Question about Pride Health & Beauty
My Pride colt XL8 mobility scooter has solid tyres can I convert them to pneumatic tyres
Solid tyres are on it at moment but I sure you can convert to pneumatic tyres
    Welcome Back:
    Visited the website for 2 consecutive days.
Hi yes think you can but you will need to replace all wheels and tyres
Posted on May 25, 2015
Testimonial: "Thank you Linda"
SOURCE: Pride Rally 3 Wheeled Electric Mobility Scooter manual
DO not ask FIX IT ALL THEY WANT IS MONEY
Posted on Nov 25, 2009
  • 225 Answers
SOURCE: I wanted to get a copy of a manual for the Pride
you can download from this site http://www.pridemobility.com/international/UK/ukownersmanuals.asp
plz rate me
Posted on Mar 09, 2010
Testimonial: "Brilliant and so fast. I am very pleased thank you so much. D."
petraman7
  • 1175 Answers
SOURCE: How do you raise the seat on a pride legend XL8 mobility
Hi...
There is a shaft pin under the seat
Pull the arms off ( temporarily)
Lift the seat slightly, remove the pin,lift to where you want it and put pin back in the hole
If this helps , please rate my help
Posted on Apr 23, 2010
  • 10865 Answers
SOURCE: pride mobility scooter XL8,Requires new
Here is the parts source I use and recommend www.monsterscooterparts.com/pridemobility.html
Joe
Posted on Sep 26, 2010
GodBlessU
  • 3513 Answers
SOURCE: pride legend xl8 scooter electrical harness
First take the control panel off, (panel that has the battery power display etc ) take care in doing to make sure you don't pull any wires off.
first check the wiring on the ignition switch, check the speed pot by moving it up and down,
Check the connections to the battery follow the wires from the battery to the Motor controller, normally marked B+, B-, then follow from the motor controller to the motor again checking the connections.
Make sure the freewheel lever stays in position
Please check the link bellow to diagnose your problem:
http://www.pridemobility.com/pdf/Owners_Manuals/INTL_Scooter/uk/UK_Legend_Classic_XL_8_om.pdf
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 04, 2010
How easy is it to change the brake lever and hydraulic reservior on a Pride Colt xl8
The brake lever IS the hydraulic reservoir. I wouldn't want to try replacing it since it requires a lot of dissembling of other components to get to the lever and brake lines.
Aug 11, 2016 | Pride Health & Beauty
Hi, i have a pride colt xl8, it makes a continuous beep when switched on, status led is fine , not flashing to show a fault, how can i stop this beep?
Make sure the disengage lever is in the correct position. If it is, then the position switch on the lever is bad.
Jul 22, 2016 | Pride Health & Beauty
Can I replace only the tire and not the whole wheel on my pride victory sport?
Yes you can. Are they solid or pneumatic tyres. You can buy from a Pride dealer or look on line. Details of tyres are written on the side of the tyre giving sizes.
Jun 08, 2015 | Pride Health & Beauty
Pride mobility victory XL front tyre wear
Is your track rod bent or out of alignment? Carefully buy the exact wheels with tyres and a track rod if necessary from dismantled Victory XL scooters (a good wheel with a good tyre about €30 - I've done that for my Pride Celebrity XL8 - it was a great success.
Jun 03, 2014 | Pride New Mobility Victory XL 4 Wheel...
How to inflate pneumatic tires?
You will probably find that they are infil tyres which are classed as solid, so they can not be inflated, your problem will lie elsewhere,ie :- something rubbing against the tyres.
Apr 03, 2014 | Pride Health & Beauty
Legend classic x18 measurements
hi, can you explain in more detail what information you require ?
The XL8 is one of the best 8mph mobility scooters out there, sadly it been replaced by the Pride colt brand..
Regards
Jan 21, 2013 | Pride New Mobility Legend 4 Wheel Scooter
Colt xl8 code 7 fault changed speed pot still cuts out
hi, can i ask you what the pot was like , a electronic one or mechanical one ?
If it's Electronic check there is a 24v - + plus voltage on the red and black cable. This is a common problem with these scooters.
regards
www.gewizrepairs.co.uk
Jan 07, 2013 | Pride Mobility Products Pride Legend XL -...
I have an xl8 mobility scooter that keeps cutting out and stopping dead, i then switch it off and on and it starts, could it be the motor?
My Pride Colt XL8 keeped cutting out (7 flashes of LED, Speed pot error) , checked all the cable connections up tiller arm as recommended by Pride technical support, worked for about a week, then problem returned. Eventually took to Pride dealer, with problem occasional occurring,they found it to be the lower tiller cable support bracket straining the cables connector intermittently and so removed the bracket, the problem then was solved !
Oct 19, 2009 | Pride Mobility Products Pride Legend XL -...
I have mislaid my Legend Classic XL8 manual & wish to know all the flash error codes
This page has a link to the users manual near the bottom:
http://www.cheapest-scooters.co.uk/8mph/pride-legend-classic-xl8-mobility-scooter.html
Aug 21, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Health & Beauty Logo
215 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
