Question about Euro-Pro 6131 Mechanical Sewing Machine
Can you use metal bobbins in this machine? - Euro-Pro 6131 Mechanical Sewing Machine
    Master:
  • Euro-Pro Master
  • 470 Answers
Probably. Most are plastic today because they're cheaper.
If they fit and work, go ahead.
Here are parts being offered for your machine; 6130 is close to 6131.
Euro Pro 6130A2 Parts
Posted on Mar 29, 2015
  • 3 Answers
Most bobbins are interchangable, the main difference I'd the depth of the bobbin. As previous answer says plastc as used because the are marginally cheaper, but also because you can see what thread is on the bobbin and how much is on the bobbin.
i am assuming you have been given or have some metal bobbins from another machine, as long as they are clean and rust free and the same size they should work fine.
Posted on Mar 30, 2015
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
Husqvarna viking sewing machine bobbin
Could the part number be 4011770? I've found the Viking 7 bobbins here: http://www.mysewingmachineparts.com/top-quality-metal-sewing-machine-bobbins-4011770-husqvarna-viking/ . Another site with them is http://www.sewingpartsonline.com/bobbin-viking-4011770.aspx . This bobbin is compatible with the Husqvarna Viking 7, 49, 51, 52, 21 & 21E . It probably will work for other machines. Sears also has them listed as 11770: http://www.sears.com/generic-viking-sewing-machine-bobbins-sewing-machine/p-SPM6124767105?prdNo=1&blockNo=1&blockType=G1 .
I also found these bobbins: http://www.amazon.com/Viking-Metal-Bobbins-5-pkg/dp/B000YZ5QSC . The part number appears to be 1702.
I hope this helps.
(googling Husqvarna Viking metal bobbins found a number of hits.)
Mar 05, 2013 | Husqvarna Viking 1
I cannot get the bobbin thread to catch and pull through the footer wen trying to thread the machine?
Make sure your bobbin is placed in correctly. Thread is counterclockwise as you place bobbin in the metal piece. Pull thread end through sliver in metal piece. Hold on to movable metal latch then lock the bobbin in place. Bobbin should not fall out but is able to rotate. Rotate the wheel on the furthest right of your Singer 1507 machine towards you to move the needle downward. The top thread should then be able to catch and pull up the bobbin thread.
Dec 02, 2010 | Singer 1507
Unable to replace bobbin case back into machine
Here's how I do it. I hold the thread with my left hand, just like the thread wikk be pulled up. With the right hand pull the metal tab toward me, hold it open while pushing bobbin in and twisting. When bobbin stops turning and feels seated, then release the metal tab to lock. good luck!
Nov 18, 2009 | Singer Sewing Machines
What bobbin size for elna supermatic 722010 Can I purchase metal bobbins for this machine at a Joannes? or ? Is there a staner bobbin number or size to ask for?? thanks@ The Elna I have came with ONE...
Elna Supermatic 722010 is a very vintage elna and would take the metal 7 hole dished bobbin like this.
Don't try to use any other bobbin in it, and always load and wind with the holes on top.
You can still buy these; one supplier is sewingpartsonline, here is like to the item
http://www.sewingpartsonline.com/bobbins-elna-426000-10pk.aspx
Aug 17, 2009 | Elna Heirloom Edition 6005
Bobbin case and threading singer 6423
This machine has a black plastic bobbin case. You drop the bobbin down into the case with the thread coming off in a clockwise direction. If you look close you will see a slot in the bobbin case where there is the metal pieces. The thread will slide into that and as you pull on it it will work its way through and come out on the other end of the metal. Lay the thread over top of the bobbin case and turn the handwheel to pick up the thread. (make sure you close the slide plate)
Feb 07, 2009 | Singer 6423 Sewing Machine
Bobbin thread getting caught
Check your Instruction manual - if you have taken the bobbin case apart to clean it, the shuttle must be reinserted with the little tab pressing against the piece you mention. It is under page 45 - "Caring for your machine" in my book. I missed it the first time I cleaned and oild mine.
Mar 21, 2008 | Singer 3962 Mechanical Sewing Machine
Sewing club member starting sewing with a metal bobbin.
Can't say for sure but besides prefrance, I have never seen a differance between metal or plastic in Janome or Elna.
Mar 06, 2008 | Janome Memory Craft 4800QD
Euro-Pro 6131 Mechanical Sewing Machine Logo
74 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
