Question about Garden
I AM NOT GEETING OIL ON MY CHAIN BAR, DO YOU HAVE ANY SUGGESTIONS ON WHAT PROBLEMS IT CAN BE BESIDES THE PUMP?
This is a Homelite 3300 zr chainsaw if that helps.
Posted on Mar 30, 2015
  • 211 Answers
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Posted on Dec 01, 2008
  • 1388 Answers
SOURCE: stripped bar stud
Many Sthil chainsaws have replaceable bar studs. The stud threads into the case. Go here: http://www.baileysonline.com/itemdetail.asp?item=QA+0000+953+6605&catID=407
look for part by model number, usually no more than a few dollars. Enjoy
Posted on Dec 21, 2008
SOURCE: my 455 rancher chain saw is not using her chain oil
Replace the oil pump..Or just try to clean it out but I have been through this and it worked for about ten minutes and I ended up just replacing the pump and works fine now. They are not very expensive (35.00-40.00) and only takes about ten minutes. Get a beer and a table or the tail gate of you truck should be fine. Take off the side cover remove the bar and chain. Clean everything up... air compressor is best a paint brush and rag works good if you do not have a air compressor. Take the top plastic cover (three screws on top of the saw). Pull the spark plug and feed a piece of rope into the cylinder. This will bind up saw so you can remove the clutch. I use a pull start rope from my old lawn mower and keep it in my saw box for this reason. This size and kind of rope seems to work best. Now you need to remove the clutch. There is an arrow on the clutch that tells you which way to turn it to get it off. This can sometimes be tricky but don't give up. I'm sure there is a tool for this and I keep saying that I'm going to make something. I use the handle of a good strong pair of pliers and turn the plier with a pair of vice grips. When you see the clutch you'll figure out something to use to loosen it and spin it off. Un-spin the clutch and remove the clutch drum by just sliding it off the spindle. Be careful because there is a bushing with needle bearings. The bearings are in there pretty good and wont just fall out. If you want to replace that you can 14.00 or so. There is also a plastic drive gear for the pump that just lifts out , replace it too 6.00 or so. Take off the metal cover I think it's just one screw. When you remove the cover you may see a lot of saw dust and oil all packed inside. If you have an air compressor just blow it all out. The oil pump is right there and is simply removed with one screw. clean every thing up put the new pump in put everything back together and you should be back in business.
Posted on Feb 14, 2009
SOURCE: chainsaw wont oil the chain and bar it is a poulan 2000 woodsman
It's probably the oiler check valve located on the crankcase just in front of the clutch. You will probably need to remove the clutch and sprocket to get at it.
Posted on Mar 06, 2009
SOURCE: stihl 180 chainsaw,lack of oil to chain and bar
hi there i had this problem check bar studs make sure there tight bar must be flush on chainsaw body not on stud flange if bar is on stud flange there is a gap so oil leaks out near sprocket and not in bar oil channel
Posted on Apr 24, 2009
How to replace the oil pump as no oil is coming onto the chain
WELL AS U DIDNT INCLUDE ANY MAKE AND MODEL , I CANT BE SPECFIC , BUT B4 U JUST GO INTO REPLACING PARTS , HAVE U TRIED TO CLEAN IT ?? IVE SEEN LOTS OF NO OR LOW OIL PROBLEMS OCCUR WHEN SAWDUST GETS JAMMED INTO CHAIN BAR , AROUND OIL GROOVE( NEXT TO MOUNTING NUT) , A QUICK TEST OF PUMP IS TO RUN SAW WITH BAR AND CHAIN REMOVED (NOT FOR LONG TIME!) AND SEE IF OIL PUMPS OUT HOLE
Nov 15, 2016 | Garden
What oil does the ryobi use
all oil tanks on chain saws take Bar/chain oil this can be bought same place u buy 2 cycle engine oil most times , this bar chain oil most times is a 30W oil , if you change weights of oil then oil pump is not gonna add proper amount of oil to saw in use ,this will cause u problems !
Jan 18, 2014 | Ryobi 18-inch Electric Chainsaw Chain Saws
Bought a new husqvarna 238 or 240 model the oil is not getting to the chain like it should any suggestions?
The early machine had big issues around oiling, there was a new crankcase with strengthening around the bar bolts, a new pump with better sealing, a new pump delivery pipe to stop collapsing, all these parts are retro fittable, but should be a warranty job.
Sep 11, 2011 | Husqvarna Chain Saw 20" Bar
Do not pump chain oil
Release the chain brake, then remove the bar and chain. Clean the area of the engine where the bar fits to, then start the engine to see whether oil oozes out of the port in the engine. If ok, then clean the bar drive-end small oil passages that run from the large holes out to the chain groove on each edge. If no oil comes out of the port, then internal service is required for the oil pump, oil line, or oil tank filter. Hope this helps!
