Question about Kenmore Dryers
Dryer was not getting hot. Pulled it apart element seems fine but it looks like it may of been overheating at one point. wires look slightly melted
Series 80 electric dryer
  • Kenmore Master
  • 5,323 Answers
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Posted on Mar 30, 2015
LEW0050PQ dryer works but smells like burning
In many machines, those elements, which are manufactured by "robots", are very cheaply made.
Rather than risk a fire, perhaps an investment of 20 - 30 dollars for a new element might be a good idea.
If you decide to do this, take a second look around for what specifically is getting so hot it is melting.
Likely the loose wire inside the element is doing that problem.
I should guess it is out of it's place and is melting an adjacent wire outside the heating element.
God bless your efforts.
Oct 05, 2017 | Whirlpool GEW9250 Electric Dryer
My Inglis dryer is overheating. How do I troubleshoot this problem? Thanks...
did you remove the metal duct to the left of the t-stat and thermal fuse?usually this gets filled with lint and will take out either the thermal fuse or the high limit,pull it off and clean it,also if the vent line is long,you can stick a leaf blower into the end of it and blow it out.most problems i find in dryers is from lint buildup.
Dec 06, 2011 | Whirlpool Inglis IP8200 Dryer
Hi, i am experiencing issues with my Kenmore 80 series , model no. 110.76832500, natural gas dryer. The issue seems to be overheating or a faulty sensor. The dryer heats normally and spins fine when first...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 06, 2011 | Kenmore Dryers
My maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
Oct 20, 2009 | Maytag PYE2300AY Electric Dryer
Recently the heating element was replaced along with a sensor. Since then it has been running fine, but about a month ago, the wire attached to the heating element corroded through. I initially thought...
more often than not those connections are loose and that jsut cannot be
but check your outlet voltage it should read 220 across the poles anything else it could eb trouble
Oct 06, 2009 | Whirlpool Dryers
Frigidaire dryer overheating
the other tstat is on front of blower housing..lift top remove screws at top of front panel from inside remove switch wires front lifts off ..be sure to ck vent first most dryers have thermal fuses that will blow if overheating does occur since yours seems to be working i would suspect vent first..if your concerned about dryer being hot to touch along top rear this is normal heating element is located just below console at rear
Nov 13, 2008 | Dryers
Dryer takes too long to heat
Okay...I'm not familiar with the configuration of Fisher and Paykel dryers. I am familiar with many other dryers, though. If the wires become melted this is usually caused by excessive current flow or a loose connection. When wires at a terminal become loose the intermittent connection can cause arcing which leads to the generation of heat, which causes the wire or connector to burn open. I have also seen heating elements short out against the casing and cause an excessive current flow problem.
Just so we're clear here, current is the force that causes electrons to flow. It is usually measured in amperes (or amps). What you are measuring is the voltage. Voltage is the difference in potential between two points. If you were to measure voltage between two points (such as through a simple wire coil) you would read 0 volts because there is no differnce in potential between the two points, as the coil should read a short. Now, if you have a RESISTIVE coil, or a coil that is open (broken) the same measure would yield a voltage reading, because there is now a difference in potential between the two points. Does this make sense to you? I know it can be confusing at times because you normally associate a voltage reading as something being good. In a nutshell: if you measure across a wire coil and read voltage - the coil is open. If you read 0 volts - the coil is good.
Who knows what caused the melted wire in your appliance. The one thing I am sure of is this is not normal. If you want to replace the relay to be sure, that is your judgement call. Relays do go bad. I would strongly recommend replacing the heating element as it appears that this model has a dual element that will still work (to some degree) if one side fails. Very ingenious design, by the way.
In addition, a lot of heat related problems associated with dryers are attributed to poor ventilation. A dryer requires proper air flow in order to work efficiently. If you have not cleaned or inspected your dryer vent ducting recently (or ever), you may want to. This is the source of many dryer malfunctions and can create a fire hazard or habitat for rodents. The rule of thumb when it comes to ventialtion is: The SHORTER and STRAIGHTER the ventilation, the BETTER. Every bend or rise you put in a dryer exhaust vent line creates resistance against the blower motor and possible choke points for lint to accumulate. The lint screens in dryers are not perfect and they do not collect ALL the lint. Simply cleaning the lint trap in many cases is not enough. Cleaning after every use, however, does cut down on the potential for your ducting to become clogged. If a dryer is allowed to run in a condition where it has poor air flow, the heating circuits will actually overheat to the point of failure. I mention all of this because I don't want you to replace parts only to have the appliance fail again due to poor ventilation.
I hope you find some of this information helpful. Let em know if you have any further questions.
Sep 12, 2008 | Fisher and Paykel DEGX1 Electric Dryer
What was your solution???
I also had this problem. I looked on this site and before even opening up the machine, ordered a new heating element. After I received the new heating element which came with a service booklet, I opened the top of my machine. I started to begin the process of getting to the heating element(a very long process) when I noticed a red wire connecting to the thermostat was burnt and its plastic insulator was melted. I then pulled out the thermostat (a very long needle) and took the advice of Jagjared and opened up the thermostat and cleaned it. I then cut the burnt part of the red wire and connector off and stripped a small amout of the red wire and attached a new insulated connector that I purchased at the hardware store. I then reinserted the thermostat(which took a while because its hard to find the hole that the needle goes into) and then connected both hot and ground wires. I'm not sure what Jagjared meant when he said that he was able relocate the thermostat because I'm only able to place it exactly where I pulled it out. Maybe he can explain?? Anyway, this was a very easy fix. I think I'm pretty handy but would consider myself only an amatuer when it comes to issues like this. I think I might have had a very difficult time actually replacing the heating element so I'm glad I didn't have to. Hope this helps you all.
Apr 13, 2008 | Malber WD1000 Front Load Washer/Dryer
Whirlpool Dryer extremely hot
If your dryer heating element does not cycle, you may have a bad high limit thermostat. The thermostat is used to regulate the internal temperature of the dryer and should cycle the heater on and off. The thermal cut-out is supposed to prevent the dryer from overheating and will blow like a fuse. It is a non-resettable device and must be replaced. It is strongly recommended that you replace both these components at the same time if you have found one of them to be bad. Both of these components will be mounted on the heater box housing. Usually the thermostat is the component closest to the ceramic terminals of the heating element. Most manufacturers sell these two components as a set. The dryer temperature at the exhaust on the back of the dryer should be about 140 degrees. If the temperature is excessive to the point where it is melting things and the cabinet is too hot to touch, make sure the heater is regulating as it should. I would use some extreme caution about using your dryer until you have this problem corrected. I would not use it under any circumstances if you are not going to be home, or if you are going to bed. Dryers are one of the number causes of fires in homes. Good luck to you and let me know if I can help any further.
Feb 18, 2008 | Dryers
Dryers Logo
55 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
