Question about Bose Car Audio & Video
Wiring diagram for 1993 infiniti j30 - Bose Car Audio & Video
3bachelors
  • 52 Answers
SOURCE: Engine light on Infiniti J30
Could be....I would first very simply check the gas cap. A loose or cracked gas cap could cause an O2 (oxygen) sensor to react and light up your "check engine" light. if the cap is indeed tight it may be an actual faulty sensor, in which case I would have your ODB plug under the steering wheel read by the infiniti dealer. Devoe infiniti is great here in Naples, FL!
Hope this helps,
NGK
Posted on Sep 03, 2008
3bachelors
  • 52 Answers
SOURCE: How do I remove the
Generally speaking there are 2 or more hidden screws. either along the edge, or beind a cover, on or near the handle. Remove those, and the rest is held in place by plastic anchors, which can be ppooed out by pulling away from door, and then up from the window once all are removed.
SOURCE: exchanging infiniti j30 parts
I've only had experience with struts, running lights, trunk gaskets and various under-hood brackets; so far everything has been interchangeable. It may not look EXACTLY the same, but it fits. Hope it helps!
Posted on Oct 23, 2008
SOURCE: need to know where my relay is on my 1993 j30 infiniti
I had the same problem, as have many others. It turned out to be the relay switch, as it has for many others. It way does, below the engine on the wall below the engine and the driver.
Posted on Feb 02, 2009
pingman37
  • 58 Answers
SOURCE: Need to add power steering fluid for 1997 Infiniti J30
There is no reserve. You will need to add it at the dipstick.
Posted on May 05, 2009
Where is the thermostat location on my infinity j30 1993
Chris, 1993 infiniti J30 thermostat location. Follow large radiator hose to intake manifold by water pump, at the end of the rad hose is the thermostat housing. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Replace the Thermostat in an Infiniti J30 eHow
Thermostat Replacement Write Up
Infiniti Thermostat Replacement
Aug 28, 2016 | Cars & Trucks
Where is the fuse for the radio on j30 1993 infiniti?
Driver side foot area on the left next to the parking brake open the panel and a diagram is on the cover showing you where the fuse is for the radio.
May 27, 2014 | 1997 Infiniti.5 J30
What does it cost to tune up a infinity j30
If this is just a basic tune up then the cost is about $135.00 (varies with local hourly labor rates), more if the distributor cap and rotor are in need of replacing
Feb 09, 2012 | Infiniti J30 Cars & Trucks
I replaced the battery in my car and my stereo quit working. I have a 1993 Infiniti J30
You will have to phone an infinity dealership and get the radio code unless it happens to be in the owner manual.
Mar 02, 2010 | 1997 Infiniti.5 J30
J30 injector problem?
maybe damage the wire when disconnect to change injectors,
Apr 18, 2009 | 1997 Infiniti.5 J30
My rear driver side window stopped working!
Sounds like it could be a short in your wiring. Or else it could be a fuse. Start there, check your fuses~~~
Mar 11, 2009 | 1997 Infiniti.5 J30
1993 Infiniti J30 starts, but run really rough and then stalls
sounds like the guy has put the timing belt back together a tooth off have some one check this for you
Infiniti j30 interchangable parts
It depends on what parts you're thinking of. Some will carry over between years, and some may not. Minor restyling on the exterior and lighting may present some difficulty, and the 96 is an OBD2-emissions controlled engine, so its ECU, engine bay harness, and many sensors may not work on the earlier car (which is the much less-stringent OBD1 emissions control).
Sep 15, 2008 | Infiniti J30 Cars & Trucks
Hope this helps,
NGK
Aug 22, 2008 | 1997 Infiniti.5 J30
Car Audio & Video Logo
60 people viewed this question
Top Bose Car Audio & Video Experts
xxxxxx xxx
Tina Robinson
_ST_
Are you a Bose Car Audio and Video Expert? Answer questions, earn points and help others
