How to remove the top cover of the cabinet .
I have removed the back brackets and tried to slide to the rear of the unit but it doesn't slide.
  • rdjagger Mar 28, 2015
    Make. Model
  • Washing Mach... Master
  • 5,323 Answers
Try these pics
How to remove the top cover of the cabinet . - remove-top-cover-cabinet-fgv1ctnzjgewe3hu2qpqylbk-3-0.jpg
Posted on May 08, 2015
Amigaman
  • 248 Answers
SOURCE: How do I remove the cabinet on a Kenmore Model 11022882101 top loading washer?
You need to remove 2 screws in console. They might be in back, on ends or in front ends. If you can't see any, they are under the console end caps. To remove end caps, pry off by pulling caps towards outside from center part of cap. Pry toward you and towards outside. Then remove 2 screws and flip console up and back. Unplug connector to washer cabinet. Remove 2 gold colored clips by inserting straight screwdriver in them and prying back. Make not of their position first. Now tilt cabinet toward you and slide forward and off base.
To replace, tilt cabinet and slide under frame in front. Now lower cabinet on to frame, making sure cabinet is on frame on sides. Re-install clips by placing them in position and pushing down with palm of hand. Plug in connector, lower console and install screws.
Posted on Nov 22, 2007
  • 566 Answers
SOURCE: How do I remove the back cover on the washing machines?
removed screws from top / bottom and sides? then pull top pcover back slightly and lift at rar to clear back cover manouver the flex drain pipe as you remove panel ?
Posted on Nov 01, 2008
SOURCE: removing cover assembly on GE top load washer
Is your washer a GE Profile Harmony? Do you want to know how to take the top off or the top of the agitor (pulsator)? The top of the washer has four screws in the back top behind the screen once you unscrew them the front of the washer has two clips one on each side and you have to kinda tap it with your palm to get them to pop.
Posted on Jan 13, 2009
  • 686 Answers
SOURCE: removing the washer top to replace the washerplate
DO YOU HAVE AN EMBLEM IN THE MIDDLE AT THE TOP OF THE FRONT CABINET? IF SO THAT IS THE EMBLEM YOU REMOVE. TAKE A PIC AND EMAIL IT TO ME A GOOD CLOSE UP BUT NOT TOO CLOSE OK. I LOOKED AT THE PIC ON YOUR REQUEST BUT THAT DOES NOT MEAN THAT IS WHAT YOU HAVE.
Posted on Apr 17, 2009
MNTECH
  • 1543 Answers
SOURCE: lp conversion for LG dryer
After removing the three screws which pass through the L bracket into the back of the dryer:
Stand in front of the dryer and (using the palms of your hands) give the top a sharp push back on the dryer top at the left and right side of the top. The top should slide back 1 to 2 inches. Now lift the top off.
If you post again with further questions, make sure to post under the model number you have. (you posted using a combo washer / dryer, and stated you are converting to LP, which combo units are not gas.)
Posted on Apr 18, 2009
Need to replace a baffle that broke off . MED9800TKo model baffle broke off insde on the dryer drum
Remove the top panel to access the outside of the drum where the baffle securing screws are found. Remove the three hex-head screws from the rear flange of the dryer's top cover the lift the rear of the cover and slide it back so the tabs clear the catches on the bracket and remove the cover from the unit.
Turn the drum until the baffle screws are on top then remove the screws and the baffles. Install the new baffles then the top cover. Make sure that the tabs slide under the bracket catches when you reinstall the top cover. The top cover screws have nylon flat washers on them. Be sure to use these screws when you reinstall the top cover.
Jul 18, 2011 | Maytag MED9800T / MED9800TQ / MED9800TK...
How do you install a thermal fuse kit on a Magic Chef CYE4000AYW. Unlike other models it doesn't look like you can just take the back panel off; do you really have to take the top and back off?
The thermal fuse kit is accessible from the top of the dryer. Disconnect power and using a putty knife, release the two spring clips holding the top cover to the cabinet. Insert the putty knife in the seam between the top cover and the cabinet at about 4 inches from the sides. Lift the top cover when the first spring clip is released while releasing the second clip then lift the top cover to the rear of the dryer.
The high-limit thermostat is located on top of the heater housing at the rear of the dyer. Remove the screw that secures the high-limit thermostat bracket and replace the thermostat.
