Question about Campbell Hausfeld PW1835YLRB 1,800 PSI Electric Pressure Washer with Hose Reel
What kind of oil should I put inside the water pump of a Campbell Hausfeld pressure washer?
4 Suggested Answers
  • 583 Answers
SOURCE: Type of oil for pressure washer pump.
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
Posted on Sep 05, 2009
  • 420 Answers
SOURCE: Gun
Replace the wand (Gun) The valve is not repairable.
Posted on Jun 16, 2010
SOURCE: What kind of oil do
The pump uses SAE20 or SAE 30 non-detergent motor oil that fills up about half way
The engine uses 10-W30 motor oil that comes a bit more than half-way up dip stick.
Do not turn washer on its side or upside down to drain oil, or oil will run into carburetor.
If you have problems starting:
read:
http://www.fixya.com/support/t6504468-craftsman_2700_psi_pressure_washer
Posted on Nov 09, 2010
Need to see a diagram of a campbell hausfeld clean power 37 unloader valve
Most all of the manuals for campbell hausfeld tools are found at www.chpower.com , just look for your model number. Also , campbell hausfeld does not make all their pressure washer pumps. Yours may be another brand. To find who makes yours look on ebay. Make search for {pressure washer pump only} and look for one that matches yours. Then look for that breakdown. Good lu ck.
Oct 12, 2017 | Campbell Hausfeld Air Tools & Compressors
Oil leak under machine, how do you tell if pump needs more oil
Oil is leaking from the engine. Pump does not have oil in it.
Sep 01, 2016 | Campbell Hausfeld 2500 Psi, 2.4 Gpm,...
Does a 2/3 HP .40GPM Campbell Hausfeld Airless Paint Sprayer require any kind of oil if so what kind and how much
airless sprayers have a pump that pumps the paint through a jet at pressure . there is no oil and it is vital that when finished that the pump be spotless after cleaning
Nov 12, 2015 | Campbell Hausfeld Air Tools & Compressors
I have a 3000 psi campbell hausfeld gas pressure washer and it has no pressue how can i fix it
Small stream sounds like your pump is not working at all - you are getting house pressure only. First check the intake fitting where you attach the hose for debris that may be clogging the water flow. Same for the pressure hose and quick connect fittings. Remove the tip from the wand and see how much flow you get. If it's still only a small amount, with the motor running, you probably have a bad pump. This can be caused by bad seals inside the pump, or by running the motor without maintaining water supply to the pump, which can melt the seals or even seize the pump if allowed for too long. Repairing the pump is typically more work and expense than replacing it, assuming you can locate a replacement pump.
Aug 03, 2014 | Garden
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
What kind of oil do you use in a Campbell Hausfeld pressure washer pump? We are using my dads and we dont have an owners manual thanks
read:
Nov 08, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
Sep 04, 2009 | Campbell Hausfeld PW2102 Gas Pressure...
Do you have to use oil in the pump and if so type,how often.
water pumps doesn't require oil in the pump; but your engine does require. if the water pump is of "self priming" type, fill the pump casing with water before starting the machine to avoid damage to the water seals.
May 22, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Campbell Hausfeld PW1380 Pump won't run when water hose is connec
http://www.ppe-pressure-washer-parts.com/campbell-hausfeld-pw138000-pressure-washer-parts
Hope this helps. I have the same problem. It's not the switch but the mechanism that slides inside the switch, which activates the switch to go on and off. I fnally found it so hopefully they have the part in stock. It's not a clogged wand trust me I have torn it completley apart and found out it is the mechanism in the switch is plastic and breaks.
May 19, 2009 | Campbell Hausfeld 1,350 Psi Electric...
Campbell Hausfeld PW1835YLRB 1,800 PSI Electric Pressure Washer with Hose Reel Logo
62 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
