Question about Oster Kitchen Appliances - Others
My darkness slider is broken on my Oster 3865 waffle iron. how do I fix it?
SOURCE: Salton Belgium Waffle Maker
I, too, was searching for that wonderful Belgian Waffle recipe and thought, no problem, I'll just look on-line. I couldn't believe it when Salton didn't have it posted on their site (if they did, I couldn't find it) and was taken to your requests for the recipe. So, I went the whole mile, or should I say traveled over mountains of files, and couldn't believe that my filing system still works after all of these years, the Salton Belgian Waffle Maker & Recipe Guide for Model No. WM-4 was right where it was supposed to be. (And my husband, and prior bosses I should add, have laughed at how I save and file everything. I'm glad I can share this with you all now...
Basic Belgian Waffle Recipe
1 cup all purpose flour
1 tsp. baking powder
1/2 tsp salt
1 tsp sugar
1 cup milk
1 egg, separated
1/2 tbl butter, melted
-Sift dry ingredients together in a bowl
-Add egg yolk and milk to the dry ingredients and beat together thoroughly.
-Beat egg white until stiff, stir 1/4 into batter to lighten it and then gently fold in the remaining egg white.
-Pour a scant 1/2 cup of batter onto the heated waffle mold. The light should be off. When batter is added, the light will go on. When the light goes off again, the waffle is done.
-Makes about 6 waffles.
Chocolate Waffles ("which make great ice cream sandwiches," says the recipe book.)
1 tsp baking powder
1/4 tsp salt
2 tsp sugar
2/3 cup milk
1 egg, separated
2 Tbl melted butter
1 1/2 squares semi-sweet chocolate (1 1/2 ounces)
3/4 tsp vanilla
-Add milk, egg yolk, and vanilla to dry ingredients and beat until well blended.
-Melt butter and chocolate together in microwave or double boiler. Stir chocolate mixture into batter.
-Beat egg white until stiff, stir 1/4 into the batter to lighten it and then gently fold in the remaining egg white.
-Pour a scant 1/2 cup of batter onto the heated heart waffle mold. (Hmm, the WM-4 isn't shaped into a heart??? Oh well, moving onward...)
Serve sprinkled with powdered sugar or cinnamon or topped with vanilla ice cream and chocolate sauce.
Posted on Feb 09, 2008
Jerseybob
  • 18 Answers
SOURCE: Waffle Iron Handle Broken - Need Replacement
Go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
Posted on Apr 02, 2008
SOURCE: waffle iron gets to hot -waffles stick
before you make your 1st waffle, spray it really good on top and bottom plate with PAM spray, once at the beginning is all it should take- good luck!
Posted on Mar 21, 2009
  • 4 Answers
SOURCE: Repalcement plates for Model 270A Toastmaster Waffle Iron?
Actually I have a Toastmaster 270A waffle iron. It is much better quality than the later toastmaster models, and it is basically identical to the Black & Decker model G48TD, which is still sold. You could get plates from Black & Decker. The entire iron sells for $50.
Posted on Jan 03, 2010
  • 27 Answers
SOURCE: waffle iron light goes on gut does not heat up...
The most common reason for not heating up is because of a blown thermal fuse. Apparently the controller lets the iron get too hot or the fuse is out of manufacturing tolerance - and so the fuse opens.
The green lamp is normally lit when the relay is off and dark when the relay is on. When cold, the relay normally turns on within a second of power-up (switched on). During power-up, the green (ready) lamp should flicker on, and then as the relay clicks, go dark. If the green (ready) lamp does not flicker, the fuse is probably blown.
The fuse is clamped inside the bottom clamshell in silicon tubing. A replacement fuse (240°C) can be purchased from many sources. The fuse should be re-attached to the wires with new all-metal crimp fasteners.
If the iron is getting too hot and blowing thermal fuses, you may be able to avoid this failure by keeping the thermostat set lower. (Turned a bit counter-clockwise.) If the waffles are no longer dark enough at the ready beep, you may have to use manual override by watching the steam and smelling the waffle.
Posted on May 25, 2010
Waffle iron light goes on gut does not heat up
May 19, 2010 | Waring WMK300 Professional Belgian Waffle...
Waffle plates stop heating
Apr 09, 2010 | Waring WMK300 Professional Belgian Waffle...
Lost manual and have no idea how temp. should be set
Thoroughly clean with warm soapy water, that is the surfaces where the waffle will sit then thoroughly dry plug it in have your mix remade when it starts heating up pour some batter on as a tester in the center of the lower grill close the lid and watch the steam when the steam starts to slow down your waffle is cooked depending on how done you like them you either take it out as the steam is slowing down or when there is very little steam, there is a lot of trial and error with a waffle maker and after using it a couple of times you will get the hang of it and know precisely or know closer to how long you like it to cook. Good luck and let me know how it works out.
goofballlovers
May 03, 2009 | Oster 3883 Waffle Maker
No instructions for used Sunbeam#3856 waffle maker
download here:
http://www.retrevo.com/support/Sunbeam-3856-manual/id/952ag122/t/2/
Apr 30, 2009 | Sunbeam 3852 Waffle Maker
Sep 02, 2007 | Waring WMK300 Professional Belgian Waffle...
WWM200PC Waffle Maker will turn on but does not heat up
I fixed one of these for a friend - the problem was an open thermal fuse. This fuse is located in the fixed grill; it is clamped to the grill and is covered by a white plastic sleeve.
The replacement part should be a 240°C/464°F 10 - 15 Amp thermal fuse. NTE sells a part NTE8242 which works available from Mouser.com for $1.41 plus shipping.
May 25, 2007 | Waring WWM200PC Waffle Maker
Kitchen Appliances - Others Logo
165 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
