Question about Pioneer Audio Players & Recorders
How do you adjust balance pioneer vsx d412 - Pioneer Audio Players & Recorders
    Novelist:
    Champion:
  • 225 Answers
Posted on Apr 01, 2015
Testimonial: "Thanks though I should've mentioned that I checked the manual and there's no reference to how to adjust balance."
  • 4234 Answers
SOURCE: vsx-d412 displays "amp err" then
This is the same as "protect" mode. Basically the unit has detected a problem with the output stage of the amplifier and has shut down to prevent further damage. Usually this is caused by defective output transistors. Expect a parts cost in the range of $15-$40. Add in the local labor rate for the total repair bill.
Dan
Posted on Apr 15, 2008
  • 120 Answers
SOURCE: sub woofer pioneer VSX-D412 5.1
you have a bad cable
Posted on Jan 17, 2009
  • 30 Answers
SOURCE: Pioneer VSX-D412 AMP-ERR message.
The AMP-ERR message in many Pioneer Receivers is caused by some DC in the output. The microprocessor then issues the warning and shuts the unit off. It is definitely not a relay switch. It could be the amplifier power pack, i.e. PAC011A or similar that is faulty or something else. Not easy to repair for the non- experienced DIY.
Good luck
Posted on Apr 24, 2009
  • 30 Answers
SOURCE: sub woofer
The subwoofer is totally independent from your Pioneer VSX-D412. You can check if it works like you did with a finger on the hot point of the RCA cable (not very good test, as you will hear noise and can't say if that means it works OK) or better connect a known receiver to the speaker connections in the sub and test to see if it’s working properly.
Regarding the receiver, you may not have enabled the VSX to output to the sub. Read the manual on how to check for that. Only Dolby Digital 5.1 signals will allow the sub out, in a receiver of this level. It normally will not let you use the sub in stereo mode. Some more complex units will allow you that, but I believe not this model.
Good luck
Posted on Aug 02, 2009
  • 435 Answers
SOURCE: Can I use my Pioneer VSX-D412 receiver to hook up
Yes, both receiver and tv have optical/digital connectors, or alternatively, the S-video connector. The Pioneer will decode the compressed 5.1 signal coming from the tv unit.
Posted on Feb 15, 2010
Pioneer VSX-D412 directv remote code
I also have the VSX D412 and DirectTV. My DirectTV remote controls the D412 fine, but I did have the same problem you're experiecing with a Sylvania flat screen that the remote wouldn't operate. I corrected my problem by turning the TV off, then back on using the TV's remote, then telling the DirectTV system that I didn't know the model number and let the system search for the code. Hope this helps.
Feb 17, 2012 | Pioneer VSX-D412 Receiver
I have a Pioneer VSX-D412 reciever, and connot get my b channel to work. Only my A channel works, and I'd like to get both or all 5.1 working. And no I don't have the manual for the system.
In case you didn't see this on the other post, it is not the function of unpaid Fixya Experts to do the web searches for or read the manuals to those who can do it themselves. Most questions submitted to us would find answers immediately if they were typed directly into a search engine.
If you don't have the manual I recommend you get it. There may be other questions. A search for "Pioneer VSX-D412 manual" finds it.
What sources fail. How is it with test tones? have you isolated (swapped) the speakers?
Here is the service manual if you should ever need it. http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-D412_RRV2727.pdf
Aug 04, 2011 | Pioneer VSX-D412 Receiver
How to hookup micro phone to Audio/video multi channel reciever model# VSX-D411
It doesn't support direct connection of a microphone.
Register and download the manual for free at hifiengine.com
Search for "Pioneer VSX-D412"
Mar 06, 2011 | Pioneer VSX-D412 Receiver
Amp error
You have a defective amp ic.either ic601 or ic602 will be bad you will also have an open fuseable resitor in the channel where the ic is bad. ic numbers are PAC010A AND PAC011A
Apr 18, 2010 | Pioneer VSX-D412 Receiver
Can I use my Pioneer VSX-D412 receiver to hook up my surround system to my new Samsung HDTV?
Feb 15, 2010 | Pioneer VSX-D412 Receiver
Sub woofer
Good luck
Nov 01, 2008 | Pioneer VSX-D412 Receiver
98 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
