Question about Smeg SUK62MFX5 Gas Kitchen Range
How do I replace the element in the main oven
The main oven doesn't heat but the main oven grill function does heat up! I'm not sure if this means the element is no longer working or if it is a problem with the control switch?
Make sure the power is off, then there should be two screws holding the element to the back wall remove them. Pull the element out until you can get to the wires, sometimes a wire will burn off at the connector, if that's the case replace it with a high temp connector if not disconnect both wires and do a continuity check on the element
Apr 14, 2015 | Ovens
How to replace element on my Hotpoint main oven BD31
If it is the main oven element, then undo the screws that secure the cover at the rear of the oven, remove cover, and you will see the round element there.
Undo screw securing element, and pull forward in to oven compartment.
Detach the wires, and fit new element.
Hope this helps you.
Please leave feedback.
Thankyou.
Jan 06, 2010 | Hotpoint Ovens
I need to replace the bottom element in my oven
You need to check the heating element for continuity and the thermistor for continuity. Use an ohmmeter or multimeter to check. The element should not be any reading over 24 ohms for a 220-250V supply and not over 12 ohms for a 110Vac supply. A good tip is to take digital photos of the job before starting on removing and testing wiring etc so that you can refer back to it if you have to replace any items or forget which wires attach to any particular terminal etc.
To test and replace the element:
  1. Turning off the mains power to the oven.
  2. Remove the lower back panel. Fan assisted ovens will have a coiled 2 or 3 turn element around the outside of the fan.
  3. Remove the 2 power connectors to the grill element if one is fitted.
  4. Check the element resistance reading on the main oven heating element and not the grill element.
  5. The thermistor or fusible link is located on top of the oven cavity if fitted and has two wires attached to it - most likely to be red and black or both white wires.
  6. Remove the earthing wire to the main oven heating element screw terminal.
  7. Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your oven. Do this from inside the oven cavity itself.
  8. Refit the new element (make sure it has the same mounting screw holes as the one you want to remove) then secure it.
  9. Reconnect the earthing wire to the element screw post.
  10. Make sure that neither of the element tags touch the chassis - check with a continuity tester of ohm meter and adjust if required.
  11. Reconnect the power cables to the main oven heating element.
  12. Reconnect the power cables to the grill element if one is fitted.
  13. Reconnect the power and check that the element works correctly.
  14. Disconnect the mains power again and replace the rear panel(s).
  15. Reconnect the mains power and recheck that the oven, and if appropriate the grill, functions correctly.
Nov 14, 2009 | Ovens
It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
Aug 10, 2009 | Smeg Ovens
Main fan oven does not work, conventional main oven does work
The element is where you said and yes it can be replaced without removing the oven. Remove the bacplate from inside the oven and you will see the element and fan. Remove the screws from the element and gently pull it forward then remove the 2 wires and keep hold whilst you fit the new element. Replace screws in the element refit the backplate job done.
Jul 29, 2009 | AEG U7101-4 Electric Double Oven
Main oven not heating.
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
Jan 06, 2009 | Zanussi Ovens
Oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Plz rate my solution
Thanks.
Dec 26, 2008 | Ovens
After effects of blown fan oven element on U1721
I think there is an inline fuse for each oven/element.
May 04, 2017 | Neff U1721 Double circotherm Electric Oven
Smeg SUK62MFX5 Gas Kitchen Range Logo
61 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
