Question about Dell Office Equipment & Supplies
Using a Dell projector, is there a way to get it to project white without any inputs, versus the standard blank blue screen? It goes white when searching for inputs, but switches back within seconds when no input detected. I'm trying to use this white light for a non traditional application at work.
  • Dell Master
  • 3,960 Answers
Since you did not provide the make and model, you will have to pull out the manual and check the settings. It may provide you with a setting change for the background color. Perhaps you can connect it to a computer, open an new blank document and project the blank image to get your white light.
Posted on May 11, 2015
SOURCE: toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Posted on Aug 26, 2007
Marrie
  • 563 Answers
SOURCE: 3M MP7740i Projector no input is detected
Hi mrus821
If the signal won't go through you will have to either have your Mainboard Repaired or Replaced.
This is unfortunatelly a common Mainbaord problem , and the above is the only way to get it fixed.
Posted on Apr 23, 2008
Marrie
  • 563 Answers
SOURCE: System shuts down
Hi labiancad
Were you able to see if all of the fans are working ?
Is there any of the LED's on the Projector flickering and what colour if they are ?
Posted on May 28, 2008
projdoc
  • 2237 Answers
SOURCE: Infocus X1 picture freezes and dissapears and then comes on again
your display settings may be off, so change settings to factory reset and you may have to drop the resolution on your computer. you may also have a bad cable, so try a different cable.
Posted on Jul 17, 2009
projdoc
  • 2237 Answers
SOURCE: Projector shuts off within 30 seconds of power on
is the led lit on the top of the projector? what colors?
green is ok.
red flashing in sequence:
2 times- lamp hours exceed 200 hrs. replace lamp.
3 times- lamp failure. replace lamp.
4 times- fans not working. remove obstruction or replace fan.
5 times- temp too high. clean thoroughly.
solid red- undiagnosed error by projector. possible power supply or ballast.
also make sure the lamp door switch is working.
Posted on Aug 07, 2009
Is there any way that I can connect my new WONDERWALL projector to my laptop computer
The wonderwall does NOT have the proper inputs for use with a computer for good reason.
A wonderwall projector is NOT a projector that is good enough to be used for movies or games and it would be embarrassing to make a presentation on one. It has WAY less resolution than even old fashioned standard definition TV. Standard def Tv is 720x 480 pixels at 30 cycles. A wonderwall is 480x 240 pixels which is appx. the resolution of a screen on your phone. That's 345,600 for STANDARD def versus only 115,200 pixels for a wonderwall. When you blow that up to 3 feet wide, it'll look pretty mediocre. We have one just like it and we use it to project VHS onto our garage during Halloween and Christmas.
It IS perfect for fun and might be ok to watch old VHS tapes but watching a dvd on one is horrible.
Your 1440 has VGA outputs. A wonderwall has AV (red, white yellow) inputs. You can buy a vga to AV adapter for less than 10 dollars almost anywhere. You don't even need to go to a specialty electronics store.
Dec 17, 2012 | Discovery Channel Discovery Expedition...
I have a VT465 and the projection back ground is yellow and I can't get it to be white
If you are talking about the actual image that is coming from a laptop being yellow instead of white, then this is caused usually by a bad signal cable running between the computer and the projector.
To be more specific: All colours in a projector get made up in some way between red, green and blue. White is all of these colours at maximum, yellow is made by red and green at maximum but no blue. If your image is Yellow when it should be white, then the blue signal information is not reaching the projector. This can also happen within the projector or computer itself but is less likely. If your using a VGA cable (15 pin cable) then blue is run through pins 3 & 7 (positive and negative respectively), see if your cable is either missing these pins on either end or if they are bent, although it's more than likely within the cable itself. You can test this theory easily by trying to put something blue on screen, if the blue signal isn't getting through then it'll appear black.
If changing the cable doesn't solve the problem try testing the computer by trying to use a different one, and test the projector by plugging in a monitor or another projector.
If you are getting a yellow screen without sending signal and just trying to get the "no signal" or "no input" screen white, then this won't be the case.
Mar 24, 2011 | NEC Office Equipment & Supplies
I'm noticed white spots on the screen and from the past two days its getting worse. kindly suggest me and give me step to step cleaning process if i can do it myself.
check if the white spots are well defined square pixels on the screen. If they are then you may have pixel failure.
  • After turning on the projector, press "+" and "-" buttons on the control panel simultaneously and release the buttons when screen goes blank.
  • Press "+" and "-" buttons again to exit the diagnostic mode.
  • While in Self-diagnostic mode, the screen will run a seven-color-cycle test as following: "Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow." Ensure that the colors of the test pattern are correct.
  • If you believe it's dirt then disconnect from the power and undo the screws underneath the unit. lift the cover over the front of the machine and carefully remove the pcb to get at the optics. don't touch and glass bits with your bare fingers. clean the optics bits as necessary with a camera dust blower bellows. best of luck.
    Mar 10, 2011 | Dell 3300MP Multimedia Projector
    Hi there, my dell projector 1800mp is not projecting an image on screen and it only black lines across. what should I do to fix it?.
    simultaneously for 3 seconds and release the buttons when screen goes blank.
    2 Press "+" and "-" buttons again to exit the diagnostic mode.
    3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
    following:
    Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
    not displayed correctly.
    Mar 02, 2011 | InFocus LP 250 Multimedia Projector
    It doesn't show red color. i tried to do factory reset. but still problem.
    1.After turning on the projector, press "+" and "-" buttons on the control panel
    3 While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
    following:
    Contact Dell if the colors are not displayed correctly.
    Mar 01, 2011 | Dell 2400MP DLP Projector
    Dell 2400MP out of range with vga connection
    make sure that the resolution matches and that the laptop and the projector are both on vga and not composite. you can also reset the projector settings to factory default to start from the beginning.
    Aug 18, 2009 | Dell 2400MP DLP Projector
    Pink shade more in NEC WT-610 PROJECTOR
    Using the on screen menu, check the hue or wall color settings. [Hue]
    Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
    Video, Component and TV standard inputs (not valid for RGB and DVI digital).
    Using the Wall Color Correction [Wall Color]
    This function allows for quick adaptive color correction in applications where the screen material is not white.
    The following nine options are available.
    • OFF • Blackboard
    • Blackboard (Gray) • Light yellow
    • Light green • Light blue
    • Sky blue • Light rose
    • Pink
    Dec 30, 2008 | NEC WT610 DLP Projector
    Sanyo plc-su50 projector - can't get it to work
    Please select correct input in menu of projector, that is Computer/ PC, like that...
    Aug 02, 2008 | Sanyo PLC-SU50 Multimedia Projector
    VT45 Projector: Blue pixels throughout screen
    If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
    So, the problem is in the cable - solution is replace cable.
    Feb 28, 2007 | NEC VT45LPK Projector Lamp for VT45
    123 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
