Question about LG Washing Machines
Hi I have a LG steam washer model f1406tdsp6 im getting error door not closed! But door is closed! Have changed door sensor still the same!
  • rdjagger Mar 28, 2015
    Double check connector is fully seated??
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
Check that the door and hinges are perfectly aligned with the door sensor as this could determine whether the sensor works properly or not.
Posted on Mar 29, 2015
dutchman05
  • 487 Answers
SOURCE: LG Washer LE Error
Yes this is the same Hall sensor as in the WM 2277
You can Order them HERE and have them within a few days.
Easy fix
Posted on Jun 19, 2008
  • 6 Answers
SOURCE: LG Washer dryer error dE
Unplug the machine.
Plug back in (maybe 10 seconds later).
Mine had several dE messages. Unpluged, waited 10 seconds, when pluged back in, it remembered which cycle and parameters I had it on, then locked the door and continued with no problem.
Posted on Apr 12, 2009
  • 15 Answers
SOURCE: On an LG 2277 washer. I try to start a load. I get
The switch is behind the front panel - to remove it, unplug the machine and:
1. Open the panel where the drain filter is (lower left side of the front panel)
2. Remove screw visible inside this area and remove the white molded plastic - also remove the screw behind that plastic.
3. Open the washer door and remove the spring loaded wire around the door gasket. Carefully pull the door gasket away from the panel push inside and then reclose the door.
4. Remove the detergent drawer and the two screws visible behind it.
5. Pull the top of the electronics panel away from the machine and lift up - place on top of machine or hook it out of the way
6 Remove the 4 screws that are visible holding the front panel to the machine. Left the entire front panel up about 2 inches and swing to the right
The wire connecting the panel to the machine on the right leads to the switch and door lock mechanism
Posted on Apr 27, 2009
  • 2692 Answers
SOURCE: Close door error on display when door is closed on WDM73
Th eswitch that teel it that door is open is out of position or bad.
Posted on Jun 19, 2009
ldsaunders
  • 31 Answers
SOURCE: We have a Kenmore front loading washer, model 417.
This could be one of two things. The actual door lock assembly there is something malfunctioning with the part that the striker goes into or that the control pannel is not registering that the door lock is actually closed. One is a $60 fix (the door lock) and the other is approx ($250). Unfortunatly because they are both electronic parts you can't just buy the cheap one put it in and if it doesn't work return it. Most stores have a no return policy on electronics/electrical parts.
Posted on Oct 03, 2009
LG front load washer has an error message of DE.
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 03, 2011 | LG WM-2277HW Front Load Washer
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
Model WFT65A31EC washing machine. Problem code DE . Door lid open error occurs when door is fully close.
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
John C
May 29, 2011 | LG WFT1071TP Top Load Washer
Lg washing machine WT - R852... LE error..bad burning smell
For LG washers 'LE' stands for Lock Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest, sorry ;-0(
John C
Apr 21, 2011 | LG Washing Machines
The letters LE are showing in the lcd even when door is closed
As you do not say the make and model of your washer I am having to guess it is an LG ;-0)
If this has assisted you please score accordingly.
John C
Apr 13, 2011 | Washing Machines
My LG TROMM washer is giving me an error code dE what does it mean?
Good luck,
John C
Apr 01, 2011 | Washing Machines
Lg model number wf-t1246tp; error code dE appears on display. however, door is properly shut
Good luck,
John C
Mar 09, 2011 | LG Washing Machines
I have a LG WM2277HW front loader washer . The door doesn't close all the way. It locks, but is kind of loose. I don't get any error messages, and it cycles fine(washes fine), but as soon as it starts...
If it is physically possible on your machine I would suggest that the door catch need adjusting, either that or it's broken but the door sensor still thinks it's OK ;-0)
Suggest a service call required ;-0)
Sorry,
John C
Mar 02, 2011 | LG WM-2277HW Front Load Washer
De error on my lg washing machine, machine is working fine, now i have a door error which means the door is not closed but it is closed i know there is a way to override the problem
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Jun 27, 2010 | LG WM-1480FHD Front Load Washer
Washing Machines Logo
50 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
