DVD door won't open
Was working some time ago. Now is not. Everything esle works
  • Ellen Lerner
    Ellen Lerner Mar 29, 2015
    update: husb. opened recorder. We fixed the door (too long to explain here), but machine says all disks fail. I think I'll have to get new machine, but very hard to find!!!
    Top Expert:
  • Televison & ... Master
  • 74,211 Answers
Disc loader mechanism fault. Either its loading belt or the loading motor might be defective. You have to take out the loader mechanism from the set, to replace either. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Mar 29, 2015
Testimonial: "Thanks. I don't think my husband has any more patience. We spent about 5 hours today taking it apart twice. The door opens, The CD spins, all the electronics works. These technical devices are so complicated. A small misalignment can cause havic. Others online have said the lens may be the problem. sometime they just go bad. Could be. I'll check the posts you recommended."
My Panasonic DMR E S45V just stopped working. The Error message is F04. The DVD door won;t open, the VHS door won;t close.
Check the servo unit to see if the actuator is changing modes when press the buttons. If one door is open the other will not function either.
Feb 02, 2015 | Televison & Video
Driver window only works when door is 1/2 way open
the wiring harness is going to be broken volkswagen sells the whole harness its better to do it that way rather then trying to fix the wires
Mar 11, 2014 | 2006 Volkswagen Jetta
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
Door locks won't lock/unlock
What kind of vehicle is it?
May 02, 2017 | 1999 Chevrolet Blazer
Overhead door opener 555 with manual release won't lockup chain
Sometimes if the clip is not reset then it wont catch the chain mechanism again to open or close the door. If you havent already reset the pull cord clip then that would be my guess. Try closing the garage door reset the clip with the rope attached, push it up til it clicks. and hit the garage door opener button. the rope and clip should move along the track until it hits the arm bracket where the garage door attaches to the chain mechanism.
If that does not do the trick then the clip has some screws on either side of the plastic casing and may need to be loosened and readjusted to match up with the garage door arm bracket and then locked back into place. That should do the trick if all esle fails, you may have to call the door company to come and correct the problem. Hope it works out!
May 28, 2012 | Home Security
Door won't open to insert dvd
The gears are jammed, the timing gear is out of sync, or a broken loading belt, or cogwheel.
Apr 19, 2012 | RCA DRC233N DVD Player
GO VIDEO model 1030....VCR works fine...DVD..nothing happens...door won't even open?
Combo units have this essential flaw--if one half fails you are usually done especially if the DVD side fails.
If Door does not open either a disc is jammed inside the mechanism or the mechanism is out of alignment or damaged.
Good argument against buying these units--DVD individual parts are rarely sold--only (if available) would be the entire DVD unit itself--not cost effective to repair.
DVD players are now real cheap (see some for as little as $20) so if not a simple jammed disc or something like that buy a DVD player.
Apr 05, 2012 | GoVideo Go Video DVD/VCR Combo
Memorex 3202-3223 dvd burner disc tray won't open
Try reseating the DVD drive so it makes proper connection.
Mar 05, 2012 | Computers & Internet
Unable to open the door of the dvd --when you press the eject button to open the slot---the door does not open---everything else works
Quick trick
First let's find out if the motor is dead or
the magnetic clamp is to strong for the motor.
Press eject then listen closely for the sounds of struggling motor
if you hear it trying SLAP the top right over the DVD drive
and that should break the magnetic seal and release the tray
you may have to try a few times Press eject and open hand slap kinda
hard the top of the DVD drive , don't worry you won't hurt it.
if that works email me and ill tell you how to fix this.
Rob
rsheehan@northernsteeldesigns.com
Oct 14, 2009 | GoVideo Go Video DVD/VCR Combo
Door locks and interior light quit working
i would check the connector where the fuses go to make sure it is locked and causing your problem
Aug 05, 2008 | 2002 Nissan Sentra
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
Electro Med Services...
