Question about Acer Aspire AM1100-B1410A Refurbished AMD Desktop PC - AMD Athlon X2 4000 2 .1GHz, 2GB DDR2, 320GB S ...
When I tried to turn it on, the monitor show "No Video Input". I can hear the fan spinning but the computer is not running like it used to.
  • Acer Master
  • 2,992 Answers
Reboot. Did you install a new display adapter, or is it an on the motherboard display adapter? If on the board, I just had a problem with it, periodic screen freezes. If you have a spare display adapter you may be able to diagnose. Or a friend has a spare, or just gamble like I did and up-grade as well as solve the problem.
Posted on Mar 28, 2015
MONITOR IS BLACK, POWER LITE IS ON, I CAN HEAR COMPUTER SOUNDS
By computer sounds do you mean the sound of fans and hard drives spinning? If there are no loud distinct beeps indicating a startup error (See Post Beep Codes), then I would check the following.
I'm assuming you mean the power light on the monitor is on. If that is the case then it is one of two things.
  1. The monitor is not set to the correct input source.
    • Make sure you go through the monitors menu and select the input. Example
  2. The video cable to the monitor has a bad connection.
    • Make sure the cable is connected properly
    • If repositioning the cable differently restores the image than the cable is most likely failing. Try replacing the cable with known good one.
    • If the cable is good it could be a problem in the jack on the monitor or the computer.
      To repair this would require disassembling the monitor or computer and replacing the jack.
      However, most computers and monitor have more than one type video input/output. Try the other input/output jacks. Example
Nov 16, 2013 | Impression Products Impression 9LSP 19"...
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
Blank screen
Did it boot all the way? Do you hear the fan running, disk drive spinning? If it sounds like it booted but the display is black, try this:
When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Apr 14, 2012 | Computers & Internet
When I turn the computer on it goes into digital power save and windows does not load
The monitor is going into power-save mode because it's not receiving a video signal from your computer. Are you turning on the computer at the monitor or on the tower? If you're turning the tower on are you hearing any noise (i.e. fans running, beeps, drives spinning, etc.)? Does the power light on the tower come on and stay on? If not you may have a bad power supply or other hardware issue.
May 02, 2011 | Computers & Internet
My problem is that my computer screen just won't turn on! I can hear the fan running so how do I fix it?
Turn off your computer first.
if the power led indicator of your monitor is blinking then your monitor is not dead or damage, you just need to clean the video card of your computer, open your computer then clean the gold plated sockets if you are using a video card. but if you are using the built in video input then clean the memory of the computer. return the parts back to its proper place then try turning your computer On again.
Good Luck, Don't forget to vote for my rating, thanks
Apr 05, 2011 | HP w1907 LCD Monitor
When I try to start the computer I turn on the tower, then the monitor and while the blue light on the tower lights up the monitor say VGA no Input and DVI no Input. All cable are plugged in and the...
so the computer is dead, you never said dead. word
only video not working sometimes, (implied not stated clear)
Desktops are most easy PC in the word to diagnose and fix.
the monitor did not lie, there is no video sync, there for no video possible and then mon, goes to sleep mode,
we call that the black screen of *****.
black means the PC never texts or shows grapics ever.
that message you say is from the monitors brain and not the PC brain. dig?
steps:
1: PC not packed in lint ,stalling all those fans.; inside.
2: The PSU fan runs, and must pin and blow are (look it its grills)
if not the PSU is bad, or the is a short inside.(overloaded)
3: the CPU fan must spin and blow air (yes inside) an fins not packed in lent.,
4: CD/dvd eject button work>? PC on>)
5: HDD heard to spin?
the goal is to get BIOS working, (even with HDD removed BIOS works) so that is why a tech uses this rule to test any PC.
the bios keys are F10 or ESC, old to new PC.
if you hammer this key the screen will show BIOS.
there are many things to prevent the video card to work
do you have a video card there, does PC have 2 DVI jacks on the rear.? i cant see it so. cant advise you easy
see the 20 steps here, im not going to repeat them all
all are valid.
http://pcdied.com/black-screen.html#Basic-basics-101
Oct 16, 2017 | HP GX613AA Pavilion A6300F Desktop PC
When i switch on the monitor the on/off button blinks and i don't get a picture. johanalvemalm@people.net.au
Most monitors will behave that way if they don't get a signal from the computer so there's nothing to display. A quick check of the monitor itself is to disconnect the signal cable from the computer and then turn the monitor on. Most monitors will display some kind of a message that there's no input and to check your cable connection. Then the power indicator changes color as the monitor blanks out.
You will probably find that your computer isn't starting up when you turn on the power. A common computer problem is that it will turn on when you press the power button, showing a power light and you'll hear the fans inside start running, but it never actually starts running. Then there's no video to the monitor and you see the trouble you described.
The monitor may still be bad. If everything seems to be starting normally and you hear the Windows startup sound through your speakers, but the display stays blank, try another monitor. If that one works, you'll need to have the bad one serviced or replace it. If the test monitor is also blank, the video circuitry in your computer has failed. If the video is built into the motherboard, you can install a plug-in video card as a replacement.
If the computer is turning on but never starts running, that can be a pain to figure out because several things can cause the trouble. The most frequent causes are a bad power supply or motherboard. Bad RAM or a defective drive or other device connected to the motherboard can also keep the board from starting up. The processor itself can fail, but that's not common. I start by removing everything except for the power supply, processor and fan to see if the motherboard is starting. If the motherboard doesn't give a "no memory" error (usually a long beep), you need a power supply or motherboard. Otherwise, the basic hardware is fine, and you can start replacing parts until the trouble comes back, and then you'll know what caused it.
Good luck, and thanks for using Fixya!
Dec 28, 2010 | Samsung Syncmaster 940BW LCD Monitor
Signal has gone
If the monitor comes on and displays a message like "no input signal" or something similar, it's working properly but there is nothing coming from the computer. People often think that the computer is working and the monitor is at fault, when in fact the computer isn't starting up.
When you turn on the computer, do you hear the normal sounds of the power supply fan running and the hard drive spinning? Most computers will give a beep when they turn on and the motherboard finishes some startup checks. Do you hear that? Do you ever hear the normal startup sounds that mean Windows is actually running?
If you are convinced the computer is starting and booting into Windows, I would suggest you borrow a known good monitor to use as a test. If it works, that obviously means yours is bad. In most cases there's nothing you can do to repair a monitor yourself beyond checking for loose connections, bent pins in the signal cable plug, or a damaged cable.
If a known good monitor still has no image, the computer is at fault. Either the video card or integrated video isn't working, or the computer isn't actually starting up. In any case, that's where you would need to start looking for the cause.
Hope this helps you along the way to solving the problem. Thanks fo using Fixya!
Feb 02, 2010 | ViewSonic VX2235WM Monitor
Gateway FPD1760TFT LCD monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
Acer Aspire AM1100-B1410A Refurbished AMD Desktop PC - AMD Athlon X2 4000 2 .1GHz, 2GB DDR2, 320GB S ... Logo
88 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
