Question about Sewing Machines
The upper looper on my Bernette 334Ds overlocker will not move backwoods and forward hence no loops or stitches being made. How do I fix this?
  • Sewing Machines Master
  • 12,029 Answers
Has it been professionally cleaned and oiled recently? Even though the manuals usually don't provide instructions for oiling the inside of a serger, they do need it periodically because of all the moving parts. If you don't feel comfortable doing it yourself, then maybe a trip to the Bernina technician is in order. (Please if you try it yourself, be sure you have the proper oil, preferably Bernina serger oil--not Bernina sewing machine oil.)
Posted on Mar 30, 2015
Setting to do the edge small stitchng on a Bernette overlocker
Rolled edge? Upper looper = 4.5, Lower looper = 6.5 or more, Right needle=4.0, No left needle, Stitch length=1, Differential=N, Cutting width=1 to 1.5, No stitch finger
Apr 12, 2018 | Sewing Machines
Setting a elna 792d for rolled hem
I don't know your model in particular but generally this is how you set up a serger/overlocker to create a rolled hem. Remove the left hand needle and thread if 4 threads are threaded). Now there is usually a lever around the stitching area that you slide back towards you to remove the stitching finger back (disengaged). Then you adjust the top looper tension looser (about 2-3) and lower looper tension tighter (7 or 8). Leave needle tension at normal tension (5). You may need to move the cutting blade to the right too. The technique is to cut the fabric wider but with a narrow stitch so the cut edge rolls under within the stitching. You want the top looper thread really loose so it rolls right around underneath up against the needle thread, the lower looper thread needs to be tight and almost invisible, pulling the upper looper thread down. I usually do a few test runs and check the stitching. Once happy, I turn the stitch length right down to 1 so it is very dense. This uses a lot of thread up.
Ideally use a wooly overlock thread on the upper looper as this "fluffs" out once stitched and "fills" in covering the fabric edge completely.
some good images here
Sewing Basics Narrow Rolled Hems with Serger Sew Mama Sew Outstanding...
Jul 18, 2017 | Elna Sewing Machines
Singer 14T967dc serger runs but does not stitch
Hello Laura
Make sure that the lower looper thread is in front of and over the upper looper thread when threading the serger; when threading for overlocking.
Please let me know how this worked out for you
Happy serging
Feb 24, 2017 | Singer Sewing Machines
Why won't my sl370 work?
Hello Mary.
By the question, it looks like the lower looper is making loops? If so, check that you are using the correct needles for your serger and that the needle or needles is/are inserted correctly:
- needles must be all the way up into the needle shaft
- needles must face with the flat side to the back and the groove to the front
- use at least needle size 12/80, not smaller
Check these few items, if the loops are still not forming:
- re-thread the serger from the start, keeping in mind to thread in the proper sequence (upper looper, lower looper, needles)
- make sure that the lower looper thread lays on top of the upper looper thread and is passed to the back of the serger and then under the presser foot when threading
- make sure that the thread are securely engaged IN the tension assembly
- make sure that the serger is set for 3-thread or 4-thread overlock (i.e. that the upper looper converter is not engaged)
- check all tension setting
- stitch length should be around 2.5 - 3.5
Let me know how it goes.
Happy serging!
May 02, 2015 | Sewing Machines
Toyota SL3455DS overlocker tension problems
Did you thread in the proper order? Upper looper, lower looper, needles from right to left?
Oct 06, 2012 | Sewing Machines
I need a manual for a Simplicity Easy Lock Serger SL4300. I got it from a friend and she didn't have the manual. The loops are over the top of the material sticking out to far and I do not know how...
You can purchase a manual for this machine from the following link for $US14.99
http://www.sewingpartsonline.com/instruction-manual-simplicity-sl4300.aspx
I can't see it anywhere for free download unfortunately. But you may find that looking at a manual for another 4 thread overlocker may get you started. If you try this link http://www.singerco.com/accessories/instruction-manuals you can look at the free Singer downloads,
try this link for their 654 3/4 thread model http://www.singerco.com/uploads/download/555_14sh644_654-(e_s_f)-(new-led-version).pdf
it may give you some help now.
Essentially, to change the stitch width you can either move the lower fixed blade wider to cut less fabric or tighten up the upper and lower looper threads in order to close up the stitching.
Moving the blade usually means opening up the front cover door, putting pressure on the upper blade and swinging it up out of the way. Then you can adjust the lower blade, usally by turning a knob near to it. Sometimes this knob will be marked 1, 2, 3.
Adjusting the looper tensions is done by changing the tension dial settings for the thread needing adjusting. If its a standard four thread overlocker that produces a "marrow" seam it will have two needles and two loopers, upper and lower. Generally on most overlockers, the upper looper will be the second from right tension dial and lower looper will be right most tension dial - turn up one half number to tighten, or down one half number increment to loosen, then test stitch again. The needles shouldn't need adjusting too often.
I usually start with all tension dials on 5, test stitch, then adjust from there. Some fabrics will tunnel (pull in) if the seam is too wide so you need to either move the blade to the left and trim more fabric or loosen off the loopers. Or in the reverse, like you are getting, the threads will hang off the edge.
