Question about Home Security
Digital keypad Sentry safe handle snapped off. how can I open the safe?
    Top Expert:
  • 14,162 Answers
Posted on Apr 25, 2016
geemarie
  • 876 Answers
SOURCE: SENTRY S3877 SAFE
Go to this site:
http://www.sentrysafe.com/products/productDetail.aspx?s=53
click on dowlnload the manual. If you do do not have adobe acrobat reader, you can go here to download it for free
www.adobe.com/acrobat
On page 4 of the manual you will find a section dealing with restoring your pin number which is what you need to do. When you change your batteries your pin number is lost.
Good Luck and Thank you for using Fix YA!
Posted on Aug 21, 2008
SOURCE: Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
  • 42 Answers
SOURCE: sentry safe
You want to be sure not to suffer a "lock out". Now, that'll cost you a few bucks -- probably more than the safe is worth...
I am quite familiar with combination lock safes, and I know that one cannot hurt them by locking them whilst the door is open, and I'd guess that digital ones should not be damaged by locking them open either.
After all, for a large safe that isn't being used, I prefer to lock them open.... no one can get stuck inside one and if I forget the combination, I can get it easily directly from the lock itself.
I'd look for a sensor that is confused. There must be several inputs to the lock that tell it that all is right with the world --- Above all, do not put anything into the safe until you have fixed the problem or decided to 'deep six' the safe.
Regarding the error message. Does the error light blink four times or in some pattern? If there is any pattern to the blinking it could be a message that tells you what is causing the problem.
If all else fails... I'd suggest a locksmith. There is something going on inside that lock that isn't right.
Calling a locksmith may not be cost effective, since he has to make money, and the safe itself isn't all that high qualtiy or expensive to begin with.
Posted on May 13, 2009
  • 736 Answers
SOURCE: sentry 1610 safe. cannot open
there are either 4 AA batteries or in some cases one 9 volt battery that has to be replaced .. in some models you slide off the area under the keypad to get at the battery .. .. as the battery ages it has enough current to operate the display but not enough to operate the unlocking mechinism .. once you have it open make sure the mechinism works freely .. if not it may need some non gumming lub .. dont use WD 40 for this ..
Posted on Sep 19, 2009
Testimonial: "I think this advice was directly helpful. However, I couldn't wait for the answer. Somehow, the same code worked if I tried one more time. "
Have key and code...safe will not open
Sentry Safe not unlocking - YouTube
? 0:36
https://www.youtube.com/watch?v=4mbtSUAoS6w
May 8, 2013 - Uploaded by 1diazsantana1
When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
Opening a Sentry Safe with a Rubber Mallet, some WD-40 ...
idoneitmyself.com/.../opening-a-sentry-safe-with-a-rubber-mallet-some-...
May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
Jan 05, 2016 | Sentry Safe Fire-Safe .8 Cubic Ft....
I changed the battery, but my sentry 1610 is not responding. Look like the whole keypad is dead. Can you please tell me is there a secondary battery for the keypad?
Could be the battery holder is bad. A1 Locksmith Burlingame CA 94010 have Sentry safe locks, keys, battery holders, battery door covers, and door handles. But only a small supply in stock.
Dec 05, 2012 | Sentry Fireproof Safe
Somehow can open my sentry s3877 with the keypad.
A Safe and Vault Tech Will confirm that once you change the batteries the user code will erase and you will now have to enter the factory default that is in the owners manual and then use the programing instructions to program a new user code.
Jan 07, 2010 | Sentry Fireproof Safe
Sentry 1610 safe. cannot open. I have been using 5 didgit code for many yaers. All of sudden, it won't open. I see green light after pushing 5 digits. I hear the familar sound. But the handle won't turn.
Sep 19, 2009 | Sentry Fireproof Safe
Sentry 1610 safe - battery is dying?
I have 2 Sentry 1610 Safes. A fresh alkaline battery MAY open the safe once (maybe twice), and then the same problem. I have a variable DC power supply that I hook up to the battery terminals, set to 9 volts and increase the current until the keypad responds & the deadbolt releases. Sentry has no solution for this problem, as this model is too old & they have no parts or troubleshooting. If you know someone with a small DC Power Supply, you can get your safe open / closed.
Mar 29, 2009 | Sentry Fireproof Safe
My sentry safe will not open after entering the code it reads "err"
You have to press the program / enter button after you enter the code How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
Aug 10, 2008 | Sentry Fireproof Safe
Mar 29, 2008 | Sentry Fireproof Safe
Forgot how to open my fireproof lockbox
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
Nov 03, 2007 | Sentry Fireproof Safe
Home Security Logo
128 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
