Question about Hoover Washing Machines
How much will also hoover washer dryer HW130M cost me new and second hand please reply as have broke a friends and need to replace
  • Hoover Master
  • 5,323 Answers
Its unfortunate that the owners blame u for breaking it? usually it will not break from one time use even if improperly used? Machines just break down all of a sudden, anyway as for new vs, old used, new is much to expensive to replace an old used one. and used should be around 100-150.00 some friends u have if u ask me, why are u replacing what may be easier to fix ? whats wrong with the old one?
Posted on Apr 20, 2015
  • 360 Answers
SOURCE: new machine need manual
This is the only manual I could find with 7148 in the model http://service.hoover.co.uk/manuals/pdfs/HNWF7148.pdf
please take the time to give this solution a fix ya rating.
clarkco
Posted on Feb 19, 2009
  • 156 Answers
SOURCE: Our Hoover Washer Dryer HW130M has stopped drying
Yes could be the element but there is also a reset button for the element, designed to trip out if ever gets too hot. Remove the top of the machine and button should be clearly visible. Try this first before committing to a new element
Posted on Oct 05, 2009
heatman101
  • 43501 Answers
SOURCE: Hoover Washer/Dryer WM120 : Dryer function - drum not turning
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
treru
Posted on Sep 30, 2010
justinbur167
  • 257 Answers
SOURCE: I have a second hand
Hello Librimelow,
The Buttons on the Hoover Softwave are as follows from left to right:
1. ?
2. Half load
3. Wool
4. Low Heat
5. Power
I can not find what the first button is I have looked every where I can think of to find out what the first button is. YouTube has many pictures of the front but you can not make out the first button of the group. Sorry I can not be of more assistance.
Thank you for choosing FIxYa.com
Justin
Posted on Mar 16, 2011
SOURCE: User manual needed for Hoover washer/dryer
I think you connect wires wrongly and after that it is not working in a proper way so here you need to change the wire position for working in a write way.
Washing Machine Warranty service
Posted on Aug 31, 2012
Condensation builds up inside machine during cycle and trips out the electric
i cant see condensation being the problem. as washers are designed to withhold this factor i belive there is an earthing problem or/ pos/neg leak causing the washer to trip the rcd. have it looked at by a service tech
best of luck
Nov 28, 2010 | Hoover HW130M Front Load Washer / Dryer
Motor not turning on cycle or spinning
check filter is clean normally if this is restricted it prevents normal function of machine
Oct 18, 2010 | Hoover HW130M Front Load Washer / Dryer
When my washer/dryer is turned off, why does the drum keep filling with water?
Turn the water off in the back of the washer where the hoses hook up...
Then check this tip out...
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Apr 25, 2010 | Hoover HW130M Front Load Washer / Dryer
Our Hoover Washer Dryer HW130M has stopped drying on the Tumble cycle. It continues to turn and dial turns to cmpletion but doesn't seem to heat up. Only realised as days cooler and not been using outside...
Oct 05, 2009 | Hoover HW130M Front Load Washer / Dryer
Spin Dryer doesn't work on Hoover 500M
Most probably the solonoid (also called brake motor). This is a 5 rpm motor that activates the drum to spin. I just replaced it two days back in my machine (Model 500M0AUS - you'll have to be specific when ordering or better take the old one to the spare part shop) which had a similar problem. The new soloniod I bought had a shorter cable length so I had to improvised when fitting. If soloniod is the problem then make wure the steel brake lever tooth fits perfectly in axle groove when you finish replaceing it. Do the replacement when the machine has fully stopped after completing its wash cycle.
Repair technician quoted 250 while the solonid costed me only 86. I did not charge labour to myself:)
Hope this is helpful.
May 28, 2009 | Hoover Nextra HNT 2135 Top Load Washer
New machine need manual
clarkco
Feb 19, 2009 | Washing Machines
Intermittant Drum
is the a pcb near the motor,sometimes the motor controler board can be faulty not sure on this brand hope this helps.
Sep 22, 2006 | Hoover HW130M Front Load Washer / Dryer
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