There is some good serger information on Debbis Cosgrove's pages www.sewing.about.com but if you have never used a serger, then getting the genuine manual is probably best.
Oct 16, 2011 | Simplicity Serge Pro SW432 Mechanical...
What setting are the three threads set on for a rolled hem on a singer ultralock l4sh654 and what is the lever by the plate for?
Rolled hemming on any overlocker is usually achived the following way. Right hand needle only.
Blade over to the right usually to cut wider than normal but you can vary this to suit the fabric and stitch width you want.
Thread in this needle and the upper and lower loopers. If you can source any, use woolly overlock thread in the upper looper, this fluffs out when not tensioned and covers the fabric to give the look of solid stitching. Change upper looper tension to about 2 and lower looper tension to about 6 or 7.
The lever by the plate is usually to control the little stitch finger where the stitches are formed, move it backwards and it should move back towards you?? If this happens, then you want it in the retracted (towards you) position for rolled hemming so the stitching is much smaller and the fabric can roll. Normally this stitch finger holds the fabric firm for the loopers to form the stitch over for your normal 3 or 4 thread overlock.
Now test stitch and see how it looks. Tighten the lower looper thread so it lays right beside the needle on the underside. You may need to then tighten or loosen more the upper looper, you want the upper thread to wrap all the way around to the underneath against the lower looper thread and needle.
The cut edge of fabric should roll to underneath inside your seam. Once you've got this happening, turn the stitch length down to 0.5 or so to close it right up tight. This uses heaps of thread so I usually test everything else, then close it up at the end to minimise waste.
Hope this makes sense, good luck.
Sep 22, 2011 | Singer 14SH654
I am trying to do a rolled hem using a singer ultralock 14sh654. Do I disengage the knife? The stitches are uneven and some are quite loose no matter how much I adjust the tension. I am positive I...
no, you need the blade in place and cutting to give an even cut fabric edge. Set up for a three thread using the right hand needle, take out the left hand needle. move blade over to the right so it is cutting wide. Most overlockers there is also a thread finger you need to change on the foot, or a little lever you flick to move this finger forward into the stitching area. Check this on your manual as each make is a bit different.
If you can source it, put wooly nylon thread into the upper looper (knot it onto existing thread and just chain it through, the knot should go through the looper eye fine). Now turn the tension on top looper down so it is looser and tighten up tension on bottom looper, so needle 5, top looper 2 and bottom looper about 7.
Now test serge, the fabric cut edge should be wider than the overlocking seam so the fabric rolls under inside the stitching. Adjust the two looper threads so that this is happening, you want the bottom looper thread to nest right up against the needle stitch and the top looper thread to wrap all the way around too.
Once you've got this happening, turn the stitch length down to 0.5, to close the stitching right up. On some fabrics you'll need to adjust the differential feed too if the fabric is "waving" a bit.
Uneven stitches or sometimes loose when serging could indicate that one of the tension devices is faulting, so if this machine is not new and its doing this, it could need a service. Can you get a regular smooth three or 4 thread seam out if it???
It is always good to just recheck the threading path, make sure the thread aerial is up and that a thread hasn't got caught back on the thread stand somewhere if you're getting something wonky happening, threads stream off overlocker cones through the machine so anything wrong in the thread path will throw off the stitching.
Jun 25, 2011 | Singer 14SH654
I need to switch to rolled hemming and can't find my manual
Is this on a serger?
Rolled hemming on a serger is usually achieved by doing the following: thread up for three thread overlock using right hand needle. Move blade to the right to trim fabric wider (so it rolls inside the seam). Put woolly overlock thread through top looper (this gives a smooth finish to the rolled hem). Loosen off top looper and tighten up bottom looper so the bottom looper is up tight against the needle thread on the underside. Test serge to get the stitch right, then turn the stitch length down to 0.5 to close it up tight (this uses loads of thread so I usually get everything else right first, then make this final adjustment). On my Bernette 334D tensions are R-Needle - 5, Top looper 7-8 and bottom looper is 3-4. Stitch length 0.5, differential zero.
And usually you flick a small lever or change a little finger on the foot or plate where the stitch forms, there is some variation here between models. Early Elna L4 and L5 locks you had a little finger you changed with a screwdriver on the pressure foot. Bernette has a little slide mechanicism near the blade that you flick forward to engage.
Hope this is of assistance to you - I went for a 2 hour lesson on my serger when I bought it and then came home and repeated all the techniques shown and then made notes and stapled all the stitch samples into a notebook so I could remember how I did it.
Also there are some great books on Serging, Nancy Zieman is one name that springs to mind. Or try You-Tube, she has some videos up there too showing different techniques.
Apr 27, 2011 | Janome Sewing Machines
I want to know which knob I use to make the stitching narrower
there are generally two variable controls .. one adjusts the stitch length (distance between stitches measured in stitches per inch) ... the second is stitch width .. that adjusts how far the zigzag moves left and right .. thats usually just a number from 0 to 10 or so .. 10 would be maximum width .. 0 would be used for straight stitch ..
so you need to adjust the stitch width control to make the stitching narrower .. the controls are called different things on different brand sewing machines .. if you have the brand and model number then there may be instruction booklets available ...
Jan 04, 2010 | Sewing Machines
Sewing Machines Logo
122 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
