Has become very noisy on spin - Washing Machines
  • robert Mar 28, 2015
    Make. Model. Age.
  • Washing Mach... Master
  • 5,323 Answers
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket.
In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Posted on Apr 20, 2015
3 Suggested Answers
SOURCE: very noisy neptune 6500 in spin
try balancing the feet on the washer
Posted on Aug 05, 2009
mayomiayo
  • 60 Answers
SOURCE: what does F7 mean, why has it become very noisy on spin cycle and leaks occasionally?
THAT MEANS IT REQUIRE ANEW BEARINGS AND OILSEAL......THAT MEANS U NEED A SPECIALIST TO REPLACE THEM.
Posted on Feb 24, 2012
My front loader Ariston A1636S. Is washing and pumping water out very quiet, but when it comes to spinning has become noisy, and perhaps describe as a grating noise. But no strange smells.
Most common causes of noisy spin are something has found its way between the drum and its casing or the heater has come adrift from its fixing and is rubbing on the drum
Mar 31, 2015 | Ariston Technologies Washing Machines
What does F7 mean, why has it become very noisy on spin cycle and leaks occasionally?
Feb 24, 2012 | Washing Machines
When on spin cycle makes noise & water comes out under machine. How do you take off back of machine to get to the pump area ?
Possible drum bearing problem , seals leak into bearing chamber and beyond , bearings seize and become noisy. Pumps get noisy but rarely leak.
Nov 09, 2009 | Washing Machines
Hotpoint WF220P has become very noisy during spin, especially at high revs. Can it be worn brushes or motor, or bearings? Otherwise all is OK.
Remove drive belt, and spin drum by hand, if it feels rough or noisy, then the main drum bearings are worn.
If no noise from drum, could be a motor prob.
Please rate ,my solution.
Thanks.
Nov 02, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Whirlpool Duet GHW9150PW1 very noisy when spinning
its most likely bad bearings and basket. usually it happens over wear and tear or overloading.
May 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front load washer that's noisy when it spins
on most kenmore front loader after some time the bearing start to wear and the washer will get louder and louder,it is a big repair job!-mike
Mar 23, 2009 | Kenmore HE2 Plus Front Load Washer
Very noisy neptune 6500 in spin
rear bearing problem buy new one when you cant stand noise
parts are about 200 and 3-5 hrs lbr maytag charges 500-600 to repair. good luck
Apr 20, 2008 | Maytag MAH6500 Neptune Front Loading...
Danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 13, 2008 | Danby DWM99W Top Load Washer
Noisy spin dryer
make sure the washer is level.there's locking nut for each legs sometimes thy become loose and the unit becomes unlevelled after a while. Level the unit side to side and front to back and relock the nuts by tightning it against the bottom frame. If thats not the problem,run it on spin only with no load and see if it would do the same if it does'nt then your problem could just be improper loading. make sure you have enough load to cover the drum when it spins.Other wise you may have shock/spring problem but very unlikely
Jul 22, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
