Question about Frigidaire GLTF2940ES Front Load Washer
Door magnet The door magnet fell out where does it go?!!!!!!!!!!!!!!!!!
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Not familiar with your model. If I've got the right picture in my head either by the catch on the door or the centre top there might be a pocket for it to slide into...
Posted on Jan 01, 2008
How do i prevent the door lock from falling inside the door?
normally there is a clip that holds it in place .remove inner panel and using a magnet see if it fell to the bottom of door .
Mar 21, 2016 | Cars & Trucks
Door fell off. Can't put it back on.
Hello sir; on the door there have two pieces magnet when you close the door it will stick on the metal on the machine check it and find out these two magnet is there/
Jun 04, 2010 | Toshiba Office Equipment & Supplies
Fridgidare Model #LTF2940ESO won't start Error Message DDO
The code means the detergent door is open. There is a magnet placed inside the detergent door cover housing that has probably fallen out. This magnet completes a circuit when the door is closed. It usually happens when cleaning the compartment and can usually be found stuck somewhere on the washer metal body itself or somewhere on the path you took while taking it to wash it out. Take the detergent tray out and dissamble it by pushing open the plastic tabs that hold it together. Look for the small 1"long magnet. If there isn't one. take your tray assembly to a repair dealer and have them put a new one back in. It is just a few dollars and your problem will be solved.
Mar 20, 2009 | Frigidaire Washing Machines
Passenger door won't open from inside on 98 S70
You will need to remove the door panel from the inside and look for any missing links or bent parts that are causing the problem. Use a trim tool to get the panel off. Unscrew the arm rest. Have a magnet on a telescoping wand hand to fish any parts that fell to the bottom of the door out.
Jan 20, 2009 | 1998 Volvo V70
Door will not open on 1998 V70 wagon
You have a broken latch that you will need to access from inside the car. Remove the door panel carefully and have a magnetic pickup tool handy to fish in the bottom of the door for any parts that fell to the bottom when the latch let go. To cheat, remove the door panel from the rear door too and you can see what is missing from the broken one.
Jan 06, 2009 | 1998 Volvo V70
Washer - soap dispenser door - Magnet fell out... where does it go
I had the same problem. If you turn the dispenser so that the front faces away from you, look on the left side in the front. half way up there is a space with what looks like a plastic clip that might hold the dispenser to the front bezel. This actually holds the magnet, which can be installed without taking the dispenser apart. Be sure to install (pop in) the magnet vertically so that the long part of the magnet sits next to the right side of the dispenser opening (when viewed from the front) when the drawer is closed.
Oct 22, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire + ddo error code
Excellent solution. I had a similar problem. The trick is to figure out where to put the magnet. I had a hard time with that.
For those like me who might have difficulty finding the spot for the magnet, it goes on the right hand side of the detergent door. The easiest way to do it is to pull the detergent door all the way out of the machine and look at it such that the back of the door is facing you. The magnet fits vertically in a slot on the left side as you are looking at the door (right side of the doorwhen inserted in the machine) in the white plastic. It sits vertically and is held by a small latch. This is not obvious at all...
Jun 25, 2008 | Frigidaire GLTF2940ES Front Load Washer
My door lock magnet fell out and I don't know whee to put it back on the dispensr mechanism tomake t lock
I found it! If you are looking at the drawer from the back the magnet sits in the pocket in the far left. The plastic extends out like a clip (to hold the magnet in place). You depress that when placing the magnet in.
hth.
Kate
Aug 15, 2007 | Kenmore 43042 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
76 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
