Question about Apple 24" iMac Desktop
How simpletech hard drives work on apple computers
    Novelist:
  • 170 Answers
If this will be used as a primary or back-up boot drive, it will have to be erased and partitioned to at least one partition. You may want to create separate partitions for booting and data, depending on the capacity of the drive. Using Disk Utility select drive, select partition, use drop down "option" menu select GUID partition table, name your partition(s) and go ahead. It will now be bootable on Intel macs and readable on older Power PC macs if you share data among platforms and operating systems. Partition before putting any data on the drive, as it may be erased. In theory you should be able to partition a drive on the newer Mac OS without losing data, but I'm chicken.
Posted on Mar 28, 2015
    New Friend:
  • 48 Answers
Simpletech hard drives should work fine on Apple computers. I'd suggest you erase the Simpletech hard drive first with the "Disk Utilities" application using the "Mac OS Extended (Journaled)" format before using the hard drive.
    New Friend:
  • 4 Answers
When you buy any drive you should not count on it working on a Macintosh
Most drives are formatted with the NTFS format for windows.
First connect the drive if it is an external drive next open Disk Utiility and do as Steve Centanne says format it for the Mac, if you do not format a drive for Mac you will be able to send files to it but you wil not be able to access them if the drive is a NTFS format and it will not allow you to use it as a bootable drive for macintosh computers. Once your drive is formatted correctly you can do a disk restore and create an exact copy of your working macintosh computer and use it as a firewire or a usb bootable disk. YOu can access all of the drives hooked up through firewire by holding down the option key when booting your mac then you can choose to run your mac from one of the external drives. This is a bunch of information for a first time user so I might suggest making sure you know all you can before proceeding
Generally speaking whatever drive is running your Macintosh (booted from) internal or external is fairly safe as you cannot erase it during this process as it is the one that is in charge. There is so much more to learning how to do this but so once you figure it out practice practice backup backup. Once you have done it correctly you will NOT have to reinstall any of your programs or serial numbers. They will just be on an exactly cloned drive. Good Luck
Posted on Mar 30, 2015
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
When i plug in the usb to my computer it is not recognized and does not show anywher
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Hope this helps.
b>
Dec 14, 2012 | SimpleTech 500GB SimpleDrive Pro External...
Won't recognize external hd
Dec 11, 2012 | SimpleTech SimpleDrive Pininfarina 500GB...
How to put songs on The Simpletech Drive?
Just plug the Simpletech in the old computer that has the songs on it. Your computer will recognize the Simpletech drive. You can copy (from your old computer) and paste your songs to the Simpletech drive. Maybe all the songs you want will be in your My Music folder under My Documents. If so, you can just copy the whole My Music folder to the Simpletech.
Once you have the songs on the Simpletech, you can now plug it into the new computer. You can copy an paste from the Simpletech to your My Music Folder on the new computer.
You can also use the drag and drop instead of copy and paste.
May 23, 2012 | SimpleTech SimpleDrive 160 GB External USB...
The computer does not recognize the Simpletech external hard drive. I plugged in a different external hard drive into the same USB port and the computer recognized it right away. What is wrong with the...
not all usb devices work on all machines
You need to find a driver or ask simple tech what the issue is i had the same issue with My WDC drive Western Digital gave me a driver after emailing them
Aug 13, 2009 | SimpleTech 750 GB USB Hard Drive
I have a 60 GB simpletech external hard drive. I
Try to hook it up to another computer and see if it works there. This will tell you if the device is failing. If you have found that it failed please see about replacing the power adapter. If still no live the device has failed and needs replacement.
Thanks, Frank Z.
@Tech
http://www.attechcomputers.co.cc
3868607368
Jun 24, 2009 | SimpleTech Pininfarina 60GB External USB...
Hard Drive problem
Have a simpletech 96300-40001-001 external hard drive from couple years ago I bougt at Sam's. I have lost the installation software. It will now work on my laptop, the computer I bought it for because I installed it there when i bought it, but it will not work on the others (not recognized) and I cant seem to find a download of drivers that will make it work on this desktop and my other laptop. Do you know where I can get a copy of the original installation CD that came wih the hard drive. I am running XP Home on all three computers.
wayne williams
waynepat1@cox.net
850-865-7026
Jul 21, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
PC cant detect my Simpletech 500gb hard drive
well..you can 'see' it on the my computer, right? welll, then perhaps you'll check the usb cable, no?
Apr 03, 2008 | SimpleTech STORAGE, SIMPLETECH 500GB PIN...
Apple 24" iMac Desktop Logo
358 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
