can let me know the model number/s of the universal remote/s - and you still have them - I can probably verify the codes and the programming instructions.
Hope this helps.
Oct 16, 2010 | Scott LCT37SHA TV
I have a Grundig GU22DVD TV/DVD combo and the remote has stopped working even with new batteries. We,ve just moved it to a new house and need to tune in the digital channels without the remote. Is this...
Take out the battery an hour,put in back in,have the same problems.The remote is dead.Try website like Remotes.com to buy an exact remote.Yes,u can use the manual control buttons on right side of the tv,but a little hard.
Sep 06, 2010 | Grundig GU19WDT 19 in. LCD TV
LCD TV Remote quit working
First thing, turn off the TV and unplug it for about 2-3 minutes. Remove also the batteries on your remote. Re-install the batteries on the remote and plug in your TV. Power on your TV using the remote. No luck?
Norcent may not be supported by a universal remote. If you just bought your unit new (maybe Best Buy who carries this brand) you are still covered by its warranty. Below are ways you can reach Norcent.
http://www.norcent.net/main/contact.asp
909) 305-2121
support@norcent.net
Mar 24, 2008 | Norcent Technologies LT-2722 27 in. LCD...
Toshiba rear projection tv
Will the tv power up with the power button on the TV control panel? If so its your remote sensor inside the TV. Let me know your model number.
Jan 21, 2008 | Televison & Video
Remote control code needed
Zenith 10017, 10463, 10178, 10016, 10092, 11265, 11145
Dec 09, 2007 | Televison & Video
TV doesn't turn on with remote
The infrared receiver on the TV is probably dead. If you're handy or know someone that is handy you could pull the TV apart and get the part number to order a new one and try replacing it to see if your remote starts to magically work again.
Jul 12, 2007 | RCA F25281 TV
Televison & Video Logo
44 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
