Question about Soundstream Vir-7830b 7" Tv Touch Screen Cd Dvd Mp3 Mp4 Divx Sd Usb Aux Blutooth
What format can I use to watch music videos on head unit in car? either on cd, dvd, usb, sd card?
I have te Kenwood DDX514. How can I get it to play music videos? thank you
Car Stereo Oxnard Kenwood DDX-418 Demo - Breakers ...
? 2:59
https://www.youtube.com/watch?v=SG6bJ6RHMgQ
May 19, 2011 - Uploaded by Josh Furagganan
But I can't get my iPod to play music on it. ... You need to havethe Kendwood iPod cable to be able to do netflix, music videos, etc. and it's only ...
How to make any video file format play on most in dash dvd ...
? 8:45
https://www.youtube.com/watch?v=8V8hyvguTw8
Dec 9, 2012 - Uploaded by richboy12
How to make any video file format play on most in dash dvd systems (Pioneers, JVC, Kenwood) .... My stereo can't read mp4 so does that mean no music video for me or are there any other ways I can watch music video in my ...
Kenwood DDX770 DVD Receiver Display and Controls ...
? 2:12
https://www.youtube.com/watch?v=IHH5Jhb6O6w
Mar 20, 2013 - Uploaded by Crutchfield
You can watch video on the Kenwood DDX771 receiver's ... Hi, I ordered ddx771 and I can't get my iPhone to play music through the usb.
Dec 16, 2015 | Kenwood DDX514 Car DVD Player
How to format my sd card to play video on my boss bv8962
i had the same problem. It is illegal to watch videos while driving hence why they dont tell you how to play youtube off of card and usb. But after hours of testing converted videos here what works for me.
download pazera free flv to avi converter. after that you will have to custom convert the videos with these settings....video format is MPG custom MPEG-2/ FPS 29.97. Audio mp3-mpeg- layer 3/ bit rate 128 and i added stereo-2 for kicks. last but not least custom resolution 720x480. convert and it works :)
Dec 16, 2012 | BOSS AUDIO SYSTEMS BV8962 Car Video Player
I can't get my sd card to work on boss bv8962
make shore you have the right format of music on ur sd card so the player can play it eg avi mp3 mp4
Feb 22, 2012 | BOSS AUDIO SYSTEMS BV8962 Car Video Player
Cannot get my ipod/iphone to play the video clips on my jvc kd-avx77 it plays the sound just not getting any video clips dvd player is working fine music plays fine on the ipod/iphone just cannot play...
Hello there, the JVC unit can play 2 video file formats these are JPEG/MPEG. To watch video you need to have USB audio and video cable for ipod/iphone, KS-U30 to the usb cable from the rear of the unit. When this connection has been made you touch [SRC] then select iPod. When you connect your ipod/iphone to the USB terminal if it is not selected automatically you can select it from the SRC menu. You can check this out on page 49 of the user guide.
Also the unit only supports certain file formats which are mpeg and jpeg and also of a certain resolution. This can also be found on page 59 of the user guide.
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 16, 2011 | JVC KD-AVX77 Car Video Player
When i put my r4 into my ds its just says cant find menu?
hi it sounds like a software problem. follow the following instructions. Please can you try and reformat the 2gb micro sd card in your pc and copy firmware from the CD back onto the 2gb micro sd card following the instructions below. be warned that formating will remove even the games from the card so make sure you have a backup of the games saved to your computer. any saved games will also be erased.
To format the 2gb micro sd card
1. Insert sd card into usb stick and into usb port.
2. Close autoplay screen if it appears.
3. Right click on removeable drive. (Eg D, E, F or J etc) that appeared on screen in computer window.
4. Left click on format in menu and when format window appears, tick quick format box and select ok. This will erase all content on the sd card and remove any corrupt firmware.
To reload firmware
1. Insert cd into pc cd/dvd drive.
2. Open cd drive on screen and copy and paste the files and folders from the system/english 1.18 folder on the cd to the removeable drive that the usb and micro sd card are in. The folders that you will copy are "_system_" and "moonshl" and the files will be "menu.dat" and "mshl.nds".
3. Once copied, check removeable drive to ensure files and folders have copied over.
4. Remove usb stick from pc and insert sd card back into R4. R4 menu should appear on DS screen.
this normaly sorts this out. paul
Jul 07, 2009 | Nintendo DS Lite Console
Doesn't show mp3 files on micro sd card
You have to drag and drop only the MP3 files into the music folder. If you have them organized and in folder by artist, drag only the MP3s into the card's Music folder.
May 05, 2009 | Lands Phones
I don´t known how watch videos on SD card - Jensen vm9512. Format
yes you can watch video
I alredy did it in my jensen
all you have to do is:
xvid avi
video codec: mpeg4
video bit rate: 887kbits/s
video size: 576x320
aspect ratio: 16:9
set this setting in total vide converter
do the convertion and that's.
Mar 19, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
JVC KD-AVX 40 compatiable USB H/Drive
You can use any non powered USB drive (gains its power from usb only). You just have to plug it into your PC and select Properties > Format then make sure you format it in FAT12, 16 or most commonly (recommended) FAT32 file system.
Once you've done this you can transfer all your music onto it then plug it into the USB port lead from the back of the head unit
Feb 26, 2009 | JVC KDAVX44 Car DVD Player
Plays the same introduction over and over
The juicebox has a built in video intro that plays when there is no media inserted; it's a cyclic clip from various cartoon network shows. In order to play a video, you have to insert a Juicebox Video cartridge into the player.
To use the MP3 kit, you put the SD card holder into the Juicebox. install the Juicebox software on your computer, put the USB card reader in your computer, and insert the supplied SD card. put a music CD in your computer, use the juicebox ripping software to convert the CD music into 128kbit MP3's, put them into the SD card. then take the SD card, put it in your juicebox SD card adaptor, turn it on. music will come out.
Dec 25, 2007 | Mattel Juice Box 512 MB MP3 Player
Soundstream Vir-7830b 7" Tv Touch Screen Cd Dvd Mp3 Mp4 Divx Sd Usb Aux Blutooth Logo
117 people viewed this question
Top Soundstream Car Audio & Video Experts
Jerry Umali
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
