Question about Sony VAIO Computers & Internet
Service servers disable got no internet connection, no audilo, can't refresh or recover and I can't load windows 8.1pro
    Top Expert:
  • Sony Master
  • 8,095 Answers
Have you tryed starting up in safe mode?
Posted on Mar 30, 2015
My Samsung Galaxy core prime won't connect to internet gives error code
What is the Error Code?
Usual causes of Internet Disconnection:
1. System is Cluttered by junk files, cache files and other unnecessary files.
2. More client-applications installed that needs server connection
3. Block by your own firewall application
Resolution:
1. Clear History Files, Cache Files, Cookies and Junk Files. You can use CCleaner Application or Advanced SystemCare Application for Mobile to clear History Files, Cache Files, Cookies and Junk Files and even optimize your mobile performance.
2. Temporarily remove client-applications installed that needs server connection.
3. Disable your own Firewall Application temporarily
4. Refresh Network connection by Disabling and Enabling it.
5. If you are connected to a Router, restart your Router if not, reset it.
These might help you.
Thanks.
NAD818
Jun 14, 2015 | Samsung Cell Phones
Dns error laptop
Instructions
    • 1 Refresh the page that failed to load. If the page reloads, you just had a momentary lapse in service that happens with most providers. Between each following step, try refreshing the page to see if the problem is resolved.
    • 2 Check the page address you typed into the address bar to make sure it is spelled right. An error in the URL address could cause this error message.
    • Sponsored Links
    • 3 Go to your connection settings and make sure the settings match those of your Internet serviceicon1.png provider or local area network. Do this by clicking on Tools on the toolbar, then Internet Options. Under the Connections tab, click Settings.
    • 4 Click the "Detect Network Settings" link on the Interneticon1.png Explorer page accompanying the error message to let Windows try and find an optimum connection.
    • 5 Download DNS error fix softwareicon1.png off the Internet if no other option works (see Resources). The software is free on some websites and should be able to identify the problem and correct it.
Nov 21, 2013 | Lenovo Computers & Internet
How to change the server aol to my google chrome on start up
Dynamic host configuration protocol (DHCP) is a way to configure IP addresses and TCP/IP settings throughout your network.
The DHCP service is run on a machine with a static IP address so that the computers on the network can find it for automated configurations.
Setting the IP address on a Windows 2003 server is accomplished through the network configuration settings in Control Panel.
Click the Windows "Start" button and select "Control Panel." Double-click "Network Connections." In this section, double-click "LAN Connection."
This opens the configuration tool to set the IP address of the server.
Select "TCP/IP" from the list of configured network applications and click the "Properties" button. This opens a new configuration window.
Select "Use the following IP address" to set a static IP for the server.
Enter the IP address chosen for the server in the first textbox that is activated.
Enter the subnet mask and default gateway for the server.
The default gateway is usually the router on the local network or the DSL or cable modem on a small, home network.
Enter the DNS server address.
The DNS servers are separate servers on the network.
For small, home networks, the DNS server is provided by your service provider.
Click the "Ok" button to save the settings. Click "Ok" again at the general LAN properties window.
Renew settings on local computers. Computers that use the DHCP server for configuration need to be rebooted.
You can also use the DOS command prompt to renew settings.
The "ipconfig -renew" command refreshes the settings on client computers on the network.
or for home page browser
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on the tools at the bottom of the drop down list will be internet options or
Click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search Providers
Toolbar extensions and Accelerators you have
have if dont need any of them you can disable or remove them
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
Hope this helps
Dec 29, 2012 | Google Chrome
I have connection between my mac 10.4.11 and the zyxel router and I have connection between the zyxel router and an old compaq desktop upstairs but I cant access the internet, which is last mile. Ive...
dchp problem. sounds like the modem is doing dhcp that's why it works plug in directly. disable the dhcp server in the router go to Network > DHCP Server > General in the router and disable it. only the modem or router can do dhcp.
Aug 02, 2017 | Zyxel NBG-417N Wireless Router
Cannot connect to wireless internet
First, do you have a wireless router button that enables or disables wireless internet? If so than it might have got accidently turned off. push it and see what pops up on screen. If it says enabled than it was turned of try connecting to internet again. If it says disabled than push again until it says enabled clearly that wasn't the problem. Next try going down to the two computers (right hand bottom corner) then double click them. This will bring up a wireless networks available, try refreshing this page. After refreshed if no networks are available than it may have to do with your internet provider. Try calling them to get a better detailed explanation.
Jul 19, 2010 | HP Pavilion dv6000t Notebook
I have a Belkin N wireless router (model F5D8236-4). If I connect both my desktop and server (used only to store files) to the router, I have access to all files but no Internet. If I connect only the...
Perhaps the server is setup with DHCP services enabled?
If it's a windows server, try going to control panel--administrative tools and look for DHCP server
If it's there open it, then right click the server's name and choose disable dhcp.
Then reboot the server and the desktop and see if that works.
also the server may have a static IP address that would need to be changed to dhcp
Jul 10, 2009 | Belkin (F5D7230-4) Router (587009)
CANT GET ANY WEB PAGES 2 LOAD
If you still can't access webpages to load using different web browsers, then the problem is in your internet connection server. Also about your 2nd problem, go to this link:
How to remove linux and install windows xp
http://support.microsoft.com/kb/314458
Jan 09, 2009 | Computers & Internet
Can't send email in outlook
You may want to try to access the mail server through
another email client, such as "Courier Mail" from rose city:
http://www.rosecitysoftware.com/Courier/
This will tell you whether the problem is in your outlook settings,
or elsewhere. If Courier works, you may decide to stick with it,
it is simple to setup, and far superior.
If the courier mail does not solve the problem, you may have to
go through the "re-install network wizzard routine" again, disable
the windows firewall, disable the router firewall, disable all other
security widgits until you find what is blocking the email access.
This is assuming of course that you do not have server or
server settings problem as you said.
You may also have a rootkit or a virus lurking in the IP stack,
or the email protocol drivers, so scan your machine.
Martin
Apr 23, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
