Washing machine show te2 will not drain or spin
Washing machine The Katin flash TE2 will not drain or spin cannot open door
  • Washing Mach... Master
  • 5,323 Answers
No agitation?
first use a meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good. now take the original hose tube and plug one end and blow into it the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
sometimes they get busted open or a pin hole and release air causing the water switch diaphram to not open.
If both check ok then next CHECK the motor coupler or belt if belt driven.check with a multi meter for continuity the door switch, and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Posted on Mar 29, 2015
  • Jorge Rendon
    Jorge Rendon Mar 29, 2015
    im sorry wrong answer for no spin try this. No agitation or spin? try these: Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly. Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it. Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed. Transmission or clutch assembly not engaging due to going out or slipping. Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Error code Te2 appears, how to clear
Error te2 means that the thermistor (part the senses temperature) has a problem. Here is an excellent troubleshooting guide ApplianceJunk com LG Dryer Error Code tE2 thermistor shorted
Nov 10, 2015 | Dryers
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
Where is the temperature sensor on a samung washing machine wf8702rsw?
Such sensors are usually located in the water input assembly where the water is mixed and the computer adjust how far the valves are open for desired water temps. Like adjusting the water valves in the shower for a desired water temp.
Sep 27, 2014 | Samsung WF8704RSW
Won't drain and spin. Cycle completes and all the lights on far right flash. Door won't open. Bottom of washer is filled with water. Tried putting it on drain and spin cycle. Still won't drain. Beeps...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 08, 2010 | Frigidaire Washing Machines
Afrer washing it stops spining and all the lights start flashing the door will open but the washing is still soaking wet
heatman101
Aug 28, 2010 | Hotpoint Washing Machines
How to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Jun 14, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
I have a thatcham TE2-1331/0305 I want to fit in my car but need a wiring diagram STERLING EXCEL THATCHAM TE2-1331/0305 ALARM IMMOBILISER Neil .
My 2005 Dodge Caravan head lights and dome lights stays on a little longer then the norm. Also the chime indicator that lets you know that you left the lights on or you left the keys in the ignition comes on as soon the door is open.I have had one battery go dead on me . Can't afford to be replacing batteries when they go dead on me! Can you help?
Jun 11, 2009 | Anti-theft Alarm System 3 Series E90 E92...
No Spark 1992 toyota camry
you should also check the crank position sensor this is what tells the ecm when to spark. this is a prox switch and when unplugged and checking ohms while cranking you should see a sqaure wave. should go from 0 ohms to infinity. when these go out you will not get any spark on any cylinder
May 19, 2009 | 1994 Toyota Camry
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