The thermal fuse is located on the right hand side of the heater housing and is mounted on a bracket. There's a 1/4" hex-head screw that holds both the heating element and thermal fuse brackets. Remove the screw and the thermal fuse bracket can be lifted off.
The thermal fuse bracket has two locating tabs, one at the bottom and the other is half-way up. Lift the bracket to clear the tabs then remove it and replace the thermal fuse. Reinstall the thermal fuse and high-limit thermostat brackets in reverse order of the removal steps. Press down on the top cover against the cabinet to reengage the spring clips.
Apr 05, 2011 | Magic Chef Dryers
How to open the top of a Maytag MDE9206 dryer? Makes loud noises want to investigate
The top cover is attached to two hold down brackets, one on each side, and it can only released once the front panel is removed. Disconnect power then open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket.
Swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Feb 10, 2011 | Dryers
One of the paddles in the dryer tumbler fell off. How hard is it to open the lid and screw them back on?
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. The baffle securing screws can now be re-tightened or reinstalled. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Oct 04, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do you open console on whirlpool LSN2000JQ2 TO REPLACE LID SWITCH? Do I have to do from the rear or front? There seem to be two plastic tabs on both sides in the back. How do they comes off?
DO NOT REMOVE PLASTIC TABS!
Access is from the front. Remove screws located in the rear corners of the side trim pieces of the control panel. Control panel slides forward and then you can swing it up. You'll see metal brackets on both corners attaching the rear wall to the cabinet. Remove brackets. Disconnect plug with 3 wires on the cabinet. Pull cabinet up-forward.
Jun 02, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Removing top of dryer to get to the drum
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum. But before that, the front panel must be removed first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top cover lip.
May 24, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
How to replace the ignition spark ignitor for Maytag MDG9700AWW - Thanks.
Access to the igniter (part #35001100) requires the removal of the top cover, console, and the front panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the top cover by removing the two 10-mm screws attaching it to the rear of the dryer then slide the cover rearward and lift it off the dryer cabinet. Take note of the notch in the top cover engaging the screw on the cabinet during reassembly.
Remove the two screws mounting the heater PCB board to the cabinet then disconnect the black and white connectors from the board.
Remove the four screws securing the console to the cabinet then rotate the console down and remove it from the dryer.
Remove the four screws securing the top of the front panel to the cabinet and the two screws at the lower portion of the door opening. Once the screws are removed, lean forward the top of the front panel and disconnect the interior light harness. Lift the panel to disengage the three tabs securing its bottom to the base of the dryer and move the panel away.
Disconnect the igniter harness and remove the single screw attaching the igniter to the burner assembly. Slide the igniter back and remove it.
Install and secure the new igniter then make sure to reconnect the harness. Reassemble the front panel, console, and the top cover by reversing the given removal steps above.
Mar 26, 2010 | LG DLEX3001P Dryer
TRYING TO TAKE MICRO OFF THE WALL AND IT WON'T BUDGE. NEED INSTALLATION INSTRUCTIONS
There are two phillips head screws holding the unit in from the top and a slotted bracket on the wall or cabinet back. Usually you can remove the screws from the cabinet directly above the unit. Support the microwave from the front while removing the screws. CAUTION ! Use two people! While holding the unit level,lift up underneath the rear of the microwave to release it from the slotted bracket in the back and bring the microwave straight out.
May 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker installed over stove-----need to remove it
Her is a link that I hope with work that shows the bracket and how it was installed.
PDF]
  JVM1850BH/CH/SH/WH – GE Spacemaker Over-the-Range Microwave Oven File Format: PDF/Adobe Acrobat - View as HTML
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
1985 GE Microwave Spacesaver Uninstall
A possible solution:
I was facing the same problem with my (1998?) GE JVM48006. In this models case, the microwave was housed in a support cabinet that was fastened to the wall behind. First, I removed the phillips head screws behind the louvered vent above the microwave. Then, I removed the screws of the slanted bottom panel that give access to servicing the stove top lights (underneath the unit) which were integrated into the support cabinet (separate from the microwave itself). On the right side was an electrical wire harness hidden behind a cover that had to be unplugged (similar to a car wiring harness). Then, I removed (4) 5.1/2 inch hex head bolts that secured the unit through the cabinet above. Now I was able to slide the microwave out towards the front (with some rocking back and forth). All that was left then was to remove the support housing (fastened to the back wall).
Aug 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
