Can this united be converted to natural gas? - Heating & Cooling
  • 494 Answers
We will need the make and model of your heater to determine if it can be converted to nat. gas. A photo of the unit and the gas control would really be helpful too.
Posted on Mar 29, 2015
  • 8 Answers
SOURCE: convert from lp to natural gas
you need to go to the manuel and check if you can retrofit the heater to natural gas. there is a difference in the ORIFICE size. or check to see if there is a phone number to the manufacture and talk to them. THE BEST THING FOR YOU TO DO IS TO GET A CERTIFIED A/C PERSON TO DO IT, IT IS VERY DANGEROUS IF YOU GET THE WRONG ORIFICE SIZE !
Posted on Jan 06, 2009
  • 10865 Answers
SOURCE: I'd like to convert my model PGB025-75 unit to
hello. The conversion requires different orifices. They can be ordered from the company, or from your lp provider or your natural gas provider.
Here is a link to a great article that explains every step for you to make the conversion
http://www.propane101.com/lpgasapplianceconversions.htm
Posted on Jun 11, 2009
  • 22 Answers
SOURCE: convert a procom heater from propane to natural
you need to find a place that makes your type of heater and they will have a change over kit all it is different orfices and jetcovers for each gas jet from your heater its self explanitory once you see the parts,sometimes there are different gas comp. that if you use there service they will change you over at no or little cost. hope this helps
Posted on Sep 15, 2009
SOURCE: I want to convert a QN300TYLA natural gas unit to
HI , I HAVE A PROPANE MODLE QL300TYLA I WOULD LIKE TO CONVERT TO NATURAL GAS , MAYBE WE CAN SWITCH PARTS.
Posted on Oct 14, 2009
dennymulford
  • 1055 Answers
SOURCE: Natural gas convertion to LP
you need too change the orfice about 10.00
Posted on Dec 22, 2009
Convert to natural gas
To convert the heater to natural gas you will need to change the orifices in the gas unit to natural gas. I am assuming you now have it on LP gas. Hope this helps. You should have someone who knows to change the orifices over. Most appliance parts dealer carry them.
Jul 18, 2016 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Tip
Changing your gas appliance from natural gas to LP or vice versa.
You have an LP gas stove which you really like and would like to take to a new home but the new home has a natural gas hookup. Since natural gas is already available it would be convenient to be able to use it. Can you convert your unit over to work on natural gas?
Yes it is possible to convert any LP gas appliance to natural gas or from natural gas to LP. The only difference is the size of the orifice used in the burner.
LP gas is composed of a much larger molecule than natural gas and requires a larger orifice to output the same amount of gas as a natural gas unit at the same setting. Therefore if you used an LP stove on natural gas it would produce too much heat and burn rather intensely. If you used a natural gas stove on LP it would not have much flame at all. You can see the problem. The solution is also obvious. You need the correct orifice.
Changing the orifice is easy. It is located in the middle of the burner and unscrews out of the unit. Install the new one the opposite way. Do not overtighten it.Usually the burners are made of soft metal and can strip easily.
The parts you would need are available at most good appliance stores but I would recommend the following site http://www.repairclinic.com . The parts will be cheaper at repairclinic. They have parts for almost any brand and a great search engine. They also have excellent videos showing how to make the repair.
Thanks for using FixYa and for the great rating.
hardrocko
on Dec 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Can I convert from natural gas to propane
Yes... you just need a retrofit kit.
Jan 26, 2016 | Heating & Cooling
Can i convert a Rheem ECO 180DVP (LP gas unit) to a natural gas unit ?
Rheem water heaters should not be converted from propane to natural gas. The burners have been optimized for the rated gas and will not work as well after conversion. (Unlike ranges where the gas/air flow ratios can be adjusted when the burner orifices and regulator are swapped, the water heater doesn't have that option.)
I wish I had better news for you. I recommend you get a new water heater for the LNG service; it will be safer and more efficient.
Nov 10, 2014 | Rheem Tankless Hot Water Heater...
Convert coleman eb15b to natural gas unit
Sorry there is no way to convert it to a gas unit.. The only way is to replace the furnace with a natural gas unit. You will need a gas line ran to it and a Flue. and then room to fit everything in that space.
Nov 10, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Thermador PG484GGBS: How to convert from Natural Gas to LP?
Hello Amvmotors,
I understand that you want to convert your Natural Gas unit to LP (Propane) gas you will need to purchase a conversion kit. Please give me about an hour or so and I will locate it and the instructions to convert.
Thank you for choosing FixYa.com
Justin
May 17, 2011 | Thermador PG484GGEBS Stainless Steel...
Where do i find propane to natural gas conversion kit for weber spirit e310 gril
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
See below link.
http://www.weber.com/help/manuals/pdf_files/2008_updated/89525_030308_2008.pdf
Feb 23, 2011 | Weber Spirit? E-310 Propane Grill
Can i convert my rlp 30 to natural gas
No you can not convert this unit to natural gas. They do not make a conversion kit or give us any sizes to drill out any orifices.
Dec 27, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Is there any difference in bottle gas heater and natural gas heater
by bottle i am assuming you mean propane. yes there is a difference , natural gas is mostly methane gas (ch4) a very small molecule, propane is (c3h8) a much larger molecule. so they require different gas nozzles and cannot run a unit on the other fuel, some can be converted to run other gas. generally natural gas units are cheaper to run, but cost more for installation as a gas line has to be run to the unit and benefit of not running out of fuel. hope this helps.
Apr 23, 2010 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Natural gas to LP converters
Your Tappan dealer can help you with this. You have a good named unit so it shouldn't be a problem. You could also check with your gas company as to where to get the conversion parts.
Feb 05, 2009 | Tappan TGF320 Gas Kitchen Range
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
