We have noticed oil on the floor under our 9 month old top loading washer.
  • Washing Mach... Master
  • 5,323 Answers
May have a bad transmission seal need to remove cabinet and check closer
Posted on May 14, 2015
Our GE WSERR417FOWW washer is leaking (profusely)
Any solution to your problem? I am searching because mine started the same behavior tonight. I hope that you found a solution, and would be willing to share it!
Thanks.
Jeff jeffyr2@verizon.net
May 24, 2010 | GE WJRR4170E Top Load Washer
Oil on the floor under the washer
The gear case you are referring to is actually the transmission, and yes this is not a good sign. The seal has gone out. its usually cheaper to get another washer than repairing the old one. However if you would rather repair this one then i would try to shop around and find the best bargain.
Jun 14, 2009 | Kenmore 22622 Top Load Washer
Machine is usually very noisy ( like it was out of balance, but isnt) 90 percent time very noisy in the final expell of water, also some oil on the floor under center of machine ? this is a top load...
oil on the floor means your gear box is leaking
if it has been leaking. if it has been leaking for a while, it may have done major damage,and would be cheeper to replace the machine second hand than to fix.
if noise is happening while you are pumping , it may have a bra under wire or small coin in the water pump.
if it is sounding like it is out of balance it may have a support or spring broken or unhooked
as the tub is usually suspended by springs
May 05, 2009 | Maytag MAT12CSD Top-Load Coin Operated...
Oil leaking from washer
if it smell like wd 40..your transmission is defective,,need help replacing post question,,
Dec 27, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washer Shaking Violently on Spin Cycle
Yes, there is...The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength for leaking issues Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
Nov 24, 2008 | Maytag PAV2300 Top Load Washer
F1 error on Kenmore Oasis HE Quietpak 9
question is not is it repairable but is it under warranty ..most likely bad control bd under console
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
Washer
You bet, the tub seal is out and also the clutch and drive tub assemblies need to be replaced because like a drum brake oil has contaminated the pads. Did you notice that if you open the lid while spinning that it takes longer than seven seconds for the basket to stop? See the pic below, you need parts 1 and 5 plus the tub seal and center post seal.
Sep 30, 2008 | Washing Machines
Oil on floor under washer
Oil is generally not a good sign. It means that the tranny seal is blown OR it means that the tub seal is bad which allows water to enter the tranny (water is heavier than oil... if water gets into the tranny it will displace the oil and force the oil out)
This being a GE? I'd wager that a tranny job is in order. If the machine is less than 5 years old it's under warranty so you'd call GE at 1-800-GE CARES. If it's more than 5 years old? Your washer is no more than a boat anchor. Get a new washer, preferably a Whirlpool. The repair cost for a new tranny will out-weigh the value of the machine.
Hope this helps.
Mar 23, 2008 | Kenmore 22642 Top Load Washer
Grease or oil on floor under washer
try putting a new coupler in it its between the motor an the transmission
Mar 22, 2008 | GE WNSE5260D Top Load Washer
Oil on floor underneath washer
jeffnew The oil which you see on the floor is coming from the gear case. The gear case is not repairable and it has to be replaced. If your washer is less than 1 year old do not wait and call Whirlpool - it is under full warranty. If your washer is between 1 to 5 years old, then the part is still under limited manufacturer warranty but you are liable for any trip and labor charges. It could be much over $200.00. If you are handy and willing to save money, you can buy the part for less than $150.00 and replace it yourself. In that case, I can find the best deal for you and help you with step by step instructions. Gendos...post back
Feb 09, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
