Question about Water Water Heaters
Just bought my house and the water heater will not turn on is there a common problem with these that I can fix my self
  • 2,963 Answers
Appears to be Electric water heater. There may be a heating element/s burned out if the tank was empty of water and power on
If you have an ohm meter if you get zero resistance you know its the element. (with power off) If you have good DIY skills, know electricity will kill if handled improperly, you may be able to replace element/s. If elements are ok, you may have a thermostat problem. Or there may be a high heat protective switch that has expired. It should be part of the element assembly and have wire to and from it and the element. I notice you have a 9yr. warranty. It may or may not transfer with the new owner, and it may be past it's purchase date or install date. Try to get a repair manual from MFG website, or possibly manualslib.com
Posted on Mar 28, 2015
  • 1,909 Answers
Did they turn the power off to the heater before you bought the house?
Check there first. I used to shut the power off to ours when going on vacation. Check curcuit breaker if its hydro and if its gas make sure the the gas is turned on and pilot is lit.
I went to take a shower this morning and the water was ice cold. For more than twenty minutes the water ran and never warmed up. Are there common things to check my hot water heater for in this situ
There is an adjustment knob to control how hot the water can become. There might be a problem at the tap (however, if this is the case, you would still get hot water everywhere in the house). If the entire house isn't getting hot water, and the knob is set at the hottest water, you probably need to get the hot water tank replaced.
Feb 04, 2015 | Rheem Tankless Hot Water Heater...
Hot water heater water, went out main line of house that enters house
You did smart thing turning off water and gas.
Play it safe.
Your water heater will NOT explode.
Conduct routine maintenance so water heater lasts longer. If plumber says you need new heater, then post question on fixya and include information showing on tank label on side of tank.
Also include why plumber says to replace.
Get another plumber.
Call city utility company to determine source of noise.
Dec 01, 2012 | Whirlpool Water Heaters
We have a plumbing technician to repaire the water leakage out side of our house, which need to turn off the water supply to our house. After that, we found that hotwater will not turn on (burner light...
You have gas water heater.
Probably a tank-type gas water heater.
The plumber can fix water heater.
If you want to fix water heater yourself, then more information is needed to narrow down scope of answer.
1) Add a comment for possible help.
Instructions for lighting the water heater appear on front of water heater. Do those instructions include lighting the pilot light?
Will the pilot light stay lit?
On side of tank is a label. Label shows Brand, type (LP or NG), and model number.
This information can help narrow the type of gas control valve, and point direction for troubleshoot.
Add a comment with this information for possible help.
2) Do-it-yourself: Open following link for do-it-yourself resources to help solve gas water heater problems:
Generally the instructions show how to clean water heater parts, check venting, and show different types of gas controls, plus links for pilot light problems and cleaning air intake.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 24, 2011 | Noritz Water Heaters
I turn off the main water valve to fix a leaking problem and now the water heater does not work. What is the problem, how do I fix this?
Turn the water valve back on, shut the power off to the water heater for a few minutes and let it reset it self. Push the reset button, and try again. Hope this helps
Mar 08, 2011 | Bosch Water Heaters
My Powerstar tankless water heater was installed last April and we have a problem that has become a real issue. We can set the temperature where we want it and get in the shower and the water will go from...
Ok, sounds like a flow sensor issue, is your house water pressure steady or does it fluctuate? The sensors on these seem to be a common issue and this model has many issues with heating. take care
Jan 17, 2011 | Bosch PowerStar AE125 AE125 Whole House...
I have no hot water at all. just bought this house in florida and it was working when it was inspected 2 months ago. is their a switch to turn it on or off?
Well there should be a circuit breaker in your panel. Be sure it is on. If the water in the house was OFF while the heater was on, the element(s) could have burned up. You can go to Reem's web site and download a manual for the water heater. It will depend on your experience as to whether or not to work on this. On must follow safety procedures to work on a energized water heater for testing. There is a high limit reset button under the cover that houses the thermostats. I would recommend turning breaker off before opening this cover. The rest is a red button. Remember electric and water don't mix.
Oct 31, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
My kids just bought an older home w/a rinnai continuum nc-45-4us. right now their house phone isn't installed, so they can't phone, but they can't turn on hot water. any suggestions
Run through the basic checks
  • Power lead from the heater plugged in a socket turned on.
  • Gas on to house
  • All valves below heater in on position.
  • If they have controllers in the house turn on (key pads marked with Rinnai logo in kitchen or bathrooms usually)
There is a turbine that spins in the heater when a hot tap is run. If the heater has been sat for some time not operating the turbine might have stuck. Run the hot tap and keep it running, using a hammer give the centre pipe connection under the heater a firm hit a few times(not too hard). This might unstick the turbine.
Sep 21, 2010 | Rinnai Digital Remote Water Heater Control...
Are water heater runs for about a minute then the code C7 13 Code flashes and we lose our hot water?
Call Rheem for a new unit. They problem will never be fixed. They have redesigned the unit. It is now RTG-95DVN a self contained venting unit. Mine was worked on several times over two years and much frustration before they finally replaced it.
Sep 05, 2010 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
We have a leaking water heater.
As far as a shut off valve on to the water heater, if there is one you should be able to see it on the water line going to the heater. This is not common in mobile homes. If there is not one I would strongly recomend you install one when you replace the heater. If it is going to be a while before you replace the heater you might consider draining it and cutting into the inlet line and installing a shut off valve, so you can turn the house water back on. I hope this helps.
May 12, 2010 | General Electric GE SmartWater Household...
Can't regulate water temperature
Slower the flow hotter the water is how it works . Sounds like the water section is blocked and could well need cleaning out . Draw back with this system is you need a good inlet flow and flow will drop when you open other taps . they are good for a small house a family house not that good . Not much you can do put in a bigger water inlet to heater ?
Mar 10, 2017 | Bosch AquaStar Indoor Natural Gas Tankless...
Water Heaters Logo
60 people viewed this question
Top Water Heaters Experts
freddyfox
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
