Question about Dryers
Want to clean lint from below the filter that is cleared between each cycle, but its not easy to remover the plastic frame that holds the filter, to get down to the bottom - there must be a way to remove that to gain access for a proper clean out?
  • Dryers Master
  • 5,323 Answers
What kind of model dryer is this
Posted on May 16, 2015
How to open to clean
Hello! The dirt cup, filter and brushes need to be cleaned to ensure continued cleaning effectiveness. Below are steps for cleaning your Hoover Slider.
Turn switch to OFF position.
1. Press button and slide latch towards outside of cleaner. Rotate dirt cup toward back of cleaner.
2. While holding dirt cup, grasp filter frame and lift out filter. Empty dirt cup after every use. Dirt cup can be cleaned with a damp cloth. Allow to dry thoroughly.
3. Pull middle section of filter out of filter frame. To remove debris from filter, tap it on a hard surface or brush it with a soft brush.
4. Remove lint, strings, etc. from the brush roll located on the underneath side of the nozzle.
5. Replace the brush roll when the brushes do not touch the edge of a card as it is moved across the opening on the bottom of the nozzle.
Further disassembly of the cleaner is not recommended. Hope this helps!
F
Aug 13, 2014 | Hoover S2105 Slider Bagless Stick Vacuum
Tip
Cleaning Lint Filters
While removing that little screen occasionally to get the lint off, I have found that I get my clothes drier by doing it after each bunch of clothes dried. ALSO, while cleaning out the lint filter is a good practice, one that is just important, if not moreso, is to clean out the area where the lint filter rests. You can usually remove the plastic piece that you insert the filter simply by removing a couple of screws and gently lifting that frame out. Next step is to get out the vacuum cleaner, either upright or cannister will do well so long as the upright has a hose attachment. Put the crevice tool on the end of the hose and use it to remove more lint from from the "cavern" (my word for the comparative amount of room there) under the frame you have removed.
Not only will this help your dryer to work more efficiently, but it can also keep the chance of fires to a minimum. (Fires are more likely with a gas dryer.)
on Jan 30, 2010 | Washing Machines
I have a lot of lint below the lint screen how do I remove
You have to dismantle the dryer to clean completely, Sometimes the lint filter may need to be cleaned half way through a cycle if there is a lot of lint buildup.
Mar 10, 2012 | Whirlpool Dryers
My BOSCH dryer #WTE86300US keeps stopping in mid cycle and gives the signal F3 which says to check condensation outlet and I have cleaned all the parts and cleaned hose but it will still beep after a few...
I have owned the same dryer for about a year and just started having this F03 problem. The condensation drain hose is the soft flexible rubber hose coming out of the back of the dryer and it drains into the same drain as a washer. It's easy to pull the hose off its connector at the back of the dryer and just blow hard into it to make sure there's no lint clogging the hose and reconnect it to the dryer. Next open the panel on the left of the dryer and thoroughly rinse (water only, no soap) clean the two parts behind the door (first is plastic and behind that is the condensation filter which probably is loaded with lint). Sometimes the lint in the condensation filter channels (those that run from front to back) can be quite stuck. Use a long pipe cleaner to get in there or a garden hose with a spray nozzle. Shake the excess water out of the condensation filter and dry off the outsides of two parts. Clean all the lint out the compartment where the parts go. There is one more crucial step not mentioned in the manual. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver or a blunt table knife under the panel and gently pop it open. Under the panel is a small chamber that you can't see very well where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Use paper towel to get it all out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place as well as the condensation filter and the plastic part. Take out the lint filter (within the dryer drum compartment) and wash it with soap and water. Use an old toothbrush or something to clean the screens thoroughly. Rinse well and dry it completely. Clean all the lint out of the empty compartment. Put all three parts back into the dryer. Clean all lint off the door. Using paper towel moistened with white vinegar clean the two metal sensors in drum compartment on the front wall and lower left. Run the dryer empty but with heat on for a few minutes to make sure all the water is drained out. Now try drying a load. I think it's a good idea to rinse clean the condensation filter at least once a month since it collects a lot of lint. Hope this works for you.
Sep 22, 2010 | Bosch WTE86300 Electric Dryer
How do I remove the lint trap holder. I have lint
you have to remove the top then the control pannel then the entire front. are you ready for this?
Jan 08, 2010 | GE Washing Machines
Haier HLP21E 6.6-Lb: How do I remove the lint filter?
Grasp the top of the plastic filter frame with your thumb on top and first finger below, push down gently as you tip the frame out toward the middle of the bin -- the frame will flex slightly, and pop out.
Returning, make sure the you have 'up' up and 'down' down, seat the plastic pin on the bottom into its cradle, and push the top of the filter frame toward the bin wall. It will pop in.
