Question about Grilling
How do i replace igniter on threader indoor gas grill pb30zs
5 Suggested Answers
  • 36 Answers
SOURCE: igniters for gas grill
Go to your nearest Vermont Casting dealer and they will directed you on the part number and the dealer you need to go through.
If it is the collector box you are looking for part number
# AN000103
Posted on Apr 28, 2008
bulldogchief
  • 388 Answers
SOURCE: Need cookbook for George Foreman Indoor/Outdoor Grill
No problem! Hopefully she will read some of the recipes on the site and use them, then change her mind about the cookbook...you never know!
Posted on Jan 28, 2010
  • 10 Answers
SOURCE: Charbroil gas grill will not ignite... needs repai...
may just need new battery in the button
Posted on May 01, 2010
SOURCE: How to replace ignition switch
where does the ignitor switch plug into ? genesis ....came unpluged
Posted on Jun 13, 2010
The line to the pilot leaks out propane right before the pilot burner.
Even the smallest pressure drop caused by this "leak" would prevent the pilot from igniting. If the pilot remains lit you may be confusing the leak with the gas control valve opening. The valve opens a few seconds before the igniter ignites the gas to create a flame. This is normal. If you have a gas grille you would know that you need the gas valves open to start a flame. Unfortunately, they have no safety mechanisms like a flame safety sensor that would be typical to indoor gas appliances.
Aug 23, 2014 | Heating & Cooling
Have brand new 810-3330-s brinkman grill main igniter is receiving no gas, is there a screw to adjust flame?
BEWARE: DO NOT TRY SUCH HAZARDOUS TRICKS YOURSELF AS LOCATING A SCREW TO ADJUST GAS PRESSURE. CONTACT THE DEALER OR AUTHORIZED CUSTOMER CARE.
Mar 29, 2014 | Brinkmann Brinkman Barbecue Grill Gas...
Char glo indoor gas grill
leave at least 1/4 inch between briquettes. sometimes clients will pile-up briquettes hoping to make the grill hotter or more efficient but the briquettes can become an impediment to heat circulation which will cause heat to spread low. this usually damages the module and control valves. A single layer with small space between each briq is sufficient.
Oct 29, 2013 | Thermador Grilling
Replace indoor natural gas grill
Did you find a replacement? I'm looking for the same thing. I need a gas valve for mine and I can't seem to find it.
Jan 01, 2010 | Grilling
Grill won't stop ignigting
See if the thermal bulb is in the flame, if not gently bend the bulb so that it is in the flame if that does not solve the problem you will have to replace the bulb to the igniter.
Jun 14, 2009 | Wolf Manufacturing Gas Kitchen Range
I HAVE A WHIRLPOOL GAS OVEN AND GRILL AKG667 MODEL NUMBER 853566715000 WHEN THE GRILL OR OVEN ARE SWITCHED ON THE FUSE CONTINUALLY BLEW. I CHECKED THAT THE CONNECTIONS WERE OK. NOW WHEN THE...
hi thanks for the question so the igniter works but no gas most of the gas stoves have the same problem if the igniter works but no gas could still be the igniter the igniter must get almost white hot to ignite the gas if id does not the gas wont lite so the ather problem is igniter lights but no gas problem is with the 2 coils on the gas valve replace those thanks the appliance doc
Sep 17, 2008 | Whirlpool Kitchen Ranges
CGB-29 Indoor Gas BBQ
If you place a flame on the electrode tip and it starts to spark shortly afterward, replace the electrode.
RepairClinic part #1021725
Nov 16, 2007 | Thermador Professional PB30ZS Indoor Grill
Indoor Grilling vs. Outdoor Grilling.
Basically, if you can grill it outdoor - you can grill it indoors. Notice that indoor grills can't drain liquids as well as outdoor grills, so this should be kept in mind. Bon apetite!
Aug 01, 2007 | Toastmaster TG21W Indoor Grill
Grilling Logo
80 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