Dec 29, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
No oil to bar
Remove the nuts that hold the clutch cover on, Then remove the bar and chain. Make sure the port hole in the bar is open for the oil to flow into the chain groove. The oil ports can get plugged by sawdust and chips. Bar oil is sticky. The bar and chain should be removed and cleaned on a regular basis. Clean the groove in the bar too. Also make sure the port on the saw body is open. Start the saw with the bar and chain removed, if oil doesn't flow from the port, then you have a faulty oil pump and will need to go in deeper to replace the pump parts.
Always use proper clean chainsaw bar oil. Using other types of oil can burn up your oil pump.
Dec 27, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
I have a husqvarna 257 with a 20inch bar and having oiling problems, is getting hardly any to no oil and have the oil adjuster screw the whole ways out, is the oil plunger bad?
If you take the bar off, and then run the saw, does oil come out of the saw? If it does, then the oil pump is likely working O.K.
If the oil comes out of the saw and does not make it onto the chain, it is possible that the oil exit slot on the saw, and the hole on the bar are not lining up properly. This happened on my Husqvarna 141 saw. The oil was coming out of the saw fine, but it never made it to the bar and chain. As a consequence the chain was always dry and very, very hot.
The other saws we use, always have plenty of oil on the chain. I think Husqvarna may have made a design flaw on some of their saws, and the exit point of the saw and the entry to the bar are not properly aligned. I wonder how many saws this affects.
Sep 14, 2010 | Husqvarna Chain Saw 20" Bar
I have a ryobi expand it pruning attachment. How much oil does it require to lubricate the chain? What kind of oil? thanks
just fill up the bar oil tank , no actual qty as such
use chainsaw bar oil - its bio-degradable and has a very slight stickyness to it that makes it stay around on chain and bar
motor oil will not stay put on chain and bar - besides not
eco freindly
cheers
Aug 12, 2010 | Garden
Chain is not getting oil
Remove the bar and chain--clean the port area where the bar fits. Run the saw at speed for a few moments--it should ooze oil out of the port. If it doesn't, then you need to check the pump, lines, and tank for plugging or other problems. If the oil came out ok, then clean the bar drive-end small oil passages that run out to the chain groove on each side. Clean the entire chain groove as well. Reassemble the bar and chain (the teeth cut toward you on the lower run), and adjust the chain so that it just pulls up to the bar, but not so tight that you can't pull it by hand. Run the saw tip at speed near some cardboard--it should throw off a thin line of oil. Hope this helps!
Jul 09, 2010 | Echo CS400 18" Chain Saw
Poulan Pro Chain Saw Bar Chain Oiler Stopped Flowing
The filter can usually be caught with a hooked wire and drawn up far enough to deal with the filter. Oil filters are not prone to plugging unless the oil used is contaminated. If you run the engine without the bar and chain attached, oil should ooze out of the engine side port. If nothing, suspect problems with the oil pump. Some saws use a plastic gear in the pump and can strip the teeth of the gear. You should find it located behind the clutch assembly. Once you have oil flowing from the engine, clean the bar drive-end oil ports that go from the large holes out to the chain groove on each side. Finally, run the bar tip near some cardboard--it should throw off a thin line of oil. I have no idea what the plastic tube might be (a manual pumper perhaps?). Hope this helps!
May 23, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Hot bar loose chain
Remove the bar and chain from the engine. Clean the side of the engine where the bar fits, start the engine and run fast for several moments. Oil should ooze out of a port and run down the engine side. If nothing, then the oil lines, valves, tank filter, and the oil pump (behind the clutch assembly) should be checked for plugging, breakage, or other problems. If oil comes out, then clean the oil holes in the bar drive end including the two small holes that lead from the larger holes out to the chain groove on each side. Clean the entire chain groove. Oil and check the end sprocket for smooth, relatively free turning. Compressed air is very useful for cleaning these parts. Reassemble bar and chain making sure the adjustment tang drops into one of the large holes--you may have to back off the adjustment several turns to make this work. Make sure the chain cuts toward you on the bottom run and install the clamp nuts/bolts finger tight. Adjust the chain until it pulls up to the bar and you can turn the chain by hand. Run a line of oil around the chain to pre-lube it. Tighten the clamp nuts and retest the tension again. If ok, start the engine and run for several minutes, then place the tip near some cardboard and run at speed for several moments--it should throw off a thin line of oil. Make sure the chain is fully sharpened then try a few cuts. It should cut smoothly without any undue pressure from you. Hope this helps!
May 15, 2010 | Husqvarna Chain Saw 20" Bar
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