After you do it a few times, it will become much easier. The frame seems to be fairly sturdy, I was a bit worried I would break it initially -- but it has lasted several years and many, many removals.
Dec 07, 2009 | Haier HLP21E Top Load Washer
Lint Filter Light comes on and cycle is interupted
Depending on how old this is or how much it is used depends how much lint has built up inside
the air flow tube. I have seen where you look inside where the lint screen is and beneath it with screen removed there is nothing but lint, in which case the dryer thinks the screen is clogged. You might have two screws on the inside of the drum that hold the screen holder in place. First remove the lint screen
and hold the little door that closes when you remove the screen, open the little door and look down inside it with a flash light, if you see a lot of lint, like I said you might be able to remove the holder
and clean this area out, also take a coat hanger and bend a little piece at the end and use this to get most of the lint out of this area and the tube that Leeds down from this area. If this can be done
and you get this area clean and it still happens, you might have to clean the entire area the tube
and the back tube,the tube leeding to the outside of the house and vent. Any questions please post back.
Mar 27, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Small plastic toy down lint trap
is the lint filter on the top of unit??? if so you ll need to disconnect power remove the 2 phillips head screws under the lint trap holding it to the main lid. then after removing about 10 1/4in screws from back panel you ll see a metal sleeve running down the back of the unit( the lint filter actually slides in to it) ending in a circular shape below. remove perhaps 4 more screws holding that panel on and youll gain acess to retrive whatever has fallen down there. easy enough to do yourdself no need to call in a professional
Oct 23, 2008 | Dryers
GE Front load washer WCHVH 6260F
I had the same problem.....The start/pause button would flash during a cycle and the washer would not finish the cycle. After reading on this forum that there is a filter/strainer inline with the drain, I tried this solution.
Remove the (3) screws that hold the lower front panel (Just below the door)
Once the panel is removed, you should see a white plastic strainer hooked to the washer drain.
Please a large bowl under the opening and unscrew the knob/handle, pull the filter/strainer out and clean all of the lint/trash out of this area.
My filter/strainer was clogged with a baby sock, 2 doilies, a fewe pennies, 2 dimes and lot's of lint.
I believe all of this debris was causing musty odors in the machine as the lint would stink due to dampness.
Once I cleared out this filter/strainer the problem and my odors went away
I wish GE would add this "EASY" step into the owners manual for proper care and maintenace.
Thank you for letting me know about this filter/strainer as it did resolve my problem
Sep 13, 2008 | GE Energy Star WCVH6260F Front Load Washer
I want to know how to remove the lint trap (not just the screen but the entire assembly) from a Maytag Performa PYET344AZW front loading electric dryer. The lint screen will not even properly slide back...
Besides drying clothes, dryers also remove lint. This fine, fuzzy material can cause trouble because it blocks dryer lint traps, clogs vents, and fills blowers. Lint can also gather around and in the tracks of the drum rollers, or in and under the pulleys and the drive belt. The result is poor clothes drying or -- sometimes -- no drying. To avoid lint problems, clean out the dryer's lint trap system every time you use the dryer.
To clean the lint screen, remove it from the unit. The screen may be located near or under the door sill, or in the top of the dryer near the control panel. It can usually be removed by pulling it up and out of its housing. Remove the accumulated lint to clear the screen; then replace the screen.
The exhaust vent also collects lint. Vent maintenance involves cleaning the lint from a screen in the dryer's vent exhaust collar and/or at the end of the exhaust vent where it sticks out through a basement window or through an exterior wall. To clean the screen, remove the clamp that holds the vent to the collar, or back out the screws that hold the vent to the collar, or pull the vent straight off an extended collar. Clean the screen thoroughly and replace it in the vent assembly.
To clean the vent itself, use a vent-cleaning brush (available at hardware stores) to pull out any lint deposits. Also check the vent run to make sure that the vent piping or tubing isn't loose at the joints, or -- in the case of flexible plastic venting -- isn't sagging between hanging brackets. Breaks or sags cause undue strain on the dryer's blower system, and can cause drying problems. If the vent pipe or tubing has become clogged with lint, remove the lint by pushing a garden hose or a drain-and-trap auger through the vent to a convenient joint. Disassemble the joint to remove the debris. With this procedure, it isn't necessary to disassemble the entire vent to find the blockage.You can head off problems before they become too serious by providing routine maintenance for your dryer's door gasket, thermostat, timer, and other frequently used parts. Let's discuss how to service these important components in the next section.
how-to-repair-a-dryer-1.jpgTHANK U.. RATE IT...
Sep 11, 2008 | Dryers
Dryers Logo
67 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
