Question about Health & Beauty
How to change the batteries on a freerider mayfair?
I got given a scooter but hadn't realised I had to charge it regularly. I suspect I need to change the batteries now but can't find out how?
    Sergeant:
  • 313 Answers
The batteries are located under the seat. you will need to remove seat and then the plastic cowl that covers the batteries and drive compartment.
Posted on Jun 17, 2015
5 Suggested Answers
gewiz
  • 1271 Answers
SOURCE: freerider mayfair, no life at all in scooter
Look carefully , you will find a fuse , gently pull the wires around the seat stem , sometimes it can get buried under the power leads from the battery.
Regards
GeWiz
Posted on Oct 01, 2009
gewiz
  • 1271 Answers
SOURCE: Mayfair freerider mobility scooter - keeps losing
ok, sounds like the speed pot,
Can you move the throttle lever up and down, try going along at a constant speed (losing power ?) then move the lever up & down ?
does it improve response ? if so replace the speed pot.
Regards
GeWiz.
Posted on Oct 18, 2009
  • 692 Answers
SOURCE: I have a mayfair freerider scooter and all of a
try borrowing a charger from a friend or neighbor to charge your scooter If it charges the batteries then your charger is bad if it doesn't charge your batteries then the batteries are bad Hope this helps
Posted on Apr 18, 2011
  • 32 Answers
SOURCE: Mayfair freerider scooter shows reverse polarity on battery meter but wires good
Check to make sure you have a good ground.
Posted on Nov 17, 2012
How do I get to the batteries on my mayfair freerider
Lift the seat off. remove seat mount by removing pin or screws. Lift plastic cover off carefully but mind cables going to lights. These can be unplugged. And there should be your batteries.
Oct 19, 2014 | Health & Beauty
I have mayfair freerider and every now & then it stops then goes again there are no green light flashes.
hi, does it just cut out ?, if so there is one fault that can cause that, worth checking, try pressing the lever in the upwards or downwards direction while going along, if it doesn't cut out , the throttle pot needs replacing ... it's worth also checking the battery and controller connections making sure they are a good fit and tight...
Other causes:
Battery voltage dropping too low...
Brake breaking down..
Regards
Rob
www.gewizrepairs.co.uk
Mar 06, 2014 | Health & Beauty
How many miles can I get from a fully charged Freerider Ascot 4 mobility scooter? My scooter seems to run out of charge after a few miles.
11 miles on full charged new batteries, this is approximately as condition change max distance, like you weight, if you are going uphill, how even the ground is etc. if you need more you could get a spare battery pack for it, and swap them over when needed. but remember to keep them charged even when not in use once a week is the best way to keep them in good shape.
Sep 09, 2013 | Health & Beauty
Freerider Ascot Electric Mobility Scooter (4 wheel) Battery charges and holds current - horn works and shows green on power dial Scooter hardly moves underload - the engaged lever is set correctly. I...
I would suspect the brake is not releasing correctly and dragging on the motor housing. Try driving the scooter a short distance and feel the motor case at the rear near the brake assembly if it is very warm or hot the the brake is sticking and will have to be replaced. Hope this helps
Jun 03, 2011 | Health & Beauty
I have a mayfair freerider scooter and all of a sudden it wont charge up. charger says abnormal charge. Is there something wrong wiyh the batteries or charger?
Apr 17, 2011 | Universal Health & Beauty
Mayfair freerider mobility scooter - keeps losing power, especially on slow speed
Regards
GeWiz.
Oct 18, 2009 | Health & Beauty
Freerider mayfair, no life at all in scooter
Regards
GeWiz
Sep 30, 2009 | Health & Beauty
Health & Beauty Logo
187 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
