Question about Jaguar 2001 XJ8 Base
I pressed valet switch and now I can not open trunk,not with switch,key fob or key !
  • Harold Goodman
    Harold Goodman Aug 12, 2016
    I used my in the drivers door and unlocked the gas cap, and trunk lid. I'm not sure but I also used the Driver's door lock (mechanical one) on the door along with using the key.
    Top Expert:
  • Jaguar Master
  • 47,775 Answers
Press it again should cancel
Posted on Mar 28, 2015
What options do I have in gaining access to the trunk of my 2004 jaguar xj8 that has gone into valet lockout
all back seats are either screwed down or hooked in. you need to use a little muscle and lift up your back seat to see which is which. there is no other way to gain entry to your trunk.Trust me Ive locked my keys in my trunk too. Now i have a hidden spare to my door and trunk. GOOD LUCK
Aug 15, 2014 | 2004 Jaguar XJ
Trunk won't open
Lower the back seat and crawl into the trunk and see what the latch is doing when you activate the key fob. the trunk lid will have to be open to enable any repairs. Also an emergency release cable is probably visible (yellow handle) inside the trunk and will Open the trunk lid.
Mar 10, 2017 | 2007 Toyota Camry
Crimestopper SP501 car alarm/remote starter will not respond. The 2 way one doesn't work, the sidekick does.
You need to program your crimestopper sp-501 key fobs, you need to program both the 2-way and the 1-way key fobs, during the same key fob program session. First find your valet button/switch, when you have found it, turn your ignition on and press the valet button four times, if you have a toggle type switch for a valet switch, toggle it up and down four times, when its in remote key fob program mode, it will honk your horn 4-times followed by 4-parking light flashes. Once your have done this press the lock button on the 2-way key fob, horn will honk and the 2-way will sing a little song to confirm programed, then press the lock button on the 1-way key fob the horn honk will be your confirm programed. turn ignition off this will exit you from program mode. then shut all doors and test key fobs for operation functions....hope this helps you out
Dec 03, 2011 | 2006 Hyundai Sonata
Nissan sentra 2006 My trunk wont open && I spent 2 1/2 hrs trying to break in from the back seats. trying to reach the seat release but cant. The key or remote wont open it. The car latch wont open...
does the key turn the trunk lock?if not theres one issue right there.the other may be that the valet lever on trunk latch assy. may have inadvertantly been engaged if deck lid was slammed closed.the release solenoid will make noise when activated by fob or lever in car but because of valet being engaged cannot release latch.does key unlock glovebox?if not this may also be a valet key cut.contact nissan dealer to cut regular key.ive seen the slamming the deck lid scenario a million times as the valet lever takes hardly any effort to engage.good luck and let me know how you make out.
Feb 07, 2011 | 2006 Nissan Sentra
2005 Nissan Maxima SL, trunk will not open when I hit the release button, switched on and off the valet switch, nothing happens.
does it work when you press release on key fob?if so remove the glove box and make sure someone performing work previously in that area didnt foget to plug it in.
Jan 31, 2011 | 2004 Nissan Maxima
How do i disable valet mode om a 98 jaguar vanden plas?
Try inserting the key into the drivers door lock and try centrally locking and unlocking all the doors a few times. If this does not reset the valet function try using the key in the drivers door lock and pressing the fob at the same time as locking and unlocking the doors. Even with valet mode engaged you should be able to access the trunk by physically inserting the key into the trunk lock.
Oct 06, 2010 | 2006 Jaguar XJ8
On a 2001 ford focus zx3 the keyless trunk entry doesn't work
i honestly am guessing,can you turn key to the left from vertical or right from vertical,if so one (left or right)is to lock trunk so you can give your keys to valet parkers....
May 22, 2010 | 2001 Ford Focus
Trunk will not open with key 1999 vw jetta
is it the valet key or the key fob? valet keys will not open glove box or trunk
Apr 05, 2010 | 1999 Volkswagen Jetta
Trunk does not open with button inside car. Does open with key remote. Is there a bad fuse somewhere and if so which one?
Your Valet cancel switch is set.
Open your glovebox and you will see a pushbutton on the the left side, if memory serves. When this button is set, the power button will be disabled, but the key fob button will still work.
This is for when you Valet your car, you push the cancel button in the glovebox, lock the glovebox, then give the Valet your Valet key, which will not open the trunk or the glovebox. Voila, no Valet rummaging through your trunk :)
Often full gloveboxes will be the cause of the button getting pushed accidentally.
Sep 26, 2009 | 2005 Lexus ES330
Jaguar 2001 XJ8 Base Logo
57 people viewed this question
Top Jaguar Heating & Cooling Experts
Lawrence Oravetz
michael vanier
NOEL
NOEL
Are you a Jaguar Heating and Cooling Expert? Answer questions, earn points and help others
