Low water level on wash cycle just in to bottom of drum this cannot be right
  • Washing Mach... Master
  • 5,323 Answers
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
Posted on Apr 20, 2015
How to fix the spin lock
Slim chance are that the motor winding is broken, electric motor capacitor is dry or the control module is defected.
I would first make sure that the water level in the drum is below the level that will stop spinning from taking place.
If water level is high, check your filter and pump cover. make sure that no coins or other items are not blocking the pump.
If water level is low, you need to check your pressure switch (connected with a rubber tube to the bottom of the drum).
Good luck.
May 13, 2014 | Washing Machines
Stops
What cycle is the machine in when it stops??If it is in spin,check there is nothing trapped around the outside of the drum.Is the water level at the right height.?If level is low can also stop the machine.ope these suggestions help you.
May 08, 2012 | Washing Machines
Bosch Axxis WFL 2060 Front Load Washer - DRUM DOESN'T CYCLE
This seems to be a fault with the program controller unit or the water level sensor. The program does not advance further after the inlet is filled but operates the drain to exit water. Now the water level sensor must be checked as if this is not working in the stipulated time it will drain out. Also unless the water level sensor contacts on reaching of set level the motor must start.http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Mar 14, 2012 | Washing Machines
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
My maytag topload washer overfilled,
It isn't a sensor problem, it sounds more like your water level tube has pulled loose. This is attached to the outer drum itself. You can see it when you remove your front cover to the right of the outer tub. This tube uses the pressure generated from your tub water level to push air up to your water level selector, which has a rubber membrane that flexes and closes 2 contacts as the water level makes the rubber expand. If that tube is off, the water will just keep running.
Mar 18, 2010 | Maytag MAV3905EWW 13 Cycle Washer
Water drains during wash cycle. I have used this washer for many years without a problem. About two months ago I noticed that the water level in the drum was going down during the wash cycle. Last week I...
Take the drain hose out of the drain pipe and put it into a sink to test the machine
If that works make sure that the drain hose is being allowed to breath (ie let air into the main drain pipe so that the machine does not set up a syphon).
Jul 16, 2009 | Whirlpool Washing Machines
Washing machine will not fill with water just aggitates
Check the float bulb in the bottom of the tub and the switch below the tub. It may be stuck in the up position telling the computor that the water has filled. The timer is not supposed to advance to another process engagement until the water floats the bulb and changes the bottom switch position.
Jun 21, 2009 | GE WBSR3140DW Top Load Washer
Kenmore top load washer will not fill on rinse cycle
Hi, It does sound like the contacts in the water level switch are sticking. This switch is activated by presure not vaccum. You can try and bow into the hose leading to the level switch and see if it has any restriction but, it is more likely the level switch is going bad.
Do you have any problem on the initial starting of you wash cycle?
Let me know if this helps at all or I can answer any more questions.
Thanks
Vic
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
LG Tromm WM2277HW Water level to low
this is normal the pic are all photo shop water you clothes are clean right?
Feb 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water drips out of front door
There does obviously need to be water in the drum to wash or rinse the clothes, however it may be the water level is now higher than normal , check for any blockages and check any drain pump filter.If all o.k. it may be the door seal is leaking .If under g/tee call maytag for repair
Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
