Washing machine just started making noise , and drum doesn't move...last wash left water in it.
  • Washing Mach... Master
  • 5,323 Answers
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuity
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Posted on Apr 20, 2015
  • 236 Answers
SOURCE: Terrible scraping noise from drum,what is it?
more likely there is a bra wire caught between the inner drum and outer tub, possibly wrapping itself around the element in the bottom.
Posted on Jun 01, 2007
  • 121 Answers
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Posted on Mar 03, 2008
  • 101 Answers
SOURCE: zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Posted on Apr 23, 2008
  • 850 Answers
SOURCE: The drum is stuck - it will not move
overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
Posted on Jul 28, 2009
  • 25 Answers
SOURCE: Indesit WIXL 143 washing machine noise
there maybe a coin or something stuck between the two drums, when the machine spins fast it lifts the item up, unplug the appliance and remove the botton drum hose to see if you can get it out.
Posted on Apr 07, 2010
Washer does not spin. Makes noise but drum doesn’t move
replace the rubber drive belt, unplug the machine remove the back panel to reach it as they do get worn and will wash but as the load sits at the bottom of the drum in spin mode the drum becomes heavier when the washing is sitting in the bottom its harder to start the rotation eric
Jan 18, 2018 | Washing Machines
Why won't it agitate or move drum?
Screeching noise is typical to drum's broken bearing issue.
See some infor about issue:
How to Diagnose Drum Problems in Washing Machine
How to change drum bearings on washing machine
How to Change the Bearings in LG Washing Machine
How to replace washing machine bearings on Bosch Neff Siemens and some...
Some more video there... explore
Now, if you don't find it so easy to replace those bearings or you are not sure if this is your problem, call a repair service
Aug 18, 2015 | Washing Machines
How do I drain the water out of the machine to prepare it for moving?
Is it a washing machine or a dryer?
Dryers are usually not heavy from water.
If it is a condenser type of dryer the water collector can be removed.
If the washing machine has completely finished its last wash, there should not be much water left.
Washing machines are usually heavy because they have a concrete stabilizer block mounted on top of the drum cage.
May 11, 2014 | Dryers
The drum isn't moving....
possible drive belt is broken if so it should be fairly inexpensive to get it replaced
Oct 02, 2012 | Hotpoint Washing Machines
Washing Machine making a loud whirring noise when water is filling and when the machine is spinning out
Check the motor bearings If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer. Check for Obstructions Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket. Check for Grease Spatter A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing. Check the Drum for Irregularities Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Aug 06, 2012 | Washing Machines
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
Hi i have a whirlpool WFS1072AW Front loader 7.5 kg we load the washer as normal press start and then this horible noise comes from the back no water goes in just the noise like gears grinding
Hello Steve.
First off is this a new washer?
If so front load washes ship with retaining plugs / pins in the back. They do this to stablize the drum in shipping so it doesn't get damaged. Check the back and see if this is the case. There should be 4 or so to remove. Also don't throw these out, if you ever need to move you will need them to make sure the washer doesn't get damaged.
Hope this helps.
Good luck
May 02, 2011 | Washing Machines
Noisy drum bearing also play on drum
Apr 30, 2011 | Washing Machines
When dishwaser is running a surginge sound is heard.hear surge then water in tub surge then water Repeats non stop.almost sounds like pump is on and off.
Although a noisy washing machine is not typically a sign that something is broken, it definitely can be annoying. Usually the noise from a washing machine can be fixed fairly easily, but a few different fixes may need to be tried before it can be determined what the true culprit of the noise was.
Instructions And Material You Need
  • Flashlight,Screwdriver,Drive belt
  1. Check the drum bearings if the washing machine is making a rumbling noise. The noise may possibly stem from water getting into the bearings. Take the belt off and spin the drum by hand. If there is a rumble, remove the bearings and replace them with new ones.
  2. Check the spider at the back of the drum. The spider is the three-armed device that holds the drum in place. If there is one loud noise on each revolution of the drum, there is a good chance the spider has partially become loose. Tighten the bolts on the spider to silence the noise it causes.
  3. Check for coins. If the noise the washing machine makes sounds like metal on metal, there is a good chance that some change has slipped from a pocket and is now in the dryer. Take a flashlight and look in the drum for coins, paper clips, and other small items.
  4. Adjust the legs. Many washing machines make more noise than they should because they have not been properly balanced. Re-adjust the legs to make sure that they are all even. This will keep the washing machine from moving and will ensure that the noise it creates while it moves will go away.
  5. Replace the drive belt. Often a high-pitched squeaky noise can come from a drive belt that has been worn down. Simply replacing the old belt with a new one will fix this problem.
Good luck and thanks for using fixya.
Dec 24, 2010 | KitchenAid KUDC03FVSS 23 in Builtin...
Hotpoint bwm129 making huming noise
Sounds like the rinse water can't come. Maybe the solenoid for cold water got stuck or a water filter needs cleaning? If the humming is louder, perhaps the drum motor (or drum) needs a little care or cleaning.
If all else fails, download the user manual and check the trouble checklist index. (Or; try learning your kenpo succession move sparring against laundry to clean it.)
Apr 14, 2008 | Hotpoint BWM12 Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
