Question about John Deere 25 Gal. Mounted Sprayer X300 Series Tractors (John Deere)
Mower doesn't want to turn or go slow up hill after a while
Clunking sound when the lawn mower is trying to slow itself down, especially going down hill.
when your mower is on an incline the oil in the crankcase flows to either side depending the angle, I would recommend checking oil levels, clunking sounds are usually metal on metal, also never mow on an incline without thinking about mower damage. skip hills if at all possible., check fluid levels, check spark plug for gummed up residue , check gas line filter for water.
Apr 28, 2016 | Troy Garden
Can anyone tell me what is wrong with my mower?
it may very well be ready to blow up
you need a two cycle machine for hills, 4 cycle mowers are dumed
it slows on hills and stops because the crankshaft, camshaft, wrist pin and piston are not getting lubricated properly and just about to seize up
Mar 29, 2015 | Cars & Trucks
When driving along a , hill to right, mower holds to desired fwd motion. When mowing with same hill on left mower cits down hill and unable to stop till bottom. Tends to speed up too. Id there an...
Sounds scary! How steep is the hill?
Could you jack up the back end of the mower and check both wheels are driving? Maybe get it running slowly and get someone to carefully try and stop each wheel from turning with some sort of friction, eg a broom. If just the left wheel is driving you could get similar symptoms to what you describe. Some mowers have a key in the axle to wheel joint - if this is the problem then maybe yours is shorn.
May 25, 2014 | Garden
X520 jd mower trouble
Sounds like a problem with the governor. Start it up. Don't engage the blades. Drive to a hill. Idle all the way down. Try driving up the hill. The motor should pick up when it slows while pulling up the hill. If it doesn't, the governor isn't working right.
Jul 16, 2013 | Garden
Craftsman GT6000 54" stalls while mowing
Sounds like you have dulled the blades with your aggressive hill cutting
Aug 12, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
Mower doesn't cut going downhill
Sounds like a loose belt check the tension spring if they ok check and see if belt is strectched
Dec 19, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Ride on mower drive problem
sounds like a belt to me not tight enough against the pullys
Nov 09, 2009 | Mtd Gold 42" Zero-Turn Mower -
John Deere 25 Gal. Mounted Sprayer X300 Series Tractors (John Deere) Logo
221 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
