Question about Garden
A picture of pig weed - Garden
A weed grows on our golf course and nobody seems to be able to identify it much less tell us how to eradicate it. I have taken some pictures. Is there someone I could send the pictures to for help?
not sure if this will help you out but have you tried looking in google images search under weeds and see if you can identify it that way.
Dec 15, 2016 | Cameras
WHICH FOOD DOES PIGS EAT
dougnuts are the prefered staple for the pigs in the USA
Doughnuts and coffee.
Apr 17, 2013 | Cars & Trucks
What is the compression on a poulan bvm200FE blower
It has lost compression, I just repaired two that were doing the same thing, Installed a new piston ring in both and they fired up and ran great on the second pull. Also check to be sure the bolts haven't backed out that hold the cylinder jug on to the block, this will cause it to lose compression and not start or run either. A new ring costs $2.00 and can be installed in less than an hour.
Sep 08, 2012 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
How to solve this problem in a different way,A FARM BOY TENDS PIGS AND CHICKENS IN THEIR YARD,hE COUNTED 21 HEADS AND 54 FEET. hOW MANY PIGS AND CHICkENs ARE THERE?pls.share me a strategy without using...
P = number of pigs
Then P is the number of pig-heads, and 4*P is the number of pigs-feet.
C = number of chickens
Then C is the number of chicken-heads, and 2*C is the number of chicken-feet.
Thus: 21 = P + C
Equivalently: 42 = 2*P + 2*C
Also: 54 = 4*P + 2*C
Thus (54-42) = 4*P + 2*C - 2*P - 2*C
Factoring: 12 = 2*P + ( 2*C - 2*C)
Reducing: 6 = P
Or, do it on graph-paper, with 'P' on the X-axis and 'C' on the Y-axis,
and each unit representing one animal (pig or chicken).
Draw one line between (0,21) and (21,0) (no pigs & 21 chickens, versus 21 pigs & 0 chickens)
Draw one line between (0,27) [no pigs and 27 pairs of chicken-feet]
and (13,1) [13 pigs have 52 feet, with 1 pair of chicken-feet]
The two lines cross at exactly one point on the graph, namely at the solution.
Feb 03, 2011 | Computers & Internet
Trying to connect my inspiron 15 to my toshiba 32af44 and i can't get a picture on my tv. I have bought a pig tail that goes from VGA(the lap top side) to s-video/audio-video cables(tv side) but still...
A simple pigtail won't convert VGA to S-video. The VGA output consists of separate RGB lines and horizontal and vertical synchronization lines.
If you have an adapter that really converts VGA (this output has no audio path) to S-Video and audio lines, then you probably just need to re-select the input through the TV's menu system.
Nov 21, 2010 | Toshiba 32AF44 32" TV
We just planted some ice plant on our embankment and the weeds and grass are overtaking it. What can we do?
Hallo there. The best is to weed it and mulch then with some clean woodchips etc. If it is just new grass weeds through among the plants with soil shacken off. It returns Nitrogen to the soil. DO not use Roundup because you will kill your plants as well. Have fun and do post a picture it will be great to see and advice can be specific. Regards
Aug 04, 2010 | Roundup "" Weed & Grass Killer
Squeals Like a Pig
REPLACE HORZ OUT TRANSFORMER
Nov 06, 2006 | GE 31GT740 31" TV
Garden Logo
551 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
