Question about LG LRE3083ST Stainless Steel 30" Electric Range 6.3 Cu Ft
The temperature in the oven is way off
I put a thermometer in it to check the temp because nothing bakes good and the temperature is way lower than it is set at
    Top Expert:
  • LG Master
  • 44,428 Answers
Then I would think the thermostat needs replaced or adjusted by a service man
Posted on Mar 28, 2015
I have a Jenn Air JJW9830DDP double oven electric, and the temperature in the oven is about 100' less than what it reads on the display. I tested the temp sensor and it ready 1073 ohms. Any s
Well, your temp sensors can still be bad. If not, there's always a new control board you buy!
However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage.
The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps.
What type of thermometer are you using to check your oven temperatures with?
If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray.
You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings.
It's the only way to be as close as possible with a digital probe.
If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel.
To adjust the oven temperature:
1 - Press Setup pad.
2 - Select the down arrow to scroll to the next screen.
3 - Select Temp Adjust using the Quickset pads.
4 - Select upper or lower oven (select models).
-"Set temperature offset using the Upper Set Knob" is displayed.
5 - Enter the desired temperature change using the Set knob.
The temperature can be increased or decreased up to 35 degrees.
The temp. change is displayed at the top of the window.
6 - Press the Set knob to accept the change.
Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
Oct 24, 2014 | Jenn-Air JJW9830D Electric Double Oven
General Electric oven how to reset thermostat
First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
Aug 08, 2014 | GE Profile JTP18 Electric Single Oven
My Maytag convection oven has the heating elements on the top. It doesn't matter if I use convection or not, metal, nonstick, or stone pans, or lower the temperature or cooking time, it doesn't cook/bake...
Stick a thermometer inside the oven. Compare the them inside the oven to the temp you see on the control panel; are they the same?
You must do this first. You will note a disrepancy. If the oven temp and yours do not match, that you have solved the problem.
Your oven sensor or thermostat might be at fault.
Oct 20, 2013 | Maytag MGR5770 Gas Kitchen Range
Think oven getting too hot and my cakes sag in middle
Get a cheap oven thermometer at your grocery store and check the temp before you put a cake in. Regardless of the kind of oven, this is the best way to be sure your temperature is correct before baking. I use one every time I bake, and I never have issues due to incorrect temp. I might have issues due to OTHER screw ups on my part, but it's not because the temp is wrong. You can buy an oven thermometer for a few dollars.
Aug 26, 2011 | Neff B1421 Electric Single Oven
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
Whirlpool Stove oven temperature not accurate
This unit has a calibration function which can compensate for temperature errors of +/-30 deg F. Hold the BAKE button for 4 seconds to enter this mode. Use the Temp UP/DN buttons to adjust the temperature offset. Push START to enter the new offset.
Also, the typical manual oven thermometers are notoriously inaccurate.
If this doesn't solve your problem, next items may be the temperature sensor or control board. If it is the control board we may be able to repair it for you at www.fixyourboard.com.
Jul 13, 2009 | Kitchen Ranges
Stoves 900DFa oven overcooking food
Sounds like the temperature control is bad. If it's digital you'll probably have to replace the circuit board. if it's a control knob, it's the mechanism behind the knob.
Jul 02, 2017 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Preheating
hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
May 12, 2008 | Ovens
Oven Temperture adjustment
On my Epicure, you are supposed to press the bake selector pad then press the + button to set the temperature to 500 degrees or higher.  Then hold the bake button for 5 seconds.  The temp display is replaced by 00.  Release the bake pad and use the - or+ buttons to adjust the temperature in 5 degree increments.  When finished push cancel (or just do nothing).  Good luck.  I tried this and my oven kind of went haywire.  It decreased the temp by much more than the 10 degrees I had set it too.  May be something else wrong with my oven though?
Nov 18, 2007 | Dacor Epicure ERD36 Dual Fuel (Electric...
LG LRE3083ST Stainless Steel 30" Electric Range 6.3 Cu Ft Logo
89 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
